Clip to hold flowers still in the wind?
Started May 20, 2012 | Discussions
clengman
clengman Senior Member • Posts: 1,916
I've read a number of times about using some kind of flexible armature with a clip to attach to a tripod keep a subject in position when it's breezy. I've been looking around for something suitable and I'm having a hard time locating anything. Anybody aware of brands, or product names to search for? Any ideas for attaching the armature to the tripod? Thanks!
 clengman's gear list:clengman's gear list
Olympus PEN E-PL1 Olympus E-M1 Olympus M.Zuiko Digital ED 14-42mm 1:3.5-5.6 Olympus Zuiko Digital ED 70-300mm 1:4.0-5.6 Olympus M.Zuiko Digital ED 40-150mm 1:4-5.6 +6 more
SteB
SteB Veteran Member • Posts: 4,434
Re: Clip to hold flowers still in the wind?
The main commercial product I know of is the Wimberley Plamp.
http://www.tripodhead.com/products/plamp-main.cfm
I've never used this and what I've used is a Manfrotto Super clamp, a Manfrotto flexible arm and a Novoflex plant clip. This is much heavier, but it can also be used to support heavier items.
The one thing I have found you need to look out for is if you clip the support to the camera tripod. The shock of the shutter and most probably the mirror flip travels through the tripod, down the support and can make the plant it is attached to slightly vibrate or shake.. I was quite surprised when I found this. So ideally such a clip or support should be used on a separate tripod.
In addition to the above I have made some of my own clips and have used foam covered florest's wire. This type of clamping only works in a light breeze and in a stronger breeze parts of the plant will vibrate in the breeze no matter how firmly you clamp the stem. I use a white umbrella I rest on its side as a windbreak.
pictureted Contributing Member • Posts: 723
I occasionally use the Wimberley Plamp and it does help, but when the wind is blowing it will only helps maintain position, you still need a fast shutter to avoid motion blur.
 pictureted's gear list:pictureted's gear list
Fujifilm X100S Nikon D810 Nikon AF-S Nikkor 16-35mm F4G ED VR Nikon AF-S Nikkor 300mm f/4D ED-IF Nikon AF-S Micro-Nikkor 60mm f/2.8G ED +13 more
(unknown member) Forum Pro • Posts: 19,115
To be honest, when I'm outside shooting florals...it must be with optimal conditions...which means a bright (but cloudy) day and absolutely no wind at all. IF the environment isn't perfect, then I simply don't even think of taking any images.
Remember, the outdoor environment dictates to us when we can (and cannot) shoot images....not the other way around
In general I find that early mornings are the best time - overall.
Here's my short blog on the subject.
http://kvincentphotography.ca/blog/2010/11/when-the-wind-blows
IF I find a stunning floral and the outdoor conditions are not condusive...I shoot it in the studio instead.
KEV
http://kvincentphotography.ca/stackedimages
http://kvincentphotography.ca/designerflorals
http://kvincentphotography.ca/macro
orionmystery
orionmystery Senior Member • Posts: 1,696
A friend gave me one of his DIY Plamp. Alll you need are some gardening wires (for bonsai), glue gun, etc.
http://orionmystery.blogspot.com/2011/03/plamp.html
Macro Photography Blog: http://orionmystery.blogspot.com
rightwinger Contributing Member • Posts: 528
Lots of fine ideas above, and I have a few of the clamps, however when the wind is blowing and you want to shoot flowers, look at a portable light tent. You will also get a great light diffuser.......
like this..... http://www.adorama.com/SVLB20.html
'Life's tough ... it's even tougher if you're stupid.' - John Wayne
 rightwinger's gear list:rightwinger's gear list
Nikon D700 Nikon D800 Nikon AF-S DX Nikkor 16-85mm f/3.5-5.6G ED VR Nikon AF-S DX Nikkor 35mm f/1.8G Nikon AF-S DX Nikkor 10-24mm f/3-5-4.5G ED +7 more
I use light tents (large) and small on a regular basis.
However, when shooting outdoors they often ruin the "being outdoors" effect.
Often the tents don't fit well over the flowers (esepcially IF they are tall, or in large clumped shrub format, etc).....
Also, they create a somewhat dull-lighting effect....and priduce an un-natural look.
(remember, there's absolutely no need to diffuse - IF one shoots on a bright but 100% cloudy day)
and thirdly, using a tent will mean...that one cannot get a true outdoor "background' look or bokeh.
The bottom-line is....it's just so much better and less complicated to ONLY shoot flowers outdoors when "optimal" conditions prevail.
Just relax, and let nature dictate to you - when you can shoot.
It's as simple as that
KEV
"It is a small gesture, but one that can be very effective - especially in a large crowd. So fart, and if you must, fart often. But always fart without apology. Fart for freedom, fart for liberty, and fart proudly" (Benjamin Franklin 'The Dream' 1751)
tonyjr
tonyjr Veteran Member • Posts: 5,254
The cheapest and semi easiest is a piece of solid copper wire and either an alligator [ long jaws ] or crocodile clip [ short jaws ] the # 10 or #8 wire is sold at a hard ware store for grounding wire .
OR , just pipe cleaners .
I have got to the point where I just up the speed to around 1/1000 and ISO to 800 - then burst shots good luck .
 tonyjr's gear list:tonyjr's gear list
Canon EOS 400D Canon EOS 7D Canon EF 35mm f/2.0 Canon EF-S 10-22mm f/3.5-4.5 USM Canon EF-S 17-55mm f/2.8 IS USM +14 more
Elvin S Pipperman New Member • Posts: 2
I've been watching a cable show called "Wild Photo Adventures." On it Kevin Adams showed how he uses a wooden stake in the ground (brings a hammer to pound it in) and then uses a pipe cleaner to gently tie the flower stem. Haven't used this yet, but obviously works well outdoors. Hope this helps.
bgD300 Veteran Member • Posts: 4,552
Get a couple of binder clamps
and stop by a bulding site for some heavy guage wiring scraps.  It's not hard to get them two to three feet long.
Alternatively, spend a lot of money on something like the Nikon SW-C1
Actually, just a couple of lengths of the wire should be sufficient.  You can wrap one end around the stem and the other to something handy.  It doesn't have to be the tripod.
My photo blog: http://birdsnbugs.wordpress.com
My camera club porfolio: http://www.pacameraclub.com/bgrant.htm
RF Stock Portfolio - http://www.dreamstime.com/resp129611
EXIF is embedded in photos WSSA #51 as bg5700
 bgD300's gear list:bgD300's gear list
Nikon Coolpix P7100 Nikon D90 Nikon D300 Nikon 1 V1 Nikon AF-S Nikkor 70-200mm f/2.8G ED VR +16 more
T Evergreen Forum Member • Posts: 63
Do a google search on "DIY plamp" and you'll get a number of ideas.  If you're near a Lowes, you can get a couple of KWIKTWISTs.  These are about 30" long and can be used like bread wrapper ties for holding things in place, etc.  Plus, the Kwicktwists screw together for even longer reach.  You can use them alone, or also pick up some small spring clamps at Harbor Freight or elsewhere for a couple of bucks and attach them to the ends of the Kwiktwists with cable ties.  For about $10 or so you can make a couple of really functional DIY plamps.
Les Saucier Photo New Member • Posts: 1
Here is what I use to hold flowers in the wind. It will also hold a macro flashlight, diffuser or background.
http://www.lessaucier.com/store/store.html
Les Saucier
