OM-D needs more light, longer exposure times! (imaging-resource.com)
Started May 15, 2012 | Discussions
temama
Regular MemberPosts: 467
May 15, 2012
New imaging-resource.com E-M5 test samples here:
http://www.imaging-resource.com/PRODS/omd-em5/omd-em5A7.HTM
It seems that there was nothing wrong with dpreview's OM-D test images, what comes to exposure times of E-M5. New imaging-resource's E-M5 test samples proves that.
OM-D needs more light (longer exposure times) at same ISO value!
Is this Olympus' attempt/trick to make the sensor better looking than what it is?
Yes - I think...
Some examples:
  • Olympus E-M5, ISO 3200, 1/320sec
  • Panasonic G3, ISO 3200, 1/400sec
http://www.imaging-resource.com/PRODS/DMCG3/DMCG3THMB.HTM
  • Panasonic GF2, ISO3200, 1/500sec
http://www.imaging-resource.com/PRODS/DMCGF2/DMCGF2THMB.HTM
  • Sony NEX-5N, ISO 3200, 1/500sec
http://www.imaging-resource.com/PRODS/NEX5N/NEX5NTHMB.HTM
Fiatopichan
New MemberPosts: 20Gear list
Re: OM-D needs more light, longer exposure times! (imaging-resource.com)
In reply to temama, May 15, 2012
Not the same day test, the light doesn't always the same everyday. This doesn't prove anything.
 Fiatopichan's gear list:Fiatopichan's gear list
Olympus OM-D E-M5
Louis_Dobson
Forum ProPosts: 27,087Gear list
Meter under reads by 1/3 of a stop, within the ISO spec, yawn, big deal.
http://www.flickr.com/photos/acam
http://thegentlemansnapper.blogspot.com
 Louis_Dobson's gear list:Louis_Dobson's gear list
Olympus OM-D E-M5 Olympus E-M1 Panasonic Lumix G Fisheye 8mm F3.5 Panasonic Lumix G Vario 7-14mm F4 ASPH Panasonic Leica DG Macro-Elmarit 45mm F2.8 ASPH OIS +4 more
temama
temama OP
Studio tests
In reply to Fiatopichan, May 15, 2012
Yes, it proves. They use exactly the same kind of studio lighting in these indoor samples.
temama
temama OP
yawn, no big improvements
In reply to Louis_Dobson, May 15, 2012
Well - at least not so much sensor improvements
If you can shoot 1/250sec (ISO1600) with Panasonic GF2 VS. 1/320sec (ISO3200) with Olympus E-M5, what does that tell you?
(that you need 1/160sec time with E-M5 at ISO 1600)
Louis_Dobson
Re: yawn, no big improvements
It tells me someone needs to learn how to take photographs. ISO3200 indeed! How desperate would you have to be?
In the meantime I have sitting in this room, and with loads of files on the computer, G1, E-PM1, GH2 and OM-D. I can assure you, processing the files, we've come along by leaps and bounds
temama
temama OP
...that you need 1/160sec time with E-M5 at ISO 1600
OK. I believe you.
...But did you take into account the exposure times ?
Louis_Dobson
I mainly shoot at base ISO, so it's not an issue. But I did a quick shot at ISO 1600, and it seems to have coped fine...
(Oh, and ISO 1600 works out about about 1200 if the metering were spot on, I know)
temama wrote:
OK. I believe you.
Fiatopichan
Re: Studio tests
Oh I forgot to scroll down, just thought about the outdoor shot. That's my mistake.
Olympus OM-D E-M5
Adventsam
Veteran MemberPosts: 4,983
Re: OM-D needs more light,cheats ISO
We know this for sure now;
ISO200=aprox iso130(maybe 125) cw. reference.
Therefore ISO400=aprox250
ISO1600=ISO1000.
They cheat by 2/3 ev. Louis and I agree it matters not a jot but why do it? I prefer to see iso50/80/100 lets get max dr @base, forget the high iso shenanigans.
Yes - I think...
Some examples:
Adventsam
Didn't realise the G3 is a bit of a cheat too,hmm.
So, no magic just smoke and mirrors LOL.
Yes - I think...
Some examples:
Susan G
Veteran MemberPosts: 6,445
Maybe slightly off your original intent in this post, but I got "lost" in the review with their "comparometer" and looked at various resolution samples (b&w and color), not the outdoor ones, from the OMD and the e30 (which is my current camera), though I don't know what lens they used for that test. The difference was very noticeable, even to my rather un-trained eye. Am I missing something?
Susan
http://www.pbase.com/susan_gordon
Just Having Fun
Veteran MemberPosts: 3,869
reason why EM5 images beat GH2?
In reply to Adventsam, May 15, 2012
So is that why almost every review site says the EM5 images are better?
I can't wait for the new 75mm lens too. You will have to lug around a tripod or shoot at over 1/150th of sec to get a sharp image. Meanwhile I can shoot indoors at night at 1/30th of a second with that new amazing lens.
I am with Louis. Always try to shoot at base ISO. Thankfully IBIS really helps with that!
Jman13
Senior MemberPosts: 1,424
Everyone is inferring things from pictures taken on different days with different cameras under possibly different lighting.
I, however actually own an E-M5, and a GX1 and a GH2. I have tested the E-M5 at the same settings vs the GH2 and the GX1 and in BOTH cases, when shot under constant light at the same time, with the same ISO, shutter speed and aperture, the E-M5 image is BRIGHTER or the same as the GH2 and GX1.
I took a shot of the same subject this morning after seeing this thread, at the same time with the exact same settings on both cameras (ISO 200, f/2.8, 1/15s, 45mm). When sampling the dead center of the same middle toned square (it was a calendar I shot) on the shot from each camera:
The dead center of the GX1 shot showed values in Lightroom of: 60.9, 60.4, 64.0
The E-M5 in the exact same spot? 60.5, 60.9, 64.1.
Admiring Light - http://www.admiringlight.com
Jordan Steele Photography - http://www.jordansteele.com
Adventsam
In reply to Jman13, May 15, 2012
Well, aint it funny how everything else seems to say otherwise. OMD is 2/3ev overstated, it may be worse, and in fact actually at iso1600 is the same as most things out there at iso800-1000, that's a big difference. If Oly feel they need to do this and people lap it up, good for both heh! but the facts are the facts and the comparison is made against their controlled lighting btw in a studio; they have no reason to lie, unlike Oly?
Adventsam
In reply to Susan G, May 15, 2012
Don't think so, the improvement is real over the e30.
Susan
Jogger
Veteran MemberPosts: 8,441Gear list
Just wait for DxO Mark (nt)
Yes - I think...
Some examples:
 Jogger's gear list:Jogger's gear list
Sony RX100 Sony Cyber-shot DSC-RX10 Nikon D700 Nikon Df Nikon AF-S Nikkor 70-200mm f/2.8G ED VR +4 more
Just Having Fun
From my testing it was very very close. 1/3rd EV at most..if that.
No matter what you do the blacks are much blacker with the EM5 while still retaining all the detail, which I love. I think this fools a lot of people.
Anyway YOU have an agenda and can't be trusted.
NuFonaut
Senior MemberPosts: 2,211
There have been comparison shots between GH2 and EM-5 on another M4/3 forum (am trying to find it) which showed equally bright pictures with the completely same settings. I have no reason to believe the EM-5 differs more than 1/3 EV which is neglible.
The old Panasonics were underrated in terms of Isos, the newer ones aren´t so it makes basically no difference.
What´s that noise?
From one of the Canon Forums:
'I just came back from my first holiday with the 5D II (I think my wife was there as well). '
Jman13
No, everything else that 'says' otherwise is comparison shots that were taken on different days.
Here are shots, taken about one minute apart, from the same location, on the same day, under the exact same lighting, with the same lens on each camera.
ISO 200, f/1.8, 1/100s for both images. The sample spot for the values under the histogram is the center of the box opening tab flap.
GH2, ISO 200:
E-M5, ISO 200:
ISO 1600, f/1.8, 1/800s for both cameras, same sample spot:
GH2, ISO 1600:
E-M5, ISO 1600:
