O-ring Trick Helps Keep Sensor Clean!
Started May 9, 2012 | Discussions
Jerry Canon
Contributing MemberPosts: 586Gear list
May 9, 2012
I stumbled on this simple trick that greatly improves sensor hygiene by accident recently. Actually, I was trying to help the "lens-crawl" issue with my 18-200 by placing this o-ring in the groove between the lens's zooming ring and lens barrel, but it really didn't turn out to work that well to stop the crawl.
So, just for the heck of it, I rolled it on back to rest in the groove between the lens and body. Since then, I've had virtually zero issues with sensor dust. I think a lot of stuff sneaks in thru this little crack. When changing lenses, I just roll it back onto the lens flange on the body. Sorry I don't have the specs on the o-ring itself but it's probably pretty flexible and forgiving.
Jerry
 Jerry Canon's gear list:Jerry Canon's gear list
Sony E 50mm F1.8 OSS
wll
wll
Veteran MemberPosts: 4,820
Re: O-ring Trick Helps Keep Sensor Clean!
In reply to Jerry Canon, May 9, 2012
it not only may cut out micro dust, but it looks cool ;- )
wll
TeaAholic
Regular MemberPosts: 138
So basically a rubber band to stop dust entering between the mount and lens. Great find. I guess you just can't get a complete dust seal with the metal mount touching the metal lens.
DezM
Forum ProPosts: 33,724
It looks good but dust can collect on the O-ring as well, no?
Dez
http://dezsantana.com
FMPhoto
Senior MemberPosts: 1,944Gear list
In reply to DezM, May 9, 2012
Telling us the size of the Oring or where you got the particular o ring would help too
Robb
http://www.robbquinnimaging.com
'Dancing through life......those who don't try, never look foolish'
NPS Member
NAPP/WPPI/NANPA Member
WSSA Member #76
 FMPhoto's gear list:FMPhoto's gear list
Sony Alpha 7R Nikon 1 Nikkor VR 10-30mm f/3.5-5.6
wkhc168
Regular MemberPosts: 240
Where do you get the o-ring and what is the size?
William C.
http://www.flickr.com/photos/wkhc/
richg101
Regular MemberPosts: 226
Dez
I'm freezing to death in Siberia. Shall I make a fire to keep warm? Nah, I don't want my clothes to smell of smoke.. I'll just curl up and die.
El Matadurr
Senior MemberPosts: 4,969Gear list
In reply to richg101, May 9, 2012
richg101 wrote:
Dez
....umm...what?
 El Matadurr's gear list:El Matadurr's gear list
Sony Alpha NEX-7 Carl Zeiss Touit 1.8/32
MBRuss
Regular MemberPosts: 266
richg101 wrote:
Dez
I think his point was more that if dust collects on the o-ring, then it's likely to end up on the sensor anyway when you move the o-ring and unscrew the lens...
Jerry Canon
In reply to MBRuss, May 9, 2012
MBRuss wrote:
richg101 wrote:
Dez
Well, I suppose it could, but it could collect on the area anyway...Huh? It's no more prone to introduce dust into the camera than if it wasn't there in the first place.
I've found that I actually have to roll the o-ring away (out of the groove) before I take the lens off. It creates a friction that won't let the lens turn otherwise.
Jerry
Jerry Canon
In reply to wkhc168, May 9, 2012
William C.
Actually, this particular o-ring came out of a MSR water filter maintainence kit and just happened to work for the purpose. Since o-rings are elastic, I would assume that you could probably pick up an assorted pack at Lowe's or Home Depot and find a couple in the mix that would work.
Jerry
Morrie
Regular MemberPosts: 111
O-rings are not as elastic as you would think. There isn't much tolerance between being too tight to get on and being too loose to be of use. I doubt, in a random assortment of o-rings, there would be one suitable.
This is an interesting idea though. Is there any evidence that this is where the dust actually comes in?
Jerry Canon
In reply to Morrie, May 9, 2012
Good question.. I would assume that there's a good chance since there's got to be some gap there, and I'm wondering if zoom lenses whose lenght change when zooming don't suck in some outside air right thru this micro-gap. I just know that since using the o-ring I hardly see any dust issues anymore.
Jerry
i3c
i3c
Regular MemberPosts: 231
My canon 24-105 has a rubber gasket in the lens mount area. Sounds like the o-ring serves a similar purpose.
For those interested you can buy o-rings on amazon (us) seller oringsusa has many different sizes & materials.
Gary Eaves
Regular MemberPosts: 435Gear list
In reply to i3c, May 9, 2012
Most auto parts stores have o-rings in a multitude of sizes. You should be able to browse and find the just the right size.
Good call!
 Gary Eaves's gear list:Gary Eaves's gear list
Sony Alpha DSLR-A850 Sony SLT-A55 Sony SLT-A77 Sony DT 18-55mm F3.5-5.6 SAM Sony 50mm F1.4 +9 more
Tom Hoots
Veteran MemberPosts: 5,740
Could you give us a diameter?
I think this is a great idea -- I got a chunk of dust that showed up at f/8 just the other day -- it wasn't in the shots I took in the morning, but it was there in the afternoon. So, it definitely got in there some time during the day.
At the least, could you measure the diameter of your O-ring? I'm really not sure how much stretch I should expect when I go o-ring hunting, very soon.
Thanks!
Tom Hoots
http://thoots.zenfolio.com
http://www.dpreview.com/galleries/4330317199/albums
Jerry Canon
Re: Could you give us a diameter?
In reply to Tom Hoots, May 9, 2012
Thanks!
Tom Hoots
James Sherman
Senior MemberPosts: 2,282Gear list
In reply to Tom Hoots, May 10, 2012
Take a lens along to your local hardware store and try some out for fit. My local Ace would be happy to help. The lens base is the same size as the mount & as long as the o-ring is stretched a bit it should be fine.
 James Sherman's gear list:James Sherman's gear list
Sony Alpha NEX-6 Sony Alpha 7R Sony E 55-210mm F4.5-6.3 OSS Sony E 10-18mm F4 OSS Sony FE 24-70mm F4 OSS
JohnK
Veteran MemberPosts: 6,396Gear list
O-ring Trick keeps OVF on camera
In reply to Jerry Canon, May 10, 2012
Hi Jerry, I like your use of O-ring, good to know. I too use an O-ring on my NEX. It keeps my OVF from falling off. After it slipped off another camera and I had to pay $100 for repair I tried various "safety" solutions before hitting on the O-ring, which works great!
JohnK
Take a picture, it'll last longer.
dannytang
Regular MemberPosts: 119Gear list
I just measured the outer diameter of my SEL50F18 and it's about 61.5mm and the groove is about 60mm.
 dannytang's gear list:dannytang's gear list
Nikon D600 Nikon AF-S Nikkor 24-70mm f/2.8G ED Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II Nikon AF-S Nikkor 50mm f/1.8G
