Tripod Mount for Panasonic 100-300 lens
Started May 7, 2012 | Discussions
bgalb
bgalb Senior Member • Posts: 1,694
Well, I finally bit the bullet and ordered this tripod mount for my panny 100-300 lens.
http://www.roesch-feinmechanik.de/29701.html
It cost just under $100 us including shipping. I have noticed that my GH2 (and E-M5) vibrate at the slightest touch when attached to even a fairly heavy tripod via the camera body tripod socket.
I have been using the manual remote shutter release when using the tripod. I am hoping that this mount will provide a little more stability by distributing the fore-aft weight better on the tripod head. If not, then that is $100 down the tubes.
 bgalb's gear list:bgalb's gear list
Olympus OM-D E-M5 Olympus E-M1 Olympus Zuiko Digital ED 12-60mm 1:2.8-4.0 SWD Olympus Zuiko Digital ED 50-200mm 1:2.8-3.5 SWD Olympus Zuiko Digital 1.4x Teleconverter EC-14 +5 more
Panasonic Lumix DMC-GH2
axlotl Senior Member • Posts: 1,497
Re: Tripod Mount for Panasonic 100-300 lens
Thanks for posting that, good find. No doubt we will hear in due course if it is successful. My solution has been to put the GH2/100-300 combo with OIS ON to steady the EVF image, on a monopod, or even a lightweight tripod, attached to the camera body tripod socket then hold the camera and lens as if it were not on a support. The thinking is this will dampen those troublesome vibrations. It appears to work OK. It will be interesting to discover if the new lens collar tripod mount works better.
bgalb
bgalb OP Senior Member • Posts: 1,694
I will be surprised if it works any better than your method. I also wanted this mount so I could balance the weight better for use on my fluid head tripod (this is just my rationalization for spending the money )
Gary2010
Gary2010 Contributing Member • Posts: 526
I am trying to order that same mount. I sent him an email. Is that how you contacted them? Did they take paypal?
thanks
 Gary2010's gear list:Gary2010's gear list
Sony Cyber-shot DSC-RX100 III Olympus Tough TG-4 Olympus E-M1 Pentax K-3 Olympus OM-D E-M10 +15 more
bgalb
Yes, I just used the email link on the site. He replied with price info. I replied back and told him I wanted to order the tripod mount and gave him my mailing address. He sent me an invoice that had his paypal email and price and shipping (total cost 74 euros). I paid thru paypal. He will now mail the mount to me.
Anders W Forum Pro • Posts: 21,465
Thanks for the heads up. I didn't know that a tailor-made mount existed (and since this is labeled "new", there probably wasn't any until recently). I was only aware of somewhat clumsy generic versions that would fit any lens of roughly the same size.
Please report back when you have got it and have tried it out. Like you, I have noticed visibile vibration at the slightest touch with the 100-300 fully extendeded when mounted on a pretty stable tripod via the camera body.
Panasonic Lumix DMC-G1 Olympus OM-D E-M5 Olympus E-M1 Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS Panasonic Lumix G Vario 7-14mm F4 ASPH +28 more
Gary2010
A friend of mine bought this mount on eBay.
He really likes it. I will be getting mine too.
Thanks for the info.
coaltrain Regular Member • Posts: 265
I just bought one of these tripod collars for the 100-300. I was quite lucky to find one on eBay at a decent discount.
The mount is a fine piece of equipment - finely crafted in aluminum and very light. After first trying it out, I am even more impressed by the workmanship and thought put into this. With the included instructions, you loosen the thumb screw, and need to line up a mark on the collar with the red dot on the lens in order to slide it on. The thumb screw only loosens a couple turns and won,t come out. I really like this feature as the collar will never come off the lens accidentally.
Once mounted on the lens, there are 2 indicator marks for landscape and portrait positions. You loosen the thumbscrew and the lens becomes just loose enough for the lens to rotate. Somehow, the lens stays perfectly aligned in the collar when twisting it with the collar loose. Then, there are 2 windows that allow use of the OIS switch in either position.
I am so impressed with this collar that I would,t have any problem with paying full price to order it new. The collar, when mounted, looks and acts like it was a factory included option.
 coaltrain's gear list:coaltrain's gear list
Panasonic Lumix DMC-LX5 Pentax K-30 Pentax K-5 IIs Pentax smc DA 10-17mm F3.5-4.5 ED (IF) Fisheye Pentax smc DA 12-24mm F4.0 ED AL (IF) +7 more
Gary2010
And here he is.
Hi Stan,
I am trying to get mine ordered.
You should post a pic of the lens and GH2 on the tripod. It is a beautiful thing.
I'm working on my tablet right now, but I,ll give it a try.
Edit to add - I just Dan,t figure out how to copy/paste on this thing - I'll post those pics here tomorrow night when I am home.
Did someone sell a single copy only? Or is there more of it from the same source? If yes, could you please post a link?
I bought from a private party that was selling his 100-300 lens. I was looking at his auction for the lens, and in the description he mentioned that he had another auction going for the collar - found that and it was listed as a 'buy it now - I didn't hesitate to pull the trigger!
I can't believe I actually found one used on eBay!
Congrats! Just a pity there wasn't more of it!
Judging from your description, this really seems like a nicely made piece of equipment. But what about the effect? Does it really help making the camera-lens combo less vibration prone when mounted on a reasonably sturdy tripod?
Aleo Veuliah
Aleo Veuliah MOD Forum Pro • Posts: 14,628
Looks good and useful, but not cheap
Simplicity is the ultimate sophistication.
God is the tangential point between zero and infinity.
Imagination is more important than knowledge.
God always take the simplest way.
 Aleo Veuliah's gear list:Aleo Veuliah's gear list
Panasonic Lumix DMC-ZS1 Panasonic Lumix DMC-FZ1000 Panasonic Lumix DMC-GF1 Panasonic Lumix DMC-G2 Panasonic Lumix DMC-GH4 +4 more
While I haven't used the mount much yet, just the feeling of proper balance when mounted on a tripod is a huge thing to me. It should absolutely stabilize the camera/lens combo much better than mounting the body to the tripod.
Now, as promised, here are some pics. Please excuse the exposure on a couple of the shots - I was in a hurry and just snapped a couple with my K-5 - afterward I found that I somehow had switched the metering lever from center weighted to fulmatrixix - hence the underexposed black subject.
Gary2010
I ordered mine today. They are out of stock. Their stock is at the anodizer's. They said they would ship by the 15th and that it takes 5 days to get to the US. Thanks for posting the pics Stan.
bgalb
My thanks, also, for the photos. Glad I ordered before posting this thread!
rrr_hhh Veteran Member • Posts: 6,019
I got one last year in November or so. It is really well made and now the lens is really sturdy when on a tripod. However it didn't solve my problems with this lens. I'm getting subpar IQ, when shooting at the long end and focusing at far objects. In my case the problem wasn't instability, however the tripod collar helps a lot when focusing the lens. Also it makes a much sturdier combo especially with the tiny G3.
rrr_hhh
 rrr_hhh's gear list:rrr_hhh's gear list
Olympus OM-D E-M5 Canon EOS 6D Sony Alpha 7R Olympus E-M5 II Sony Alpha 7R II +4 more
Anders,
They don't sell through Ebay (I inquired about it at the time).
Just follow the link on the first mail of this thread ( http://www.roesch-feinmechanik.de/29701.html )
You will find their Email under the Kontakt information (link frame).
I just sent them an Email, asking for price and delivery conditions. They answered me the day after, with very clear information as to how to proceed. After I ordered one, they gave me the information needed to pay through Paypal.
I issued my first mail to them on the 1st of December and the tripod collar was delivered here on the 7th (just checked in my archives).
The tripod as already written by privious posters is extremely well made. Pure German mechanic skills and care. The whole lens and body combo is much sturdier. Without the collar, as soon as I touched the focusing ring, the image would jump in the VF. Now it is perfectly steady. Also the whole combo is much better balanced and I have no fear concerning the fact that the heavy lens could end up wearing out the mount of my G3.
The only reason I'm unhappy now is that I know for sure that the softness I'm getting in pictures isn't due to user error, neither to camera vibration, but to the fact that this is a bad copy of the lens.
rrr_hhh
Bob Tullis
Bob Tullis Forum Pro • Posts: 31,018
I was lurking, as I'd like to acquire the 100-300. When reading the above, I just wondered if you're finding this while using a filter (such as 'protective')? I suspect the findings are w/o a filter, but had to ask.
...Bob, NYC
http://www.bobtullis.com
"Well, sometimes the magic works. . . Sometimes, it doesn't." - Little Big Man
 Bob Tullis's gear list:Bob Tullis's gear list
Sony Alpha 7S Sony Alpha 7R II Voigtlander 28mm F2 Ultron Sony RX1R II Sony Alpha 7 II +15 more
