Shadow pull-up, E-M5
Started May 13, 2012 | Discussions
gollywop
Veteran MemberPosts: 5,425
May 13, 2012
While cleaning out old folders, I happened upon this shot I made when I first tested UniWB with the E-M5. I'd forgotten about it, but upon seeing the sequence of which this was a part, I realized it also provided a great test of just how well the new ACR 7.1 could deal with a large shadow pull.
Here is the original along with a PP that involved nearly a 4-stop exposure boost (3.85 EV). All the tonal alterations were done in ACR 7.1, but it did take a trip to CS6 to have NR (via Neat Image) and to be resized.
gollywop
Louis_Dobson
Forum ProPosts: 26,387
It's really good isn't it? I love it... (nt)
In reply to gollywop, May 13, 2012
Erik Johansen
Senior MemberPosts: 1,271Gear list
Very good, but.....
...the feet are killing me.....
It is never too late to give up your prejudices.
gollywop
Re: Very good, but.....
In reply to Erik Johansen, May 13, 2012
Me too.
gollywop
gollywop
Re: It's really good isn't it? I love it... (nt)
In reply to Louis_Dobson, May 13, 2012
Yes. It's hard to believe. But I'm definitely a believer.
gollywop
Spectacle99
Regular MemberPosts: 115
Re: Shadow pull-up, E-M5
Wow! That's pretty impressive.
nand
Senior MemberPosts: 1,386Gear list
Yes, but...
This is really amazing. It is also amazing, that the corrected image is time stamped 6 minutes earlier than the uncorrected dark image?
Nand.
 nand's gear list:nand's gear list
Fujifilm X100S Olympus OM-D E-M5 Fujifilm X-E1 Olympus E-M1 Olympus 12-40mm F2.8 +22 more
Martin Ocando
Senior MemberPosts: 2,561Gear list
I see clipping...
But not shadows or highlights. You need a nail clipping PRONTO!!!
Good pull example, BTW.
Me too.
gollywop
Martin Ocando
 Martin Ocando's gear list:Martin Ocando's gear list
Panasonic Lumix DMC-G5 Panasonic Lumix G 20mm F1.7 ASPH Panasonic Lumix G 14mm F2.5 ASPH Panasonic Lumix G Vario 14-42mm F3.5-5.6 ASPH OIS Panasonic Lumix G Vario 45-150mm F4-5.6 ASPH Mega OIS +6 more
Raist3d
Forum ProPosts: 32,605Gear list
Good for m4/3rds but there's
a lo of chroma and noise in there. And this is on a very resized own shot.
Raist3d/Ricardo (Photographer, software dev.)- "You are taking life too seriously if it bugs you in some way that a guy quotes himself in the .sig quote" - Ricardo
gollywop
Re: Yes, but...
In reply to nand, May 13, 2012
Yes, because, after processing and saving the corrected version, I pulled the .xmp to revert to the original RAW file so I could resize and save it as a jpeg.
You are too suspicious for your own good.
gollywop
gollywop
Re: Good for m4/3rds but there's
In reply to Raist3d, May 13, 2012
Gee, I wonder how that got there.
gollywop
Louis_Dobson
Who cares? It's a daft thing to do, but amusing it will do it.
http://www.flickr.com/photos/acam
http://thegentlemansnapper.blogspot.com
400trix
Regular MemberPosts: 145Gear list
Dude, trim your toenails...
Now I'm looking forward to the E-M5 even more. Except for the toenails.
God loves the noise just as much as the signal.
 400trix's gear list:400trix's gear list
Olympus E-300 Olympus OM-D E-M5 +1 more
grumpyolderman
Senior MemberPosts: 1,085
good pullup, I had to do that today about a dozen times, when my flash did not fire (not loaded, all manual) and it was only on a s100fs, really small sensor, introducing a lot of noise in the pull up, but resulting in useful pics:
JL
gollywop
Re: Dude, trim your toenails...
In reply to 400trix, May 13, 2012
Then I hate to be the one to break this to you, but it doesn't work without the toenails.
gollywop
gollywop
In reply to grumpyolderman, May 13, 2012
Not bad at all, but you lost the window details -- not, of course, that they are the most important element of the shot.
gollywop
Detail Man
Forum ProPosts: 14,950
Wow ! Nothing to "sneeze at". Do you like NeatImage better than ACR 7.x's Color/Luminance NR ?
I managed to get out with my (camera model shall go un-named, as it now lives in the shame of runner-up status among the cyborgs) yestreday, and was again reminded of how much better I (personally) like (along with UniWB) using B&W preview to frame shots, and simply could not manage to be able to effectively sort through the resulting (B&W) JPGs that I simultaneously record along with the RAWs to determine which of the mutliple shots that I typically take has the best focus-integrity, camera-stability, light-distribution, framing, etc. in order to determine which to RAW process. With my chosen "multiple shots of the same scene" approach, B&W is invaluable ...
Am curious as to whether (on the E-M5) using such a B&W preview/review has any disadvantages (for instance, does it modify the "blinkies", or review/playback RGBL histogram, functionality) ?
gollywop
In reply to Detail Man, May 13, 2012
Yes. It does a much better job of removing noise, and it does so without killing detail. I've just started using it. I used to use Noise Ninja, which worked quite well. But they have not stayed up with things: they still haven't produced a 64-bit version for the Mac, and as such, it will not run under CS6. I use the ACR NR facility only very lightly for chroma noise at development and save the heavy stuff, when it is needed, for PS.
But, in the silver-lining department, I think Neat Image may actually be better than Noise Ninja. So I'm glad they forced me to look into the issue once again. I got the "Pro" version of Neat Image, by the way, because it works with 16-bit (and 32-bit) color rather than being limited to 8-bit.
It works just fine. All review functionality remains intact; and both the pre- and post-shot blinkies work, properly based on the chosen WB (which, of course, is . . . ).
I will also reiterate that UniWB seems to work particularly well with this Olympus camera. It works wonderfully with my D300, but, for a reason I can't figure out, it does not work too well with my E-510. It's okay, and exposure setting is better with it than without it, but it is not as reliable as with the E-M5 and D300. I don't know if it is in the nature of the metering or the way the jpeg engine produces the histograms and blinkie info.
gollywop
Raist3d
gollywop
Raist3d
Well but that's the point. I think it does pretty good, don't disagree with that. But I like whole observations to be complete if you will.
As for caring, well, there's this thread about it, and we are replying.
