T3/1100D banding? Read-out glitch? Need help I.D.ing these artifacts
Started May 23, 2012 | Discussions
cowboycoffee
New MemberPosts: 9
May 23, 2012
Hi, I'm trying to troubleshoot some artifacting that's been showing up on my friend's Canon T3 (1100D)... My first guess is that it's a sensor read-out / banding gremlin, but I'm looking for help!
Sample images here:
(Canon T3 w/ factory firmware: set to "P" mode with built-in flash, JPEG "S2" 1920x1280, triggered via DSLR Remote Pro)
p.s. The camera was problematic all day this past weekend on location, but we've been unable to re-create the problem in the office today :S
Canon EOS 1100D (EOS Rebel T3 / EOS Kiss X50)
WilbaW
Forum ProPosts: 10,414Gear list
Re: T3/1100D banding? Read-out glitch? Need help I.D.ing these artifacts
In reply to cowboycoffee, May 23, 2012
Have you tried a different memory card?
Check out the unofficial Rebel forum FAQ - http://snipurl.com/RebelFAQ
 WilbaW's gear list:WilbaW's gear list
Canon EOS 60D Canon EOS 7D Mark II
HobbiesAreFun
Senior MemberPosts: 2,454Gear list
Looks to me like corrupted files.
-Eric (17 years old with tons of things I can't wait to learn)
http://eswenson.smugmug.com
 HobbiesAreFun's gear list:HobbiesAreFun's gear list
Nikon D800E Nikon AF-S Nikkor 28-70mm f/2.8 ED-IF Sigma 50-500mm F4.5-6.3 DG OS HSM Nikon AF-Nikkor 80-200mm f/2.8D ED Samyang 14mm F2.8 IF ED MC Aspherical +3 more
cowboycoffee
New MemberPosts: 9
In reply to WilbaW, May 23, 2012
Thanks, do you suppose the problem is linked to the camera being tethered and triggered via laptop?
photonius
Veteran MemberPosts: 6,381
yes, my first impression as well is corrupted files. Given that it was tethered, that's a source of errors if it was not the memory card.
perhaps the cable had a bad contact?
Anyway, test camera back and forth with a freshly formated memory card that is good. If that doesn't show any errors, it's not the camera per se.
Life is short, time to zoom in ©
cowboycoffee
New MemberPosts: 9
In reply to photonius, May 23, 2012
Thanks photonius. Yeah, we didn't have much luck re-creating the glitch when the camera was shooting directly to a card... so it sounds like the latest consensus is that we've got corrupted files because of the cable or laptop.
Cheers!
Y0GI
Veteran MemberPosts: 5,228Gear list
In reply to cowboycoffee, May 24, 2012
Cheers!
I'm confused! Were the scrambled shots that you posted from shots saved to a memory card or saved to the laptop? I am not aware that the EOS Utility can save an image to the computer instead of the memory card in the camera. Where did the corrupt images come from: memory card or computer?
Yogi
When you get down to the nuts and bolts of photography, the results depend on the 'nut' behind the camera!
See the 'Gear List' in my 'Profile' for my current equipment.
Check out WilbaW's beginner FAQs at - http://snipurl.com/RebelFAQ
 Y0GI's gear list:Y0GI's gear list
Canon EOS 7D Canon EF-S 10-22mm f/3.5-4.5 USM Canon EF-S 17-55mm f/2.8 IS USM Canon EF 100-400mm f/4.5-5.6L IS USM +2 more
cowboycoffee
New MemberPosts: 9
In reply to Y0GI, May 24, 2012
It's a T3 with no memory card tethered via USB to a PC laptop running DSLR Remote Pro.
Y0GI
Cheers!
I agree. Cable or laptop issue.
Yogi
cowboycoffee
New MemberPosts: 9
Cool, thank you for the help!
