Existing Ambient Light in Potential Home Studio Space
Started May 30, 2012 | Discussions
andrewbdub Regular Member • Posts: 467
How much ambient light is too much in a studio?
I've recently moved to a house that has a room big enough to hold a home studio. However, the room does have a reasonable amount of ambient light, about 90% of which comes from West-facing floor-to-ceiling windows. I could get some dark curtains or external shading for these windows, but would still be left with some light coming in via a skylight, up a stairwell and through a small side widow.
I don't want to buy a set of lights, backdrops, etc only to find that I need to restrict my shooting to after sunset. Any advice, thoughts, input would be greatly appreciated.
andrew
http://www.andrewbottphoto.com
kgbruce01 Senior Member • Posts: 1,245
Take a shot at max sync/lowest ISO - is it black? Good. (nt)
andrew
Don89 Contributing Member • Posts: 703
Re: Existing Ambient Light in Potential Home Studio Space
Like KG Bruce said. Take a test shot and see.
I had a client who was concerned his factory would bring too much ambient light in and influence the flash photos. I simply turned off all the flash units and shot a few frames of the setup and also turned around and shot the factory floor at the settings I was using for the shoot.
No light showed at the shutter speed and aperture I was using for the flash photography.
You could try 1/200 and 1/250 second light at f8 and see if ambient shines through. Test again from 1/60 through 1/250 at f8, then again at f5.6, 2.8... until you see the ambient. You'll see the limits and influence of ambient to your arrangements. Some ambient might be acceptable - depends on your needs. Also - ambient only might look good too - depending again on your setup.
f-stop controls your flash and shutter speed controls ambient.
Sailor Blue
Sailor Blue Veteran Member • Posts: 9,296
It isn't quite that simple.
ISO, aperture, and flash power control the flash exposure.
ISO, shutter speed, and aperture control the ambient exposure.
 Sailor Blue's gear list:Sailor Blue's gear list
Fujifilm FinePix Real 3D W3 Canon EOS 7D Tamron SP AF 90mm F/2.8 Di Macro +10 more
it is that simple.
andrewbdub OP Regular Member • Posts: 467
Thanks Don, Sailor Blue and KB
andrew
Barrie Davis
Barrie Davis Forum Pro • Posts: 21,460
It's curtains for you!
There is too much ambient light in there for you to do controlled lighting with artificial lights. Even if an 'X' sync test yielded a black result, the high level of ambient contamination would mean your flash modelling lights were more or less useless....
.... which would make them hard to use, and even harder to learn with.
You need to install full blackout blinds or curtains (drapes) throughout, or give up on the idea of working by PLACED lighting until after dark.
However, even as an ambient-only work space you would still need some control over the light sources... for which curtains/blinds are the only practical solution.
Baz
"Ahh... But the thing is, they were not just ORDINARY time travellers!"
Barrie Davis
Don89 wrote:
it is that simple.
It is simple, but it isn't THAT simple!
  • Shutter speed controls ambient, independantly .
  • Flash power+distance controls flash, independantly .
  • Aperture controls flash AND ambient, together and in step .
  • ISO also controls flash AND ambient, together and in step .
Some people find it helpful to write/print the above on an index card to then keep with their kit.
Baz
Re: It's curtains for you!
People still use modeling lights? Funny.
Don89 wrote:
it is that simple.
Only in your head, because you are soooooo aew-sum at it.
So, in summary,
f-stop controls your flash and shutter speed controls ambient. I really like using flash outdoors. Keeping ISO the same, I alter for taste using aperture and Shutter speed. If not tasty enough, I'll use an ND filter.
So we all forgot ND filters, but that does not add to complexity, just control. That might be a consideration as well for an over-ambient situation. Just be careful of the ND filter. Some really impact sharpness.
Sorry, did not realize this was not simple control of the photog's environment. Read up. Plenty of sources out there to study. Simple as Barries extended efforts.
Barrie Davis
Modelling lights.
kgbruce01 wrote:
People still use modelling lights? Funny.
Yes, especially as modelling lights are now becoming increasingly accurate in coverage, AND relative brightness... the Einsteins being a case in point (diffuser dome over lamp and tube.)
And anyway, what's the point in carefully observing in the viewfinder how the light and shadow falls across the model as she takes up different poses, and timing your shots accordingly, if the light you see does NOT reflect the light you're gonna get?
Are you saying you don't work that way. Funny.
Baz
Re: Modelling lights.
Barre, I can work all day long without modeling lights, and get exactly the outcome I envisioned in my head. Exactly, every time. That's how familiar I am with my equipment, and how confident I am in using it.
Funny.
Yes, yes you are.
Barrie Davis
kgbruce01 wrote:
Barre, I can work all day long without modelling lights, and get exactly the outcome I envisioned in my head. Exactly, every time. That's how familiar I am with my equipment, and how confident I am in using it.
It seems to me your confidence is misplaced. You are not even making an attempt at observing or controlling the interaction of light with your subject...
... and yet seem to believe this is some kind of achievement!
You are like one of those people who sees what they get when the shoot was over, and THEN decide it was what they "wanted."
You might fool yourself, but you're not fooling me. Funny.
Baz
Klaus dk
Klaus dk Veteran Member • Posts: 3,349
Baz
Ahh Barrie... the thing is, kgbruce01 is not just an ORDINARY photographer! Take a look at his posts across the forums, and you will se how far above the rest of us he is. And incredibly modest and generous, too.
Less is more
 Klaus dk's gear list:Klaus dk's gear list
Canon PowerShot S120 Canon EOS 500D Canon EOS 7D Canon EF 35mm f/2.0 Canon EF 50mm f/1.8 II +9 more
Barrie Davis
Klaus dk wrote:
Baz
Gosh! Yes. I see what you mean... Thanks.
I also note how he likes to rubbish respected posters' advice, without offering the slightiest justification, OR anything to replace it.
http://forums.dpreview.com/forums/read.asp?forum=1055&message=41664753
Baz
Baz
Gosh bare, so jealous of my superior photo skills... One day Barre, one day you will be good too. Just not yet. poor, poor Barre.
