Pentax DAL 50mm F1.8 : incomming
Started May 21, 2012 | Discussions
Couscousdelight
Regular MemberPosts: 405Gear list
May 21, 2012
Large maximum aperture for shallow depth of field: F1.8
6 lens elements in 5 groups
Diagonal field of view: 32 degrees
7 aperture blades, rounded for a smooth bokeh
SP coated front element repels dirt and grease and is easy to clean
Image format: APS-C
Screwdrive autofocus
Plastic bayonet
Not a pancake, but still quite compact with a length of 38.5mm/1.5 inches
52mm filter diameter
Light weight: 122g/4.3 oz
Price : expected to be less than 200$.
It should be start shipping in late June.
Source : Pentax Forum
http://www . pentaxforums. com/news/smc-pentax-da-50mm-f18-prime-coming-soon.html (remove the spaces)
Arno
http://www.labellelumiere.fr
http://www.pentaxphotogallery.com/artists/labellelumiere
DAVID MANZE
Senior MemberPosts: 1,123Gear list
Re: Pentax DAL 50mm F1.8 : incomming
In reply to Couscousdelight, May 21, 2012
Hi,
I'm sure it's going to be a goodie, nonetheless a plastic mount! well I'd rather pay a tad more for a metal one.
Dave's clich├ęs
 DAVID MANZE's gear list:DAVID MANZE's gear list
Pentax K20D Pentax K-5 Pentax K-01 Pentax smc FA 50mm F1.4 Sigma 10-20mm F4-5.6 EX DC HSM +13 more
ogl
ogl
Contributing MemberPosts: 983Gear list
Image format: APS-C
Plastic bayonet
Alsmost the same as FA50/1.7, but a big bigger and 7 blades aperture.
 ogl's gear list:ogl's gear list
Pentax K200D Ricoh GXR A12 50mm F2.5 Macro Pentax K-5 IIs Pentax smc FA 31mm F1.8 AL Limited Pentax smc FA 43mm F1.9 Limited +5 more
Couscousdelight
In reply to ogl, May 21, 2012
Cideway
Veteran MemberPosts: 5,634Gear list
They must be looking to knock down the vignetting as this lens on those specs has a larger filter ring the the FA 50 f1.4
Chris.
A weather sealed ultra wide, is that too much to ask?
http://www.pentaxphotogallery.com/chriside
GMT +9.5
Pentax SLR talk FAQ
http://forums.dpreview.com/forums/read.asp?forum=1036&message=23161072
 Cideway's gear list:Cideway's gear list
Pentax K-5 II Pentax K-3 Pentax smc FA 50mm F1.4 Pentax smc DA* 16-50mm F2.8 ED AL (IF) SDM Pentax smc DA* 50-135mm F2.8 ED (IF) SDM +2 more
Marc Sabatella
Veteran MemberPosts: 6,677
In reply to Cideway, May 21, 2012
Yeah, pretty much all the Pentax 50's made since the introduction of the "M" series are 49mm. Only the A50/1.2 and a couple of the macro versions are 52mm. I actually wonder if this might have been to facilitate sharing caps and filters with the kit lens? Although I suppose if they were going to do that, they would have done so with the 35/2.4 too.
viking79
Forum ProPosts: 12,558Gear list
Will be out for july 2012.
Price : 249$.
Ouch, seems high given the plastic mount, no hood, and no internal focus motor (comparing to the $220 Nikon). Still, I am bet it performs well and will be a nice lens.
Eric
I never saw an ugly thing in my life: for let the form of an object
be what it may - light, shade, and perspective will always make it
beautiful. - John Constable (quote)
See my Blog at: http://www.erphotoreview.com/ (bi-weekly)
Flickr Photostream: http://www.flickr.com/photos/28177041@N03/ (updated daily)
Sony SLT-A99 Sony Alpha 7R Sony Alpha 7 Samsung NX30 Samsung NX 30mm F2 Pancake +7 more
awaldram
Forum ProPosts: 10,473Gear list
The filter ring has no input to vignetting.!
The front element has the biggest affect and it looks small as a cheaper lens should therefore vignetting should be worse than the 50.14 at the same aperture.
Chris.
GMT +9.5
Pentax SLR talk FAQ
 awaldram's gear list:awaldram's gear list
Pentax Q Pentax K-3 Pentax smc DA* 55mm F1.4 SDM Pentax smc DA* 16-50mm F2.8 ED AL (IF) SDM Pentax smc DA* 50-135mm F2.8 ED (IF) SDM +11 more
mhike
Regular MemberPosts: 366
In reply to awaldram, May 21, 2012
Finally.
Sounds promising and if anything like the DA35 2.4, it will be a solid performer. I just got my f50 1.7, so I'm out of this search.
I don't think the one additional aperture blade would make a difference, either.
I also hope the DAL50 is as fast to focus as the older F/FA models and as fast as the 35 2.4.
I wish Pentax would get behind their primes and offer the K-30 or k-5 even with a two prime kit consisting of the DA35 2.4 and DAL50. Plastic mount or not, I'm sure fans would appreciate a set with top-notch optics. No depth guage, but again, OPTICS!
Marc Sabatella
In reply to awaldram, May 22, 2012
Well, perhaps not the ring itself, but surely the potential for vignetting is a major concern in deciding what size to make the filter ring? And since most other Pentax 50mm lenses take 49mm filters, the fact that this one doesn't - but physically could - might be evidence that in fact the front element on this in fact slightly larger than it might have been with previous designs of similar maximum aperture. That is, if the lens did in fact have a smaller maximum aperture than it should for a 50/1.8, it would indeed vignette as much as or more than other lenses, but then, it should be able to take 49mm filters without vignetting any further, just as is the case for other Pentax 50mm lenses. So why wouldn't they have given it a 49mm filter ring?
awaldram
In reply to Marc Sabatella, May 23, 2012
I think 49mm is more historical than logical.
indeed most of the more recent designs have required a stepped barrel to get down to 49mm.
It easier to fit a filter thread matching the barrel dimensions which in all mi zooms outsizes any optical requirements (focal divided by aperture).
i.e a 50mm f.18 needs a front element of 28mm !!!
so 49mm or 52mm is a design decision not an optical one.
