Do you convert NEF to DNG?
Started May 22, 2012 | Discussions
konoplya
Regular MemberPosts: 214
May 22, 2012
if you do, for what reason other than to reduce file size?
also, is any information lost during the conversion or not? i mean image information, not metadata etc.
thank you in advance.
Jan Morales
Regular MemberPosts: 335
Re: Do you convert NEF to DNG?
In reply to konoplya, May 22, 2012
I convert all my raw files to DNG on import. I started years ago when Bridge was my image library because I didn't like the separate XMP sidecar files that got created during processing. I was also sympathetic to the argument that DNG is an open format that is less likely to be orphaned. When Lightroom came around it made the conversion on import fully automatic and effortless.
I imagine a scientist or extreme pixel peeper could determine if there is real image quality loss converting to DNG, but I have never felt like anything was missing from my images.
By the way, in my experience the file size savings are minimal, at least for the cameras that I have used. File size was not a reason why I started converting to DNG.
beshannon
Veteran MemberPosts: 4,203Gear list
To process the file
 beshannon's gear list:beshannon's gear list
Panasonic Lumix DMC-ZS7 Sigma DP2s Nikon Coolpix AW100 Nikon D800E Nikon AF-S Nikkor 16-35mm F4G ED VR +5 more
mwphotog
Forum MemberPosts: 76
Always. Smaller file size, no sidecar files to keep track of, NO loss of image quality....so, why not?
ThePaleRider
Regular MemberPosts: 251Gear list
Eventually, each old camera's RAW file format will fall off the list of those supported by the processing software, meaning that you will have to run an older version of the processing software if you want to be able to continue to view them or process them.
Eventually, that processing software will no longer be supported by the latest operating system, so you will have maintain a legacy operating system just for your raw processing application.
Eventually, support for that legacy OS will be withdrawn and you will not be able to find the hardware to run it.
What then?
No camera maker guarantees to support any of their file formats for ever, so it all boils down to how long you want to look at your digital files for. Five years? Maybe ten is closer to the mark, but I doubt whether you will be able to open D800 NEFs in fifteen or twenty years.
Now, whether being tied to an Adobe format (albeit a supposedly "open" one at the moment) is any more comforting, I don't know, but something is needed. Clearly.
tankahn
Regular MemberPosts: 280
In reply to mwphotog, May 22, 2012
My FastStone Image View (version 4.6) would not display the new LR4 compressed dng files properly so there might be some compatibility issues. Better stick with nef instead of getting a nasty surprise down the road.
Russell Proulx
Contributing MemberPosts: 590
If you embed the original NEF in the DNG then the file size is not larger. I prefer to keep the file my camera created as that's the only true 'original'.
I don't think there will ever be a image format that cannot be opened and used because it was not converted to DNG. Any historian who might care will find a way and there will be no problems my lifetime. For all I know I might prefer to one day use Nikon's own software if it's the best one to use with Nikon files.
I prefer sidecar XMP files and it makes backing up my edits that much easier. I only have to move tiny XMP files to my backup media rather than HUGE DNG or NEF files. If ever there's a write error it won't affect the original.
Them's my 2 cents
R
konoplya
these are all interesting perspectives, thank you all for contributing.
is there software that you like the most for the conversion?
calson
Veteran MemberPosts: 6,808
Meta data is definitely lost with the translation to DNG which is important with the D800 and a number of its exposure features.
It is really quite silly to take the time to do the conversion to save space with a 1TB hard drive selling for under $100. DNG is also "open" in the sense that Adobe has published the spec but it is by no means a universal file format.
Worry more about the availability of hard drives as standards change. IDE are no very difficult to find and the same will happen with SATA in 10 years time. And even if the enclosure has a Ethernet or USB port the drive itself will be IDE/eSATA/whatever.
Russell Proulx
In reply to Russell Proulx, May 22, 2012
Russell Proulx wrote:
Correction (typo): If you embed the original NEF in the DNG then the file size IS LARGER.
fwiw: I still prefer Bridge/ACR for my processing as it works better with my own workflow.
R
Alejandro Daz del Ro Fery
Veteran MemberPosts: 3,735
No ... Re: Do you convert NEF to DNG?
The only present universal file format is the TIFF, but I use NEF and/or JPEG, managed by ViewNX2 and/or CaptureNX2.
Un saludo.
Kaj E
Veteran MemberPosts: 9,059Gear list
Never
I use Capture NX2 to process my NEFs. If I need to continue in Photoshop I do it on a 16-bit tiff.
In my opinion Capture NX2 is a better NEF converter than ACR. The NEF is saved with all edit steps (including Color Efex Pro edits) completely reversible and non-destructive. I can save several edits of the NEF in the same file. No sidecar files.
Kind regards
Kaj
http://www.pbase.com/kaj_e
WSSA member #13
It's about time we started to take photography seriously and treat it as a hobby.- Elliott Erwitt
Mato34
Contributing MemberPosts: 893Gear list
I use ACR but never convert to DNG
Let's say you converted your raw files to DNG.
Do you want to process them using some DNG capable program? No problem.
Do you want to process them using Nikon Capture? Uuuuoooopss!!...
Let's say you didn't converted your raw files to DNG and kept original NEFs.
Do you want to process them using Nikon Capture? No problem.
Do you want to process them using some "only DNG" capable program? Well, convert them to DNG at the moment using the DNG Converter that you downloaded once, and... no problem.
I see no problem keeping original NEFs, but I can see one when converting them to DNG and erasing NEFs...
Saludos!
Please, excuse my poor english...
 Mato34's gear list:Mato34's gear list
Nikon 1 J5
Patrick McMahon
Senior MemberPosts: 1,247Gear list
As someone who loved the .NEF container, DNG originally appealed to me, but using Lightroom pretty much took that away. I think the side care file is great because it doesn't mess with my .NEF if I want to open it in NX2. (there is still a part of me that believes there will be an NX3 - silly me )
I also move my files from within LR and have metadata updated, so I am not scared of 'losing' a sidecar file. I completely understand that it is possible, just not something I found plausible in my work-flow and computer use.
Furthermore, as mentioned, storage is cheap.
But - perhaps the most persuasive for me, is having become a NAPP member and discovering a lot of the Adobe pros not using it. And the ones that do, do not point to a convincing argument.
Great idea, good luck and keep us posted.
This I don't follow...
 Patrick McMahon's gear list:Patrick McMahon's gear list
Nikon D700 Nikon Df Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II Nikon AF Nikkor 18-35mm f/3.5-4.5D IF ED Nikon AF-S Nikkor 24mm f/1.4G ED +6 more
tarnish
Senior MemberPosts: 1,470
To bridge from non-Adobe 1st step to Adobe 2nd step
Not because DNG is "compact". It's because the TIFF alternative is obese.
konoplya
i mostly use NX2 also to mess with NEF files before exporting to photoshop. i never thought about NX2 not being able to work with DNG files. good point as someone mentioned. ACR and lightroom automatically assign their profiles to the raw file which i don't like.
i think i've just made my decision to not bother converting to DNG for now
thanks guys!!
Joesiv
Veteran MemberPosts: 5,494Gear list
In reply to ThePaleRider, May 22, 2012
You think?
It's funny several of my old discontinued cameras still are fully supported by lightroom (ACR) (Nikon Coolpix5000 from 2002 for example).
The way I understood it is, once a profile has been created and put on the list, it isn't removed. Why would they?
It's actually the other end of the chain that is more concerning, new cameras with that need new profiles, are they supported, and when, and will you be forced to upgrade to the newer photoshop/lightroom to view them.
I used to convert to DNG with my old RAW files since compressed RAW was a feature of DNG and not of older NEF's and panasonic .RAW files, not to mention that newer bodies that I bought were out of "support" for older adobe software. But actually now I don't, I keep them in NEF. I may have to go back to DNG if I get one of the new Nikon bodies though :S since Adobe seems to be forcing the upgrade again...
Kudos to Pentax and such companies for natively supporting DNG as their raw format, thus avoiding such choices.
Cloverdale, B.C., Canada
Currently shooting: Nikon D3S, D700
http://www.joesiv.com
 Joesiv's gear list:Joesiv's gear list
Nikon D700 Olympus E-510 Nikon D600 Nikon D750 Nikon AF-S Nikkor 50mm f/1.4G +7 more
tdptdp
Regular MemberPosts: 496Gear list
I need the sidecars, so no. I might process one shot three different ways, and as long as I've got the NEF and the sidecar, I can copy the NEF without the sidecar to a new directory and begin again with the original data.
I could do the same, I suppose, by keeping a reference DNG somewhere, but it's easier for me with NEFs.
KenEis
Veteran MemberPosts: 4,037
Re: No ... Re: Do you convert NEF to DNG?
In reply to Alejandro Daz del Ro Fery, May 23, 2012
Apparently NX2 does not recognize DNG
Ken Eis
http://keneis.zenfolio.com
Skipper494
Forum ProPosts: 10,556Gear list
In reply to konoplya, May 23, 2012
No. I convert to tiiff and process, saving as tiff, then produce whatever jpegs I need.
