How wide are these?
Started May 12, 2012 | Discussions
Adventsam
Veteran MemberPosts: 4,983
How wide are these?
May 12, 2012
would you say?
Aleo Veuliah
Forum ProPosts: 14,455Gear list
Re: How wide are these?
In reply to Adventsam, May 13, 2012
Hmmm, wondering, 24mm ?
Is there any trick ?
Simplicity is the ultimate sophistication.
God is the tangential point between zero and infinity.
Imagination is more important than knowledge.
God always take the simplest way.
 Aleo Veuliah's gear list:Aleo Veuliah's gear list
Panasonic Lumix DMC-ZS1 Panasonic Lumix DMC-GF1 Panasonic Lumix DMC-G2 Nikon 1 V3 Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS +3 more
Adventsam
In reply to Aleo Veuliah, May 13, 2012
Much better than 24mm Aleo
No trick, its real OOC, am impressed, we are rectlinear 10mm equiv FOV prime but only available on GH2, LOL.
Hen3ry
Senior MemberPosts: 7,850Gear list
Who cares? Irrelevant question
 Hen3ry's gear list:Hen3ry's gear list
Panasonic Lumix DMC-G6 Olympus M.Zuiko Digital ED 9-18mm 1:4.0-5.6 Panasonic Lumix G 14mm F2.5 ASPH Panasonic Lumix G Vario 100-300mm F4-5.6 OIS Olympus M.Zuiko Digital 45mm 1:1.8 +5 more
Ray Sachs
Senior MemberPosts: 8,426Gear list
The lens isn't wide enough (although with nothing in the foreground its very difficult to say) but the aspect ratio is way too wide. I'm sure you're opinion is different because you must continue to cling to the limited number of features in which the GH2 still rules the roost. When I first got an LX5, I shot everything in 16-9 for a while but quickly grew to hate it - now I never use it. Just 3:2 or 4:3 for me, depending, sometimes cropped down to square after the fact. Yes, its nice that the GH2 can shoot in 3:2 without reducing the pixel count, and no the OMD can't. But I've been shooting in 3:2 on cameras that weren't made for it for quite a while and its never bothered me in the least in actual use. If I didn't, I'd probably just crop off the tops and bottoms to fit, since 3:2 works better with my favorite print sizes...
-Ray
http://www.flickr.com/photos/20889767@N05/collections/72157626204295198/
Adventsam
Re: Who cares? Irrelevant question
In reply to Hen3ry, May 13, 2012
I care Grandad! You some sort of camera snob?
Cheers Sam
Adventsam
In reply to Ray Sachs, May 13, 2012
Ray, this wasnt meant to be a gh2 vs, just an innocent feedback question, but I get an old geazer and some lecture, I dont need it, enjoy your Omd.
Louis_Dobson
Forum ProPosts: 26,387
Not too keen on the crop, look APS-C or worse. Where have the top and bottom gone? Otherwise nice. 24mm efl (12mm MFT) I'd guess, could be 28.
Adventsam wrote:
would you say?
papillon_65
Forum ProPosts: 15,732Gear list
Not as wide as these ;)
Try doing that with a GH2 SOOC
It's a known fact that where there's tea there's hope.
Tony
http://the-random-photographer.blogspot.com/
 papillon_65's gear list:papillon_65's gear list
Canon PowerShot G1 X Sigma DP1 Merrill Sigma DP2 Merrill Panasonic Lumix DMC-FZ200 Canon EOS 5D Mark II +4 more
Aleo Veuliah
Re: Not as wide as these ;)
In reply to papillon_65, May 13, 2012
Ahah, indeed, what lens is ?
Detail Man
Forum ProPosts: 14,837
Re: How wide are these ?
Adventsam wrote:
would you say?
The Maker Notes section of the image-file meta-data have been stripped-off , but if we assume that you used your LGV 14-140mm at 14mm, and that you have not cropped the width or the height from the 16:9 aspect-ratio recording mode (in order to ensure the widest Angle of View, and the smallest 35mm equivalent Focal Length), the calculations are fairly straightforward ones.
As you have pointed out, Panasonic states the GH2 image-sensor pixel-pitch as being 3.8 Microns.
The GH2's 16:9 aspect-ratio is 4976 x 2800 pixels (5709.69 pixels diagonal) which equals a 21.697mm diagonal (which will generate the highest AOV, and the lowest 35mm equivalent diagonally-referenced Focal Length) - which it would surely seem that you are seeking to claim ...
AOV = ( 2 ) x ( Arctangent ( ( 21.697mm ) / ( ( 2 ) x ( 14mm ) ) ) ) = 75.543 Degrees
35mm Eq. FL = ( 43.267mm ) / ( ( 2 ) x ( Tangent ( ( 75.543 ) / ( 2 ) ) ) ) = 27.918mm
Wow, that's 81.596 Microns "wider" than a 28mm (35mm equivalent) Focal Length. Good show.
This is the same as the 35mm equiv. FL of the E-M5 in 4:3 aspect-ratio mode with a 14mm lens ...
DM ...
Detail Man
In reply to Detail Man, May 13, 2012
Whatever the Focal Length of your lens, Sam, the diagonally referenced 35mm equivalent Focal Length will not be any different with the GH2 in 16:9 aspect-ratio mode that it would be on the E-M5 in 4:3 aspect-ratio mode. So, you are talking about the avaliablilty of lenses for the E-M5 ?
Ray Sachs
My response wasn't to knock the GH2 either, just your rather incessant fanboyism. If the "only available in the GH2" wasn't intended to be that, then apologies for the very short "lecture". But there's an element of the boy who cried wolf at play here too...
-Ray
Big Ga
Forum ProPosts: 16,198
I'd be surprised if there wasn't an error in at least one of the assumptions above.
papillon_65
It's that abomination known as the Sony 16mm F2.8 used in Panorama sweep mode in portrait orientation on my toy 5n ;).
Tony
Adventsam
11mm m43, the quip about gh2 was a joke:-) anyway its real > 20mm in 16:9, focus upto 6 inch but feels closer
Big Ga
So where does the "rectlinear 10mm equiv FOV" come in ??
duartix
Veteran MemberPosts: 3,422Gear list
It's been well over 20ยบ for a week now. SOOCs are in the closet already. Not that I liked wearing them anyway, I'm a RAW walker myself.
Give me a week or two, I'll get really really wide by then...
Duarte Bruno
 duartix's gear list:duartix's gear list
Fujifilm FinePix F40fd Olympus PEN E-P1 Panasonic Lumix DMC-GH2 Olympus M.Zuiko Digital ED 14-42mm 1:3.5-5.6 Panasonic Lumix G Vario 14-42mm F3.5-5.6 ASPH OIS +4 more
Adventsam
Sony 16mm is a dog!
Adventsam
In reply to Big Ga, May 13, 2012
No errors, a cracking lens! 10mm corner to corner sharp, yes!
