Trying to use ND Filters
Started May 27, 2012 | Discussions
Nhelnhel
Contributing MemberPosts: 811Gear list
May 27, 2012
I took a photo of a river dam with a ND filter.
I hope i can find a beautiful water fall or a much beautiful flowing water place to photograph.
Here it is...
Comments and critiques are always appreciated.
Thank you in advance.
 Nhelnhel's gear list:Nhelnhel's gear list
Pentax K-3 Pentax smc DA* 16-50mm F2.8 ED AL (IF) SDM Pentax smc DA* 50-135mm F2.8 ED (IF) SDM Pentax smc DA 70mm F2.4 AL Limited Sigma 300mm F2.8 APO EX DG HSM +2 more
JDBraun
Junior MemberPosts: 49
Re: Trying to use ND Filters
In reply to Nhelnhel, May 27, 2012
How many stop ND filter did you use on this? Looks good to me - the water flowing over the dam in particular is just creamy.
Josh
TMalford
Veteran MemberPosts: 7,684
Here it is...
Brutal honesty has me responding that the composition is nicely balanced, but the light is uninteresting, the time value is too long for this much movement, robbing the water of interest, and the dam is not appealing. There's way too much stuff that doesn't really have a reason to be in the image.
Solutions/suggestions:
Shoot when the light is better. Get closer to something and don't include so many distracting elements that are not interesting. Experiment with shorter time values. Make the water interesting, not just a mass of white.
Tan68
Veteran MemberPosts: 4,010Gear list
In reply to TMalford, May 27, 2012
TMalford wrote:
... the time value is too long for this much movement, robbing the water of interest, ...
I understand it was a practice shot. I am posting under TMalford because I also thought the water looked a little too smooth. Some people like a bit of texture in water and some people like less. It is just a mater of taste. Here is a recent thread that shows water at different shutter speeds. There is also some comment about preferences.
http://forums.dpreview.com/forums/readflat.asp?forum=1036&message=41305771&changemode=1
Cideway
Veteran MemberPosts: 5,634Gear list
In reply to Nhelnhel, May 28, 2012
I would avoid shooting below f11 if you can possibly even sticking to f8 unless you really need the depth of field.
Chris.
A weather sealed ultra wide, is that too much to ask?
http://www.pentaxphotogallery.com/chriside
GMT +9.5
Pentax SLR talk FAQ
http://forums.dpreview.com/forums/read.asp?forum=1036&message=23161072
 Cideway's gear list:Cideway's gear list
Pentax K-5 II Pentax K-3 Pentax smc FA 50mm F1.4 Pentax smc DA* 16-50mm F2.8 ED AL (IF) SDM Pentax smc DA* 50-135mm F2.8 ED (IF) SDM +2 more
leopold
Forum ProPosts: 11,964Gear list
In reply to Cideway, May 28, 2012
ND filter can be helpful, hope you will find an interesting waterfal.
Leopold
Pentax forever
http://smarcoux.zenfolio.com/
http://www.limagier-photo.com/
http://www.firstlight.com/galleries.php
http://steevemarcoux2.wordpress.com/
Nhelnhel
In reply to JDBraun, May 28, 2012
Josh
I used the B&W ND 64x
Thank you.
Josh
Nhelnhel
In reply to TMalford, May 28, 2012
This is only a quick test that i made.
Thank you very much for your comments and suggestion.
Here it is...
Nhelnhel
In reply to Tan68, May 28, 2012
Ive read that thread and its really depends on its own taste/preferences.
Thank you again.
Thank you again...
Nhelnhel
Chris,
Ill note that on my mind and use it on my next water flowing photos.
Thank you very much.
Chris.
GMT +9.5
Pentax SLR talk FAQ
Nhelnhel
In reply to leopold, May 28, 2012
Leopold
Thats what im hoping for "find an interesting waterfall"
Leopold
Pentax forever
