critiques?
Started May 20, 2012 | Discussions
dlyfe13
New MemberPosts: 5
critiques?
May 20, 2012
foodsci
Regular MemberPosts: 151
Re: critiques?
In reply to dlyfe13, May 21, 2012
Composition is fine, but the images aren't very sharp. This is probably due to camera shake, try to take at least three consecutive photographs and add some post-processing. Are you using autofocus or manual focus?
dlyfe13
New MemberPosts: 5
Re: critiques?
In reply to foodsci, May 21, 2012
AutoFocus
ollie_b
Re: critiques?
witch camera do you use ? the focus is wrong.
Kweide
Senior MemberPosts: 1,682Gear list
Re: critiques?
In reply to ollie_b, May 21, 2012
WOW
as far as my EXIF reader is correct he did them with a pocket cam:
Kamera: Casio COMPUTER CO.,LTD. EX-Z2
Objektiv: 15.7 mm
Belichtung: automatische Belichtung, 1/125 sek, f/5.1, ISO 200
Blitz: On, Fired
Datum: Mai 20, 2012 9:34:00AM
Datei: 900 × 598 JPEG 156,025 Byte (0.15 MByte, Kompression: 90%
see more of my work on http://www.klaweide.de ( some NSFW )
 Kweide's gear list:Kweide's gear list
Olympus OM-D E-M5 Olympus E-M1 Olympus Zuiko Digital ED 50mm 1:2.0 Macro Olympus Zuiko Digital ED 12-60mm 1:2.8-4.0 SWD Panasonic Lumix G 20mm F1.7 ASPH +14 more
ollie_b
Re: critiques?
In reply to Kweide, May 21, 2012
Kweide wrote:
WOW
Objektiv: 15.7 mm
Blitz: On, Fired
Ok, you must use the best resolution 12M, the best quality of shot, the lower iso without flash.
dlyfe13
New MemberPosts: 5
Re: critiques?
wow, your right. My camera got broken, so I had to borrow this one.
AlbertoGarcia
Regular MemberPosts: 211Gear list
Re: critiques?
In reply to dlyfe13, May 24, 2012
Hello,
nice pictures... important is to capture the moment... and that was the camera available.
Only I would have chosen a lower point of view - is she smaller than you? - this seems to be reinforced by your shooting technique...
Just squat a bit, it would make her look taller (and her legs slender)
have fun!
Alberto García-Briz
http://albertog.over-blog.es
 AlbertoGarcia's gear list:AlbertoGarcia's gear list
Kyocera Finecam 3300 Panasonic Lumix DMC-FZ7 Canon EOS 500D Canon EF-S 18-200mm f/3.5-5.6 IS Canon EF 100mm f/2.8 Macro USM
69chevy
Senior MemberPosts: 1,353
Re: critiques?
In reply to foodsci, May 26, 2012
Look at his focal length and shutter speed. Unless he was driving a running washing machine down a gravel road, it is not camera shake...
Giving advice is nice, but bad advice is not very helpful.
69chevy
Re: critiques?
In reply to dlyfe13, May 26, 2012
The shots are good, but the camera used is not well suited for low light or shadows (the backlit shot). Not your fault, but the center shot is by far the best.
amolitor
Forum MemberPosts: 95
Re: critiques?
In reply to 69chevy, May 26, 2012
The camera doesn't matter. They've all got limitations, this one is just more limited. Work with that.
Given the camera, I would get in closer, a lot closer, and avoid challenging lighting conditions. You're going to want directional lighting, but mild. Morning light, through a window, from the side, and get in close. Have her stop looking at the camera, at least some of the time. I think the strongest image is the third one, largely for this reason.
As others have suggested, figure out how to get the most out of the camera. Just because you can produce good work regardless of limitations doesn't mean you should not remove the trivial limits!
http://photothunk.blogspot.com/
