60D SD Memory Card Speed Recommendation
Started May 20, 2012 | Discussions
xlr8or
xlr8or New Member • Posts: 22
I'm about to order a new Canon 60D and have not previously owned a digital SLR. Although I'm not that much into high speed sports photography, I would like to order a decent speed SD memory card for the 60D. I would probably be shooting in either RAW or RAW+JPEG formats. Most of what I'll be shooting will be candid family shots and nature (landscape/wildlife). Any suggestions regarding the speed of card needed for such applications starting out as a new digital SLR owner?
Thanks in advance!
Y0GI
Y0GI Veteran Member • Posts: 5,228
Re: 60D SD Memory Card Speed Recommendation
Thanks in advance!
I believe that the Canon spec is for a minimum Class 6 for the 60D. However, this spec will undoubtedly go higher as new cameras are released, so to 'future-proof' your card purchase, get at least Class 10 cards for your new camera. The 60D does not have the capability to take advantage of UHS-1 speeds and they are pretty pricey, so I wouldn't upgrade that far.
Yogi
When you get down to the nuts and bolts of photography, the results depend on the 'nut' behind the camera!
See the 'Gear List' in my 'Profile' for my current equipment.
Check out WilbaW's beginner FAQs at - http://snipurl.com/RebelFAQ
 Y0GI's gear list:Y0GI's gear list
Canon EOS 7D Canon EF-S 10-22mm f/3.5-4.5 USM Canon EF-S 17-55mm f/2.8 IS USM Canon EF 100-400mm f/4.5-5.6L IS USM +2 more
xlr8or
xlr8or OP New Member • Posts: 22
I read that Sandisk is a reputable brands of SD cards. Are there other reliable brands with which I can compare prices?
Y0GI
Sandisk and Lexar are the most expensive but prolly the most reliable. Some recommend Transcend. I had good results with PNY SDHC cards in my XSi/450D.
Yogi
victorian squid
victorian squid Veteran Member • Posts: 3,390
As YOGI said, class 10 - the cost savings for anything lower isn't worth it as you never know what you'll be doing.
Sandisk is probably the very best, period.
I can also recommend Transcend (for SD only) as well as Lexar.
I've used Sandisk for years and years for CF and SD cards as well as USB memory. I have yet to have a problem with one. Some have (gasp!) gone through the washing machine. I've also been using Transcend for SD as well for years. I believe there's a video on youtube of Sandisk being abused.
I just picked up some Sandisk at B&H on sale, you can use this as a reference against other places and brands: http://www.bhphotovideo.com/c/buy/SanDisk-One-Day-Special/ci/19004/N/4111826621
With the 60D and a class 10 Transcend card, I've shot well over 80 frames without running out of buffer (JPEG) at a time.
 victorian squid's gear list:victorian squid's gear list
Canon EOS 6D Canon EOS 70D Canon EF 24-70mm f/2.8L II USM Tamron SP 150-600mm F/5-6.3 Di VC USD Canon EF 16-35mm f/4L IS USM +37 more
KentG
KentG Veteran Member • Posts: 4,268
I found a special price for Sandisk 64 GB Ultra C10 SDXC 30MB/s a week ago on Newegg for around $50/each. Only lasted a few days but they come around every now and then.
Kent Gittings
 KentG's gear list:KentG's gear list
Pentax K-5 II Pentax K-5 IIs Pentax K-S1 Sigma 50-150mm F2.8 EX DC APO OS HSM Sigma 18-250mm F3.5-6.3 DC Macro OS HSM +1 more
scorrpio
scorrpio Veteran Member • Posts: 3,388
I have several 16GB Class 10 Transcend cards, they work just fine for me.
Toby1Kenobi
Toby1Kenobi New Member • Posts: 7
SanDisk 16GB SDHC Memory Card Extreme Class 10, which they advertise as 45 MB/s performance. They have good reviews and were on sale till recently below $20 at bhphoto. The sale is gone is gone, and shows for 24.95, but that is only $5 more.
They show the lower speed SanDisk 16GB SDHC Memory Card Ultra Class 10 UHS-I , for 18.99 which is the Ultra line.
I have had multiple Sandisk SD and CF cards and one 32GB Transcend CF card, and no problems so far.
