HBIF Catch-in-Focus process. (9 imgs)
Started May 21, 2012 | Discussions
brandrx
Forum ProPosts: 24,863
May 21, 2012
Hi folks,
I've been wanting to try my Pentax-A 100mm f2.8 Macro lens for Catch-in-Focus against the hummingbirds so I thought I would, at the same time, write about the process I go through of trying to capture HB's in flight. Normally I would use the DA*300/4 because you can use multiple focus points with that lens. I will assume that most of you already know how to set up the camera for Catch-in-Focus via the menu settings and the proper switch settings.
I first set the A setting of the lens so that I could select the aperture at the lens. Then I pressed the lens lock button and rotated the lens CCW about 10 degrees. This is so I can use the lens in the AV mode and set the aperture at the lens at f8 or f5.6 in order to capture more images. FWIW: An f4 or slower lens will capture more images than an f2.8 or faster lens because of the focusing DOF. Sometimes the light is such that an f5.6 or f8 lens will not fire the shutter with CIF. I had good light for my shots today.
I prefocused the lens at the distance of the approach of the future hummingbirds would be coming in to feed.
Then I moved the camera so that the feeder is more out of the frame. Note: When I use a DA*300/4 lens the feeder is almost always completely out of the frame.
I capture an incoming humminbird but it is not in focus. These things are so fast that sometimes they will move a bit between the time the camera senses Catch-in_Focus and the time the shutter fires.
Other times the camera will sense CIF but the HB is already at the feeder before the shot is actually taken.
Other times you almost make a good capture but the eye is covered.
Finally you get a good shot of a hummingbird in the right place and in focus. However, he/she might not appeal to you for it's color or the position of the wings.
So, then you continue to let the camera take images or you close down for the day and try again the next day. Hopefully you will sometimes get a shot that is sharp and colorful that has a great pose but unlike the following it will not have the tip of it's wing out of the frame. Note: I captured this image in 2011 with the DA*300/4 lens.
Setting up the camera for Catch-in-Focus is the easy part. Capturing a HB in flight with good color and composition and at the same time sharp is the hard part and that all depends on chance.
Cheers.
Ron
Ron - 'We don't have time to go take pics this afternoon Carl.'
Carl - 'What do you mean? It will only take 1/1000s.'
'Keep your eyes looking forward. However, glance back now and then to see where you've come from. It will put a smile on your face.' ~ brandrx
BobORama
Senior MemberPosts: 1,539Gear list
Re: HBIF Catch-in-Focus process. (9 imgs)
In reply to brandrx, May 21, 2012
One key thing: you have to have a subject to take pictures of.
That's a nice tutorial. One question. On A-series and newer, the camera would meter and focus with aperture wide open, and stop down on taking the shot. So why "manage" the aperture at all? If you were forcing the camera into a fixed, tighter aperture to give a thicker DoF - the AF system should be less picky and get more arrivals / departures. That I could understand. But you seem to indicate it works the opposite way, as less light means less focus locks.
In a way, the entire sleight of hand would be avoided if Pentax directly exposed a AF sensitivity setting. Then you could make the AF less picky in CiF mode ( or more picky ).
Fl_Gulfer
Senior MemberPosts: 1,174Gear list
In reply to BobORama, May 21, 2012
So will this work with the Pentax DA*60-250 f4?
Gear Listed in "About Me"
 Fl_Gulfer's gear list:Fl_Gulfer's gear list
Pentax K100D Pentax K-5 Pentax K-30 Pentax smc DA 18-55mm F3.5-5.6 AL Sigma 10-20mm F4-5.6 EX DC HSM +4 more
Canari44
Forum MemberPosts: 57
Great shots.
Do you know if it's possible with the DA* 60-250mm F4 (or with the DFA 100 F2.8 Macro)?
And how set multiple focus points ?
nb : I tried CIF with the DFA 100 F2.8 Macro but i don't know how to set multiple focus points.
brandrx
Canari44...
In reply to Canari44, May 21, 2012
Canari44 wrote:
Great shots.
Thanks Canari44.
Any Pentax autofocusing lens that has an AF/MF switch on the lens can be used on the K20D, K7, and K-5 to do CIF. The DA*60-250mm f4 lens has an AF/MF switch on the lens. Simply set up the menu to do CIF, set your lens to MF and set your camera to AF-S and you are good to go.
To set for multiple focus points, on the K-5 press info twice, use the four-way controller to select Auto 5 or Auto 11, use the focus point selector on the back of the K-5 to select Auto.
The DFA 100mm f2.8 Macro does not have an AF/MF switch on the lens so for purposes of this discussion it cannot be used for CIF.
Cheers.
Ron
brandrx
Bob...
As I have written many times before, when focus trapping hummingbirds from a tripod like this, if the light is good, an f4 lens will focus trap more often than an f2.8 lens, an f5.6 lens will focus trap more often than an f4 lens, and an f8 lens will focus trap more often than an f5.6 lens. That is because the DOF of the focus is greater the slower the lens is. So for instance, you might capture a subject with an f4 lens whereas if you have an f2.8 lens for the same subject in the same position it might not capture it because it might be too far forward or back to detect focus and fire the camera. Believe me, I have long ago given up on using f2.8 lenses for this type of shooting. An f4 will almost always work in any kind of lighting. An f5.6 or f8 lens will not always work because sometimes the light won't allow the camera to sense focus trap.
I once tried a 200mm f2.8 lens for CIF the HB's. I captured two HB's in a four hour period. The next day I switched to 300/4 and captured about 50 subjects.
There you have the main reason that I think the DA*300/4 lens is the best damn CIF hummingbird shooter in the whole danged world.
Cheers.
Ron
brandrx
Fl_Gulfer...
In reply to Fl_Gulfer, May 21, 2012
Except for the 1:3 macro capabilities of the DA*300/4, the DA*60-250/4 is almost as good.
Cheers.
Ron
Greyser
Senior MemberPosts: 3,592Gear list
Great images and great tutorial, Ron. Thank you.
 Greyser's gear list:Greyser's gear list
Pentax K-5 Pentax K-01 Pentax K-5 IIs Pentax K-3
Canari44
Re: Canari44...
Thanks for the explainations.
The DFA 100mm f2.8 Macro has a clamp and when i switch it on off, i can do CIF.
I've made CIF with an old FA 100 Macro but if i remember good, i've made CIF also with the DFA.
brandrx
Re: Canari44...
Well, I would have to see this done myself before I can believe it. However, I do know that it can be done by shorting the data pin with aluminum foil.
Cheers.
Ron
Canari44
Re: Canari44...
i just use the clamp (switch to off), i have tried it (CIF) for flowers in macro mode, set the K5 for CIF, set Macro lens to macro 1:1 and i approach (get closer) the flower to take photos.
PS : excuse my english
brandrx
Re: Canari44...
I guess there must be something about the clamp that I don't understand. I'll take your word for it though.
I guess that the clamp must lock it down tight enough that the lens does not try to autofocus when you press the shutter button?
Cheers.
Ron
Canari44
Re: Canari44...
i can't test it now (my K-5 is faulty, i've a problem with the mirror or with the motor of the mirror). i think that when the clamp is off, AF does not work (the clamp on/off looks like AF/MF). thanks if someone can tried it.
brandrx
Greyser...
In reply to Greyser, May 21, 2012
I'm glad you like them Greyser.
I hope that someone might benifit from what I wrote.
Ron
SanMat
Senior MemberPosts: 2,753
Hi Ron,
I like #6 and #9 the most, as far as detail. I've tried some shorter lenses with CIF from time to time with mixed results. Before selling it I tried using the zeiss 100mm (attached to K5) but I never quite got the perspective and background effect that I wanted. It seemed like no matter which other lens length I tried, I kept coming back to the 300mm, since the combination of feather detail, and also background blur seem to be just right.
Nice to see you've had some good activity there. It's been real quiet here. I've seen a few of the Annas near us (from time to time), but I haven't seen many of the males at their usual perches around the neighborhood. Not sure why, as they are supposed to be here year-round.
Looking forward to more of these.
Pete
Jim Beverlin
Senior MemberPosts: 1,820
Ron - Great shots! Really like # 5. What kind of hummingbird are these?
I really wonder why I continue to subscribe to "Outdoor Photographer" when images that you and others post are superior to what is published in the magzaine.
JRB
brandrx
Jim...
In reply to Jim Beverlin, May 21, 2012
Thanks Jim. The first image (the OOF one) is a male Black-chinned. The last image, the one I took in 2011, is a female Rufous. All the rest are female Black-chinned hummingbirds.
Those are mighty kind words Jim. Thank you.
Have you looked into the Nature & Wildlife Photography Forum yet. I see some great images in there taken with every kind of equipment.
Cheers.
Ron
kriztian
Contributing MemberPosts: 553
Brilliant
kriztian
brandrx
Pete...
In reply to SanMat, May 21, 2012
SanMat wrote:
Hi Ron,
Hi Pete.
Same with me. I've tried everything from a 16mm Zenitar FE, 28mm, 50mm, 85mm, 100mm, 150mm, 200mm, 400mm, 500mm, to Pentax 600mm (via FA*250-600mm f5.6) and I keep coming back to the DA*300/4 lens. Although I've never tried it against the hummers, I suppose the Pentax FA*300mm f4.5 would probably work just as well.
I havn't seen any of the Rufous yet this year. I will begin to worry if they don't show up here in a couple of weeks.
Thanks Pete. I hope you see your male Anna's soon and get some images.
A friend told me that someone around the town had spotted a Calliope hummingbird this year. I've never seen one but hope to some day.
Cheers.
Ron
brandrx
Thanks kriztian. (nt)
In reply to kriztian, May 21, 2012
