8 or 16 GB RAM?
Started May 31, 2012 | Discussions
reid thaler
reid thaler Senior Member • Posts: 1,518
8 or 16 GB RAM?
I'm building a new system. I current have 8 GB in my current system and it seems to usually runs using 4-5 GB of RAM.
I'm using PS and Lightroom. Any reason to bump up to 16 GB?
Thanks!
Reid
http://www.lumiograph.com
Kodak Brownie
Argus 126
Quaker Oats Container Pinhole Camera
Ho72
Ho72 Senior Member • Posts: 1,711
Re: 8 or 16 GB RAM?
Depends on what you're doing. Working up photos for Facebook is one thing, stitching 16bit panos is another.
If you're sure your memory usage is as low as you report it to be then 8GB will probably be fine. I tend to error on the side of "more is better" so I personally would go for 16...
Barry Fitzgerald Forum Pro • Posts: 29,888
Re: 8 or 16 GB RAM?
I suppose ram is cheap but whilst you'd notice a bump in performance from 4-8Gb ram you won't with 16Gb, at least not at the moment anyway.
reid thaler
reid thaler OP Senior Member • Posts: 1,518
Re: 8 or 16 GB RAM?
Thanks all. Looks like it may be good to keep it at 16 GB. With stitching panoramics, it may be good to have the room, and it's already ordered.
Reid
Kodak Brownie
Argus 126
hotdog321
hotdog321 Forum Pro • Posts: 15,769
Re: 8 or 16 GB RAM?
Yeah, more RAM is always good and it is relatively cheap future-proofing. Some of CS6 RAW processing and filters are pretty heavy-duty. And if you get into video editing, you really should go with 16 GB.
 hotdog321's gear list:hotdog321's gear list
Canon EOS 5D Mark III Canon EF 70-200mm f/2.8L IS II USM Canon EF 24-70mm f/2.8L II USM Canon EF 16-35mm f/4L IS USM Canon EF 11-24mm F4L +1 more
V1V1D
V1V1D Contributing Member • Posts: 667
Re: 8 or 16 GB RAM?
One other thing to consider, make sure you are using DDR3 which I'm sure you are but make it pc-1600 minimum. If your mobo will support higher go for it.
I'm stuck with triple channel on my gaming/PP rig and can't push it past 12gb. Though as Barry said, I doubt I would notice 4 additional gb if I had a dbl channel mobo.
 V1V1D's gear list:V1V1D's gear list
Sony Alpha NEX-7 Sony Alpha a6300 Sony E 18-55mm F3.5-5.6 OSS Sony E 16mm F2.8 Pancake Sony E 50mm F1.8 OSS +4 more
bllarkin Forum Member • Posts: 61
Re: 8 or 16 GB RAM?
On the RAM speed, I disagree. You aren't going to see a performance increase much above DDR3 1600, and anything above 1600 is overclocked anyway (the base speeds of all current RAM is 1600).
 bllarkin's gear list:bllarkin's gear list
Nikon D5100 Nikon AF-S DX Nikkor 18-55mm f/3.5-5.6G VR Nikon AF-S DX Nikkor 35mm f/1.8G Nikon AF-S Nikkor 85mm f/1.8G
karl_h New Member • Posts: 5
Re: 8 or 16 GB RAM?
FWIW,
I recently got a Nikon D800 - large files! I upgrade from 8 to 16 GB and it made a HUGE difference.
Karl
Jim Cockfield Forum Pro • Posts: 16,333
memory speed tests
bllarkin wrote:
On the RAM speed, I disagree. You aren't going to see a performance increase much above DDR3 1600...
Yep, I've seen multiple articles discussing where there is a negligible difference in real world application performance by using faster and/or lower latency memory.
For benchmarks that look at memory speed as part of the test, sure. For real world apps, nope (probably no more than about 2 percent difference with most apps between run of the mill 1333Mhz DDR3 and running memory at 2133Mhz DDR3; with virtually difference at all with some apps).
Here's one example of an article testing different types of memory:
http://www.anandtech.com/show/4503/sandy-bridge-memory-scaling-choosing-the-best-ddr3/1
Here's another:
Here's another article with lots of tests using Sandy Bridge chipsets:
http://techreport.com/articles.x/20377
Gotta love some of the conclusion page.
"If you're looking to set benchmarking records or to compensate for personal shortcomings, K-series Sandy Bridge CPUs at least make it easy to run exotic DIMMs at blistering speeds. Everyone else can rest assured that using relatively inexpensive DDR3-1333 memory won't cost them much performance in the real world"
Of course, anymore, it's just as cheap to buy 1600Mhz DDR3.. But, I wouldn't spend more on premium memory that can run faster with lower latency, as you're probably not going to see any benefit for the extra cash, unless you're just looking for "bragging rights" as to how well a system tests on benchmarks that take memory speed into account.
JimC
I'd go 16GB for the extra disk cache
With a brand new system using DDR3, I'd probably go with 16GB of 1600Mhz CL9 type memory, as a set of 4x4GB rated at 1.5v with 9-9-9-24 timing can be bought for under $100 anymore (and personally, I wouldn't spend more to get anything faster, unless it just happened to be on sale).
I'd just check the supported memory list on the Motherboard manufacturer's web site to make sure I'm buying something compatible with it, and I'd read though user feedback for the product I'm buying to see if others had any issues with it.
Here are 4x4GB sets of 1600Mhz DDR3 at newegg.com
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=100007611%20600006127%20600006073&IsNodeId=1&name=16GB%20%284%20x%204GB%29
If you sign up for their e-mail specials, you can sometimes find memory for even less (as I see e-mail specials from them almost every day with promo codes for more off of many components).
Even if your apps can't make use of it, the Operating System should use most of it for disk cache purposes (and I rarely reboot my PCs, meaning that frequently accessed data will be more likely to be in disk cache). I do use LInux most of the time, and cache algorithms will vary by OS. But, Windows should also use most of the available memory for Disk Cache purposes.
I'm at 6GB (2x1GB + 2x2GB) on one PC and 8GB (4x2GB) on another one with Core 2 Quad in it. But, if I were upgrading to a new machine, I'd go 16GB, as DDR3 is cheap.
JimC
Sgt_Strider Senior Member • Posts: 2,207
Re: I'd go 16GB for the extra disk cache
RAM is so cheap at the moment that I wouldn't hesitate to upgrade to 16GB if I were the op. In fact RAM was even cheaper in Q4 of 2011. I bought 16GB of RAM and my computer absolutely flies with tens of tabs opened and LR4 runs without any issues.
Sam_Oslo
Sam_Oslo Senior Member • Posts: 2,859
Re: 8 or 16 GB RAM?
RAM is really cheap in these days, so get as much as you can.
If you work with large files, PS can make a good use of 16GBB. You can always create a RAMDisk use it as TEMP-folder and scratch-disk, it will help a lot, specially if you work with editing big-files.
 Sam_Oslo's gear list:Sam_Oslo's gear list
Sony SLT-A77 Sony 50mm F1.4 Sony 20mm F2.8 Tamron SP AF 90mm F/2.8 Di Macro +2 more
RedFox88 Forum Pro • Posts: 24,875
the more ram you have...
The more RAM you have, the more Windows will use it. Plus the more RAM you have, the bigger your swap file will be, i.e. 1.5 times your amount of RAM
In my view, any amount of RAM over 4 GB is wasted money as it won't improve performance because Windows will always be wanting to use a swap file. You can of course turn your swap file off which I've done for my desktop.
(unknown member) Contributing Member • Posts: 946
Re: the more ram you have...
Some ideas:
It is possible to change the Windows setting to reduce the swap file size, correct?
Also if having more RAM, the user should also change the Photoshop memory usage setting to make it use more RAM.
With having more RAM, one may use a RAMDISK program to have Photoshop using part of the ramdisk as a cash & scratch disk which may significantly improve the speed performance.
BruinBlue Regular Member • Posts: 107
raminolta wrote:
Some ideas:
Yup. Windows7 set it at 1X RAM on my 16GB system. I reduced it to 800MB on my SSD for (poorly written) programs that require a pagefile be present.
 BruinBlue's gear list:BruinBlue's gear list
Canon EOS 5D Sony Alpha NEX-7 Sony E 16mm F2.8 Pancake Canon EF 24-105mm f/4L IS USM Sony E 18-200mm F3.5-6.3 OSS +3 more
QuicksilverCA Contributing Member • Posts: 543
Re: 8 or 16 GB RAM?
The more the better, RAM is fairly cheap these days anyways so you may as well go with 16GB
herebefore
herebefore Veteran Member • Posts: 3,296
Re: 8 or 16 GB RAM?
The simplest answer is:
Always go with the most ram you can afford with a 64bit OS.(up to the memory handling limit of the OS)
There should always be an advantage in that.
Larry Lynch
Mystic, Connecticut
I figured out why I cant lose weight! The only exercise Im good at is CHEWING
Don't take yourself so seriously. No one else does
In all matters of opinion, our adversaries are insane.
Oscar Wilde
Re: 8 or 16 GB RAM?
Well up to a point my board takes up to 32Gb or ram in 8Gb x 4 sticks. But that's pretty expensive to deck that out at the max ram wise. 4x4Gb was considerably cheaper.
To be honest yes ram is cheap so no reason to skimp for the sake of a modest outlay 16Gb is pretty cheap to do (in 4Gb modules that is) I can't say I noticed a difference with 8Gb though. 4Gb is ok for most normal non heavy users, 8Gb should take care of most more demanding ones.
I can't see any reason to even think about 32Gb though even for very demanding users
herebefore
Re: 8 or 16 GB RAM?
I agree.. today, 32gig is overkill for most users.
I have found though, I can update one of my systems to 16 gig for about $108 (US $) with 2 8gig chips, so I have ordered them. (two chip motherboard).
The two 4gig chips currently in it will go to another mobo that has room for 4 chips (currently holding 2gig chips). I will add 2 more 4gig chips to it and have both systems running with 16gig (perfect for running Lightroom 4.# with a LARGE catalog).
The 4 left over 2 gig chips will go in the "parts box" or get used in a Linux box.
Larry Lynch
Mystic, Connecticut
Oscar Wilde
coolaction Regular Member • Posts: 327
Re: 8 or 16 GB RAM?
I currently have 8GB in my current system and it seems to handle mostly everything, that said RAM is pretty cheap so I think I may upgrade it to 16GB in the near future.
