Why isnt the PL452.8 the reference lens for testing m43?
Started May 25, 2012 | Discussions
Adventsam
Veteran MemberPosts: 4,983
May 25, 2012
Does anybody find it kinda weird that the reference glass for m43 testing is a legacy 43 glass? I have nothing against the 50mm its a cracking glass, but still a native lens of the calibre of the PL452.8 is equal to the task, surely?
Anders W
Forum ProPosts: 21,460Gear list
Re: Why isnt the PL452.8 the reference lens for testing m43?
In reply to Adventsam, May 25, 2012
Perhaps you missed it, but Andy Westlake already answered that question the first time you asked it. Have a look here:
http://forums.dpreview.com/forums/read.asp?forum=1041&message=41606195
Panasonic Lumix DMC-G1 Olympus OM-D E-M5 Olympus E-M1 Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS Panasonic Lumix G Vario 7-14mm F4 ASPH +28 more
Steen Bay
Veteran MemberPosts: 6,792
Andy Westlake told/showed you why here :
Vaughan Williams
Contributing MemberPosts: 741
Absolutely not.
Whether or not the PL45 is as sharp (and I doubt it, and I own both), the Oly 50 is a true reference in that it's been used to test every single 4/3 and micro 4/3 body and so provides a constant reference point for all future bodies against previous bodies.
Your constant advancing of all things Panasonic against all things Olympus does you a great disservice - you were right about the great improvements of LR4 but very few people took any notice of you because nobody takes you seriously because of your partisanship.
Adventsam
Re:OK I missed it.
In reply to Vaughan Williams, May 25, 2012
Now I know DPR got a bad copy; Thanks.
Vaughan Williams wrote:
Absolutely not.
Somebody has to be on Panasonic side, as this whole forum is so pro Olympus its embarrassing at times. I don't give a damm if people do or dont like what I say; I usually ask my questions in good spirit and generally they are received with good response. I am what I am and aint going to change. People generally don't like the truth, it hurts if it goes against there feelings.
Ollie 2
Senior MemberPosts: 1,525Gear list
Re:OK I missed it.
"People generally don't like the truth,"
Since when is "fanboy delusion" a synonym for "truth"?
 Ollie 2's gear list:Ollie 2's gear list
Sigma DP1 Merrill Olympus PEN E-P2 Fujifilm X-Pro1 Olympus OM-D E-M5 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 +16 more
Anders W
Re:OK I missed it.
Have you ever considered being on neither side or on both?
Yes, this is noticeable.
You are getting fewer good responses than you used to. And this is understandable.
That's a pity.
It's a mistake to generalize your own personality to others. I want to know the truth even if it hurts at times. Not so sure about you.
Guy Parsons
Forum ProPosts: 22,727Gear list
Why they use 50mm
In reply to Ollie 2, May 25, 2012
Just check SLRGear's tests for both lenses and see that the 50/2 is the closest to a perfect lens. That's why it's the best thing to use for checking bodies.
http://www.slrgear.com/reviews/zproducts/leica25f14dg/tloader.htm
http://www.slrgear.com/reviews/zproducts/olympus50f2/tloader.htm
Regards.......... Guy
Olympus PEN E-PL5 Olympus PEN E-P5 Panasonic Lumix G Vario 45-150mm F4-5.6 ASPH Mega OIS Olympus 12-40mm F2.8 Panasonic Lumix DMC-LX3 +19 more
Anders W
Re: Why they use 50mm
In reply to Guy Parsons, May 25, 2012
Guy,
The lens Adventsam suggested they use is the 45/2.8 macro (which SLRGear hasn't tested), not the 25/1.4. However, DPR themselves have tested both the 50/2 and the 45/2.8, and, the outcome of that contest is what Andy Westlake referred in order to motivate their preference for the 50/2.
Guy Parsons
Trawling through DPReview lens tests I found the reason why in text.....
The 45mm performs pretty well in our studio tests. It can't match the stratospheric standard set by the Olympus Zuiko Digital ED 50mm F2 Macro (few lenses can), but it's decently sharp and has minimal distortion.
That's in http://www.dpreview.com/lensreviews/panasonic_45_2p8_o20/3
I'm happy with both Olympus and Panasonic gear that I use so no real fanboy bias in my case. I do own the Oly 50/2 but by the time the AF finds where to focus, the subject has lost interest and gone home, but it is a really good lens.
Regards....... Guy
Adventsam
Re:OK I missed it.
In reply to Anders W, May 25, 2012
I prefer Panasonic iq and equipment to Olympus for many reasons.
I have no issue with this.
That's a pity.
You want me to change to pretend somehow?
I think you are sure.
btw, back on topic, the 50mm macro tested on the e-3 body doesnt look so good? are we seeing sensor technology limiting these lens. The softness that dpr observed in the corners is a bit extreme as mostly the borders are sharp too, only extreme. Anyway, I still prefer the 45mm as its a native lens, adapters should be avoided for reference testing.
Guy Parsons
Oh hell, another brain spasm for today!
I had too many windows open and grabbed the wrong one. Sadly they didn't have a graph for the 45mm after I cleaned up my screen and clicked on the right test line - so we have to rely of the graphs of the DPReview tests which do show that the 45mm performance edge to edge is nowhere as good as the 50mm lens.
http://www.dpreview.com/lensreviews/olympus_50_2_o20/3
Sorry again about my stupidity but it is in-built and hard to avoid.
Regards........... Guy
Andy Westlake
Senior MemberPosts: 2,928Gear list
Re:OK I missed it.
Another wonderful example of your view on the world. As it happens we tested two copies, both provided directly by Panasonic - this was (fractionally) the better of them, but overall performance was very consistent between the two.
The test results do not imply the Panasonic 45/2 is a bad lens, BTW. They simply confirm our long-standing opinion that the Olympus ZD 50mm F2 Macro is optically superb, and a benchmark optic that shows the quality of the Micro Four Thirds cameras from both Olympus and Panasonic in the best possible light.
Andy Westlake
dpreview.com
 Andy Westlake's gear list:Andy Westlake's gear list
Fujifilm FinePix F30 Zoom Olympus Stylus Verve S Olympus XZ-2 iHS Canon EOS 5D Panasonic Lumix DMC-GF1 +11 more
Tim in upstate NY
Veteran MemberPosts: 7,120Gear list
And furthermore . .
In reply to Andy Westlake, May 25, 2012
Andy Westlake wrote:
Another wonderful example of your view on the world. As it happens we tested two copies, both provided directly by Panasonic - this was (fractionally) the better of them.
. . . You already provided the test data to Sam in another thread to show him why you use the 50/2 and it hasn't had any effect at all on his stubborn little crusade.
 Tim in upstate NY's gear list:Tim in upstate NY's gear list
Olympus PEN E-PL3 Olympus OM-D E-M5 Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS Panasonic Lumix G 20mm F1.7 ASPH Olympus M.Zuiko Digital ED 14-150mm 1:4-5.6 +3 more
Adventsam
Guy,
The 50mm is a super lens, but I do struggle with the concept of using a lens designed for 43 and an adapter for reference testing on m43. I know people will say it doesnt matter, but for the most part few will use the 43 lens on m43 bodies.
Regards....... Guy
Ollie 2
Re:OK I missed it.
There you go again, Andy, displaying your blatant bias.
D200_4me
Veteran MemberPosts: 3,851Gear list
I like the Olympus 45mm f/1.8
It's reasonably sharp in this shot...(viewed at 100%)
http://bit.ly/JPNygP
 D200_4me's gear list:D200_4me's gear list
Fujifilm FinePix X100 Nikon Df Sony a6000 Nikon D750 Nikon AF Nikkor 50mm f/1.4D +6 more
Guy Parsons
Adventsam wrote:
Guy,
The 50mm is a good lens but best used as a manual focus lens on M4/3 to avoid the frustration of the slow AF.
On the other hand my 4/3 11-22mm lens does perform AF acceptably fast (for me) so is a good lens for M4/3. I do have the 4/3 14-54 Mk1 lens and that is painfully slow AF but others say the Mk2 version of that lens does focus acceptably fast.
There is absolutely no problem with using a 4/3 lens for testing body resolution etc on M4/3 as the appropriate Oly or Pan adapter provides the correct distance to sensor. It's just that the AF may be slow, painfully slow or non-existent according to the lens-body combination chosen.
I notice that in the period that DPReview was testing the Olympus 50/2 lens they used a Panasonic 4/3 body as that body had the best resolution. I wonder if the Oly fanboys were raving on about that travesty in the same way that you are now raving about the reverse situation.
Regards........ Guy
Anders W
Re:OK I missed it.
Yes we know that you prefer Panasonic although the reasons are not always crystal clear. Personally I prefer this or that piece of equipment (of whatever brand) for this or that substantive reason. Have you ever tried this approach to the world? If not, you should. Very refreshing.
That's a pity.
No. I want you to be open to the possibility that you might change rather than being a closed system. Personally, I don't know in advance whether I will change or not. It depends on the information I encounter. Have you ever tried this approach to the world? If not, you should. Very refreshing.
Sure that I want to know the truth, yes.
Hmm. E-3? As far as I can see, DPR tested the 50 macro on the (presumably excellent) Panasonic L10.
And the reason for that would in this case be?
Anders W
Happens to all of us from time to time. My turn next. Please keep that in mind.
