Problem with CS6 HELP
Started May 18, 2012 | Discussions
KenEis
Veteran MemberPosts: 3,928
May 18, 2012
I just purchased CS6 and its faster then CS5. But one big problem. I can't view D800 Nikon NEFs with CS6 Bridge even after I upgraded to 6.7. But my old CS5 with the 6.7 upgrade views the D800 NEFs just fine. So CS6 will not open D800 NEFs and says I need to upgrade. So I go to the upgrade and the script tells me I did upgrade. CS6 and its Bridge open the D800s NEFs converted to DNGs or TIFFs just fine. Any suggestions.?
Ken Eis
http://keneis.zenfolio.com
Toermalijn
Forum ProPosts: 12,557Gear list
Re: Problem with CS6 HELP
In reply to KenEis, May 18, 2012
Adobe is working on a raw 7.1, it will be released any time soon.
raw 6.7 does not support d800 files yet, that's all the script says.
You could use the dng converter for the time being...convert the raw files to dng and import into raw 6.7, should work without any problems.
Ken Eis
Stuart001
Regular MemberPosts: 396Gear list
Adobe have a release candidate for ACR 71, available from
http://labs.adobe.com/downloads/cameraraw7-1.html
It states D800, so I hope it helps.
Stuart
 Stuart001's gear list:Stuart001's gear list
Nikon D90 Nikon D700 Nikon D800 Nikon AF-S Nikkor 16-35mm f/4G ED VR Nikon AF-S Nikkor 70-300mm f/4.5-5.6G VR +9 more
KenEis
In reply to Stuart001, May 22, 2012
Thanks I've got ACR 7.1 running and it all works. Now if I could just get NIK's Color Effect pro4 to not bomb CS6 all would be well.
Ken Eis
