5d2 & TS-E 45 - first time tilt shift user thoughts
Started May 20, 2012 | Discussions
forbaz Contributing Member • Posts: 510
[cross post in canon lens forum also]
Just picked up a 2nd hand TS-E 45 last week. First crack at seeing what it could do both with some portrait and landscape work today. Not the easiest thing to use for sure, with the manual focus (99.9% of the stuff I usually do is with AF), but definite sense of accomplishment when you get the photo. Especially as it was my first go I felt the need of course to use full tilt and 2.8 for every shot
Happy for cc of pics. A few of them below, all shot with 5d2. More at the link in my signature if you're interested.
PIC 1
PIC 2
PIC 3
PIC 4
PIC 5
PIC 6
 forbaz's gear list:forbaz's gear list
Fujifilm FinePix X100 Canon EOS 5D Mark II Canon EF 35mm f/1.4L USM Canon EF 50mm f/1.4 USM Canon EF 85mm f/1.8 USM +5 more
vvv14 Forum Member • Posts: 56
Re: 5d2 & TS-E 45 - first time tilt shift user thoughts
Congrats on your new toy. Great shots, my favorites are 1 and 4.
However, i can't stop thinking about a tutorial I saw on Photoshop CS6 about selective blurring.
tiberiousgracchus Regular Member • Posts: 250
lovely set. pics 4.5.6 my favs
forbaz OP Contributing Member • Posts: 510
cheers vvv. I havn't quite seen anyone who has been able properly replicate TS via photoshop, but i've seen plenty of not so good examples. I'm more about getting it right in camera and spending as little time as possible on the PP - I don't have photoshop anyway
cheers!
Peter 13 Veteran Member • Posts: 8,301
Sorry to say that but except for the last picture, the rest look like shots taken with a defective lens.
Dimitris Mitrovgenis Regular Member • Posts: 415
Hey I would love this Defective lens.Listen to Peter 13 and sell it to me!!!!!!
sorry Dimitris, this one's staying in my bag for now
russbarnes Senior Member • Posts: 1,199
If you use a slightly narrower aperture you will get a smoother transition to out of focus areas. I have a set here amongst others on my site:
http://russbarnes.co.uk/altered_realities/slideshow
You might find you need to start using grad filters too because out of focus elements can easily be blown using tilt lenses.
 russbarnes's gear list:russbarnes's gear list
Nikon D800 Nikon Df Nikon D810 Nikon AF Nikkor 85mm f/1.4D Nikon PC-E Nikkor 45mm f/2.8D ED +6 more
russ,
thanks very much for the link, and the tip. I had a look through your site - these images are truly exceptional, and i'm not even really a landscape style photographer, but can really appreciate your photos. Can I ask a few questions please - how narrow generally are you going on the aperture? Are you going as far as max tilt, and which of the ts-e lenses are you using in your shots? Thanks again!
Thanks man
I find shooting selectively at f/4 to f/5.6 can render a softer transition between the focussed and out of focus areas. You'll also find that this is likely to render better images because you're using the lens stopped down a little.
Ah yes, something else. I use about 5 degrees, not the whole hog. Using these lenses without going to the max will also produce much better images overall.
Errrrrrrrrr sorry, but I shoot Nikon's 24mm PC-E and 45mm PC-E But I'm sure if you buy the 24mm TS-E II you'll find this is a very capable lens indeed... I'm waiting for Nikon's delivery of a 17mm PC-E which is now under development and due this year...
russbarnes wrote:
Thanks man
thanks Russ much appreciated!
