Nex-7: Never noticed this before
Started May 11, 2012 | Discussions
eths
Contributing MemberPosts: 768Gear list
May 11, 2012
While going through some pictures from my last vacation and fooling around with the 4.1 RC2 (Mac) version of LightRoom, I noticed vertical stripes in the sky above a cross in the B/W version of a picture. In the (almost totally) unprocessed original the stripes are not immediately visible.
Here two 1:1 crops illustrating the effect:
It looks like the Nex-7 sensor has some minor weaknesses after all.
 eths's gear list:eths's gear list
Sony Alpha NEX-7 Nikon D600 Sony Alpha 7R Nikon AF-S Nikkor 16-35mm f/4G ED VR Sony E 16mm F2.8 Pancake +18 more
headofdestiny
Veteran MemberPosts: 9,222Gear list
Re: Nex-7: Never noticed this before
In reply to eths, May 11, 2012
I don't believe that this is a sensor issue, but, rather, because you are using the first curtain electronic shutter at 1/4000. That's usually the cause of this phenomena. The manual mentions that issues can come up when using high shutter speeds and the electronic shutter. You should be fine if you set "FRONT CURTAIN SHUTTER" to OFF.
eths
In reply to headofdestiny, May 11, 2012
Good point - This could easily be the explanation.
Sometimes I have it on and sometimes I don't. I have no idea if it was on or off at the time.
ulfie
Veteran MemberPosts: 3,153
Looks like subtle images of the Rapture above the crucifix.
V1V1D
Contributing MemberPosts: 655Gear list
In reply to headofdestiny, May 12, 2012
Would this apply to fast shutter speeds only? I never really fully understood the front curtain setting. Is it best to toggle at different speeds or is on or off the best all around setting?
 V1V1D's gear list:V1V1D's gear list
Sony Alpha NEX-7 Sony E 18-55mm F3.5-5.6 OSS Sony E 16mm F2.8 Pancake Sony E 50mm F1.8 OSS Sony E 55-210mm F4.5-6.3 OSS +2 more
headofdestiny
In reply to V1V1D, May 12, 2012
This happens only at higher shutter speeds, but I don't know where the cutoff is, and the conditions vary. I never turn of my front curtain shutter, and I've never had this problem, myself.
DezM
Forum ProPosts: 33,725
Same here
Dez
http://dezsantana.com
El Matadurr
Senior MemberPosts: 4,975Gear list
In reply to DezM, May 12, 2012
Ditto to that, since it is only visible in certain situations (sky on a bright day usually), I just always leave it on and don't worry about it. If I have some critical shot that I need to save, the blur brush in LR can get rid of the line. Though I have never had it show up, yet.
http://matthewdurrphotography.wordpress.com
Same here
Dez
 El Matadurr's gear list:El Matadurr's gear list
Sony Alpha NEX-7 Carl Zeiss Touit 1.8/32
flint-hill
Senior MemberPosts: 1,215
Do you recall the lens and approximate aperture?
In reply to eths, May 12, 2012
This is an interesting observation. And the effect has a familiar look to me though I can't recall the context in which I've seen it. It will come to me, probably.
eths
Re: Do you recall the lens and approximate aperture?
In reply to flint-hill, May 12, 2012
Sorry, I don't.
But I'll risk a wild guess based on the RAW file: Nikon Nikkor 28mm/f2.8 AIS at f4.
eths
The only time I've seen problems in the past was with the Novoflex 600mm/f8.
One side of the picture is (sometimes) darker than the other if using the electronic first shutter with this long lens.
nzmacro
Veteran MemberPosts: 8,734Gear list
Very interesting.
I have a few shots of exactly that blue with birds shots and about the same ratio. I'll convert a few and let you know.
All the best, very interesting.
Danny.
http://www.birdsinaction.com
http://www.macrophotos.com/g2macro
Worry about the image that comes out of the box, rather than the box itself.
nzmacro
Different results
I have first curtain set and lens at F/4.5. MF lens though, so might not be comparable.
From RAW. In LR4 and darkened the blue slightly, cropped around 100%, then converted in LR4 to B/W with the high contrast pre-set.
With those setting I didn't get any bands. I wonder if its the conversion or other settings. Interesting for sure. Would love to know what causes that.
All the best.
Danny.
headofdestiny
Re: Different results
In reply to nzmacro, May 12, 2012
All the best.
Danny.
I believe it is the 1/4000 shutter speed that is the cause with the OP's pic.
nzmacro
Ahh of course. Samples at 1/4000th
In reply to headofdestiny, May 13, 2012
Yes of course, sorry about that. took another look and ......
So same LR4 settings and these are higher shutter speeds. 1/3200th and 1/4000th. Fairly heavy crops.
All the best.
Danny.
eths
Re: Ahh of course. Samples at 1/4000th
In reply to nzmacro, May 13, 2012
Nice pics!
Interesting, that you don't have any vertical "bleeding". I've been looking through my library, and haven't found any further examples either, yet. It appears that this weakness needs exactly the right combination of factors to become recognizable.
