600D / T3i Swivel LCD Hood Loupe Solution
Started May 22, 2012 | Discussions
Lawrencew Veteran Member • Posts: 4,369
I was looking for a hood to shade the LCD on my 600D, but couldn't find one that worked well with the swivel LCD. They all require some form of attachment to the LCD body that subsequently prevents the LCD from being closed back in, or don't allow the LCD to swivel at all - which seems pointless.
However, I found it fairly straightforward to buy a Neewer (aka GGS, Perfect) hood with a folding 3x loupe and then add some stick-on Velco strapes to attach it around the LCD.
Works really well, and I love having both a hood and a 3x loupe.
The 3x loupe combined with Magic Lantern Focus Peaking really makes focusing via live view so much easier.
Obviously this would work well with a 60D
Regards
Lawrence
My Flickr http://www.flickr.com/photos/lozwilkes/
 Lawrencew's gear list:Lawrencew's gear list
Sony Cyber-shot DSC-RX10 III Canon EOS 70D Canon EF 70-200mm f/2.8L IS II USM Canon EF-S 18-135mm f/3.5-5.6 IS STM Canon EF-S 10-18mm f/4.5–5.6 IS STM +3 more
Canon EOS 600D (EOS Rebel T3i / EOS Kiss X5) Canon EOS 60D
baneling
baneling Senior Member • Posts: 1,647
Re: 600D / T3i Swivel LCD Hood Loupe Solution
I rarely move the LCD on mine. what's the hood shade that you found? I've never seen one.
Canon T3i
Canon EF-S 18-55mm f/3.5-5.6 IS
Canon EF-S 55-250mm f/4-5.6 IS
 baneling's gear list:baneling's gear list
Canon EOS 600D Canon EOS 5D Mark III Canon EF-S 10-22mm f/3.5-4.5 USM Canon EF-S 18-55mm f/3.5-5.6 Canon EF 70-200mm f/4L IS USM +4 more
WilbaW
WilbaW Forum Pro • Posts: 10,737
Can you use these things while wearing glasses?
Check out the unofficial Rebel forum FAQ - http://snipurl.com/RebelFAQ
 WilbaW's gear list:WilbaW's gear list
Canon EOS 60D Canon EOS 7D Mark II
Lawrencew OP Veteran Member • Posts: 4,369
Yep. I wear glasses and contacts too, and use the loupe with both. It has dioptre adjustment.
Regards
Lawrence
The Neewer one I am using is both a Hood and a Loupe. The Loupe flips up if you want to view the LCD without pressing your eye to the Loupe.
There are other shades around but they are fixed in position and either prevent the LCD from being moved at all, or prevent it from being fully closed in the reverse position.
e.g. http://delkin.com/i-5829814-universal-black-pop-up-shade-for-3-0-inch-diagonal-lcds.html
Regards
Lawrence
Must say that I am finding that this loupe together with Magic Lantern focus peaking is a killer solution for video.
Regards Lawrence My Flickr http://www.flickr.com/photos/lozwilkes/
