D800 - best 77mm Circular Polarizer
Started May 19, 2012 | Discussions
Valentin Hertz Contributing Member • Posts: 513
Can anyone recommend a top 77mm Circular Polarizer? I'm looking for very good performance and easy cleaning..I understand the nikon one is not the best...
Thanks!
OleManTx Junior Member • Posts: 40
Re: D800 - best 77mm Circular Polarizer
Have a pair of Hoya HD 77mm Hardened Glass circular polarizers...only recommendation is don't tighten too much as they can be a pain to get off of a lens.
Jogger
Jogger Veteran Member • Posts: 8,441
I have a B+W 77 MRC CirP.. they have another one that is even more expensive (the KSM i think).. but, that was more money than i want to spend on a filter.
Thanks!
 Jogger's gear list:Jogger's gear list
Sony RX100 Sony Cyber-shot DSC-RX10 Nikon D700 Nikon Df Nikon AF-S Nikkor 70-200mm f/2.8G ED VR +4 more
Rich Lanthier Veteran Member • Posts: 3,820
If money is not an issue: Hoya HD (pricey) or B+H XS-Pro (very pricey).... Both are slim (less vignetting) and you can still use lens caps... I buy filters from maxsaver.net
Rich Lanthier
Having fun with photos.
Patco Forum Pro • Posts: 12,076
And if money is really not an issue, get a Heliopan
http://www.bhphotovideo.com/c/search?srtclk=sort&ci=115&N=4277997899+4291103898+4291599900+4291413233+4294954537+4294955264
Patco
A photograph is more than a bunch of pixels
emax Senior Member • Posts: 1,916
Circular Polarizer Tests
Valentin Hertz OP Contributing Member • Posts: 513
Rich Lanthier
Is this the one you mentioned? Also is that easy to clean? I had Hoya in teh past and it was a mess...
http://maxsaver.net/HOYA-77mm-HD-Circular-Polarizing-Digital-Filter.aspx
Thanks!
Like this one?
Thanks!
Maji Contributing Member • Posts: 734
I recommend any one of the CPLs by Singh-Ray.
 Maji's gear list:Maji's gear list
Nikon Coolpix P500 Nikon D800 Nikon 1 V2 Nikon D7100 Nikon AF-S Nikkor 70-200mm f/2.8G ED VR +6 more
orchidblooms
orchidblooms Senior Member • Posts: 1,255
singh-ray lb for the z-pro... seems to be a winner... i have the 'warming' cpl and like it...
That would be the one; never had an issue cleaning it.
Yep, nice filter for the price. The "comparable" B+H is about 200, and the Heliopan, etc, are even more. Note that if you order from MaxSaver it does take a while for shipping as it is from Taiwan. So if you need it quickly.... No problems cleaning this new Hoya format...
Rich Lanthier
Thanks!
Rich Lanthier
Robin Casady Forum Pro • Posts: 12,898
Winners: B+W or Marumi
B+W (not B+H) MRC means multi-coated.
Mrc Nano Kaesemann is their top of the line weather-sealed filters.
http://www.2filter.com/prices/B+W_filters/B+WCircularPolarizers.html
I believe Marumi makes the Nikon branded filters.
http://2filter.com/marumi/marumisuperdigitalHG.html
The both did well in this test:
http://www.lenstip.com/115.4-article-Polarizing_filters_test_Results_and_summary.html
Robin Casady
http://www.robincasady.com/Photo/index.html
Weyskipper Junior Member • Posts: 29
I cannot comment on Singh Ray, but I have heard some very good things. I currently have Hoya Pro 1 and B+W as well as B+W KSM and Nikon. The are all in different sizes, so the comparison is across different lenses and not purely scientific.
However, although the B+W KSM is more expensive it produces visibly better results than the others. The other thing with the KSM is that the polarisation effect is really easy to see through viewfinder.
I would be interested to hear from others who have both KSM and Sing Ray.
 Weyskipper's gear list:Weyskipper's gear list
Canon PowerShot G12 Nikon D800 Nikon 1 V2 Nikon D810 Nikon AF-S Nikkor 300mm f/4D ED-IF +15 more
odedia Regular Member • Posts: 313
If anyone can also comment about MRC vs no MRC in B+W's line, I would be grateful. Does MRC only helps out against scratches / water resistance? Or does it also have an impact on image quality?
odedia
http://500px.com/odedia
http://d800club.com
Leonard Shepherd
Leonard Shepherd Forum Pro • Posts: 10,446
Why do you think Nikon Series II is not one of the best?
It has Nikon's best multi coating - and (poking fun at one reply) was in production before Marumi existed.
Leonard Shepherd
99% of photo equipment is good or very good. The main thing to do with it is to learn to use it well.
Nikon Coolpix P7700 Nikon D800 Nikon D7100 Nikon D810 Nikon D750 +24 more
Charlie3 Forum Member • Posts: 64
Carl Zeiss T* POL Filter (circular) 77mm
Easily obtained in the UK and Europe, or direct from Carl Zeiss in Germany, but not sure what happens in the USA
Charlie
http://www.flickr.com/photos/27592974@N03/
 Charlie3's gear list:Charlie3's gear list
Fujifilm X-T1
Photophanatic Regular Member • Posts: 120
Outdoor Photographer magazine just had an article on circular polarizers that you might want to look at before you purchase one. Look here:
http://www.outdoorphotographer.com/gear/more-gear/gadget-bag/anatomy-of-the-polarizer.html
 Photophanatic's gear list:Photophanatic's gear list
Nikon 1 V1 Nikon 1 V2 Nikon D810 Nikon D500 Nikon AF-S Nikkor 24-70mm f/2.8G ED +14 more
Thank you but not that article is not that great. It's like someone will tell you the first 2 dslr vendors are canon and nikon...
