Anybody know anything about this lens? Leitz 17mm f0.6
Started May 18, 2012 | Discussions
wornleather
New MemberPosts: 4
May 18, 2012
This is a lens I've acquired and can't find out anything about it.
The lens states it was made in Canada for Hughes Leitz (which leads me to believe it may be military in origin, it also says the field of view is 163 degrees and the focal length is 17mm with a speed of f0.6.
The attached pic shows it with an old Canon of mine just for scale - it doesn't actually fit the Canon.
It has a flange-to-image-plane distance of approx 27-28mm which means it should fit M mount cameras (but whatever mount that was fitted has been removed).
It weighs 38lbs, has astonishing optical qualities, superb glass and appears to be very fast - placing a light meter behind the lens shows that there is far more light on the camera side of the lens than there is on the image side.
Anybody seen one of these before or know anything about what format or type of camera it belongs to?
Mike
ProtonPump
Regular MemberPosts: 205
Re: Anybody know anything about this lens? Leitz 17mm f0.6
In reply to wornleather, May 18, 2012
Mike
I dont know anything about it but I would like to buy that f/0.6 lens from you. just for speeds.
CelticOdyssey
Senior MemberPosts: 1,289
Fascinating, and I hope you get some answers. But where does it say its focal ratio is f/0.6?
maxnoy
Junior MemberPosts: 49
Cool stuff! Can you post the image of the back?
maxnoy
In reply to maxnoy, May 18, 2012
Must have been made from 1990-1997 to be branded Hughes Leitz - http://www.elcan.com/Our_Company/History.php .
Has got to be a fisheye with that angle of view. I guess fixed focus. Wonder who can machine an M mount for you.
wornleather
New MemberPosts: 4
In reply to CelticOdyssey, May 18, 2012
It says f0.6on the flight case the lens came with which I assume is accurate as it's seems to be the original factory case. Any idea how the intensity is calculated?
wornleather
New MemberPosts: 4
I'll try upload some images this evening
CelticOdyssey
All I know is that the speed is the distance from the lens to the focal plane divided by the lens diameter. With a compound lens, I'm not sure which lens element.
unknown member
(unknown member)
In reply to wornleather, May 19, 2012
ELCAN Canada made very fast lenses for X-ray applications; but f/0.6 is getting close to the theoretical maximum for a lens in air...
Joe
 Joe Pineapples's gear list:Joe Pineapples's gear list
Ricoh GR
wornleather
New MemberPosts: 4
Here are a few more images of the lens including a very poor and greatly enlarged/cropped view through it, (Sorry it was taken with a crappy Samsung digital - none of my SLRs would focus to 20mm)
I probably should have added these images to the initial post but I didn't know how.
The actual image through the lens is bitingly sharp right to the edges with stunning colour and contrast imo.
It appears to be fixed focus with everything from 5' to infinity being in focus.
Does anybody know what the difference is between a fish eye and an ultra wide angle lens?
I'm tending to the view that this isn't a fish eye as the rectilinear distortion is minimal - is that right?
Lastly some dimensions - The front element is 9' (23cm) across, the rear element has a max diameter of 2.5 inches (55mm) set in a 3 inch (75mm) tube.
I'm leaning to the view that this was an x-ray lens.
Sorry if I sound excited by it but I only paid £70 for it and it is a seriously well made lens with a gobsmacking amount of exquisitely flawless glass.
Now i need an M mount for it.
WhiteWolfy
New MemberPosts: 4
In reply to wornleather, May 26, 2012
I'm 95% certain this lens was used for medical purposes. No focus, no aperature.
Still an interesting find though. Perhaps you could simply hold a camera behind the back element and take a few pictures?
Edit: It's a projection lens used in cinemas... not likely to be very usable for photography.
I know a similar lens which was specifically made for Aurora Borealis research a few decades ago.
Irakly Shanidze
Veteran MemberPosts: 4,364Gear list
In reply to CelticOdyssey, May 26, 2012
right, it does not work for wide-angle lenses.
Irakly Shanidze
http://www.shanidze.com/en
 Irakly Shanidze's gear list:Irakly Shanidze's gear list
Leica M9
WhiteWolfy
New MemberPosts: 4
In reply to Irakly Shanidze, May 27, 2012
It's a projection lens actually.
http://bit.ly/pdf_google
Olaf Ulrich
Contributing MemberPosts: 952
In reply to wornleather, May 28, 2012
wornleather wrote:
Does anybody know what the difference is between a fish-eye and an ultra-wide-angle lens?
A wide-angle lens has a gnomonic projection; a fish-eye has not.
wornleather wrote:
I'm tending to the view that this isn't a fish-eye ...
It most definitely is a fish-eye lens. As it has no adjustable aperture, it most likely is not intended for regular still photography. It might be a projection lens for a planetarium, intended to cast a picture into a dome-shaped projection area.
