X Pro1 dust reduction system?
Started May 12, 2012 | Discussions
firefox23508
Contributing MemberPosts: 753
May 12, 2012
I am toying with the idea of getting this camera but a search of this site yields no results regarding sensor shake or other type of dust reduction ability. Does this camera even have that?
redzob
Regular MemberPosts: 141Gear list
Re: X Pro1 dust reduction system?
In reply to firefox23508, May 12, 2012
yes it does. Mine often does a sensor clean after changing lenses and sometimes as you switch it on/off....
 redzob's gear list:redzob's gear list
Sony RX100 Fujifilm X100S Fujifilm X-Pro1 Fujifilm XF 35mm F1.4 R Fujifilm XF 60mm F2.4 R Macro +7 more
johnbandry
Regular MemberPosts: 498Gear list
Yes. Options
You can set it to clean the sensor whenever you turn the camera on, or whenever you turn the camera off. You can also select sensor cleaning from the menu at any time.
John Bandry
 johnbandry's gear list:johnbandry's gear list
Canon EOS 5D Fujifilm X-Pro1 Canon TS-E 24mm f/3.5L II Fujifilm XF 18mm F2 R Fujifilm XF 35mm F1.4 R +3 more
Chris Dodkin
Veteran MemberPosts: 5,872Gear list
And - it's very effective
In reply to johnbandry, May 13, 2012
seems to repel dust better than my 5D2
http://www.dodkin.com
Chris@1D-Images.com
Mac Pro/MacBook Pro/iPods/iPhones/iPad
 Chris Dodkin's gear list:Chris Dodkin's gear list
Fujifilm FinePix X100 Canon EOS-1D Canon EOS-1D Mark II Canon EOS 5D Mark II Canon EOS 30D +34 more
vrot01
Regular MemberPosts: 278Gear list
Re: And - it's very effective
In reply to Chris Dodkin, May 13, 2012
i agree... so far it is much more dust resistent than my 5d2...
 vrot01's gear list:vrot01's gear list
Canon PowerShot S30 Fujifilm FinePix F30 Zoom Fujifilm FinePix F70EXR Fujifilm FinePix F660EXR Canon EOS 5D Mark II +20 more
PG Thomas
Contributing MemberPosts: 514Gear list
In reply to vrot01, May 13, 2012
I've had sticky dust, but a quick blow from an compressed air cylinder shifted everything. I use 'Green Clean' but any good make designed for photographic use should be OK.
IMPORTANT
Always keep these air cylinders upright and still - And bring the camera to the cylinder not the other way round.
Also try not to use them 'full blast' unless you have to.
Many cylinders use liquid propellants which can foul the sensor if you shake the can or misuse them.
Finally always test on a clean UV filter to check that only clean air is coming out before pointing it at the sensor!....
Having the sensor in the X-Pro1 near the lens mount makes life easier.
Pete
 PG Thomas's gear list:PG Thomas's gear list
Fujifilm X-T1 Fujifilm XF 56mm F1.2 R
