Anyone with experience with Canon to MFT lens adapter
Started May 7, 2012 | Discussions
Juan Trujillo
Regular MemberPosts: 486
May 7, 2012
Coming from a Canon DSLR to OMD I want to give a try to some Canon lenses I have.
I've found this one that looks good because comes with aperture control (diaphragm on the adapter):
http://www.bhphotovideo.com/c/product/811146-REG/Bower_ABAM43EOS_ABAM43EOS_Micro_4_3_Camera.html
Mike Kobal talks well about it at http://www.mikekobal.com/blog/?p=2003 but menctions vignetting on zooms.
Has anyone experience adapting Canon lenses to MFT?
berni29
Senior MemberPosts: 1,256Gear list
Re: Anyone with experience with Canon to MFT lens adapter
In reply to Juan Trujillo, May 7, 2012
Hi
The adapter I use is far simpler and has a pin to work the aperture stop down mechanism on the Canon lens, which is a 50mm f1.8 SC
Berni29
OMD, GH1 + Pana 20mm & 14-45mm (prev E30, E510, E1)
 berni29's gear list:berni29's gear list
Olympus OM-D E-M5 Panasonic Lumix DMC-GM1 Olympus Zuiko Digital ED 50mm 1:2.0 Macro Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS Panasonic Lumix G 20mm F1.7 ASPH +3 more
Boris
Veteran MemberPosts: 9,254Gear list
I use a cheap fotodiox Canon to m4/3...no aperture control though but not a big deal since I shoot wide open mostly. If you don't wish to shoot wide open...while your lens is on a canon body pick your f-stop, push and hold the DOF button and remove the lens...the f-stop will remain set on the lens.
Boris
Panasonic GH2 w/Canon 135mm f2L at f2.5
 Boris's gear list:Boris's gear list
Ricoh GR Digital IV Sigma DP2 Merrill Ricoh GR Canon EOS-1Ds Mark II Canon EOS 5D Mark II +40 more
Diane B
Forum ProPosts: 20,475
In reply to Boris, May 7, 2012
This is the simplest for EOS lenses. The second post refers to FD lenses.
I would go the cheapest route until you see if you really want to use EOS lenses on m4/3. I don't except for VERY occasional use of my 45 T/S or Tamron 90/2.8 macro--and I mean VERY occasional use. My EOS adapter was around $30 AIR. The ones that are able to deal with aperture changes are very pricey.
Diane
Diane B
http://www.pbase.com/picnic
http://www.flickr.com/photos/38647240@N00/
Bob Meyer
Veteran MemberPosts: 5,332Gear list
I haven't used one, but there were some posts about it a while back. The diaphragm really isn't in the right position to do it's job, and IIRC, if it's stopped down very far it starts to cause vignetting. Maybe the new improved search function will find those old threads.
Bokeh is the aesthetic quality of the blur in out-of-focus areas of an image, or the way the lens renders out-of-focus points of light. Bokeh is not the same as depth of field (DOF).
 Bob Meyer's gear list:Bob Meyer's gear list
Panasonic Lumix DMC-GH3 Panasonic Lumix DMC-GX7 Panasonic Lumix G Vario 7-14mm F4 ASPH Panasonic Lumix G 20mm F1.7 ASPH Panasonic Lumix G Vario 100-300mm F4-5.6 OIS +12 more
Juan Trujillo
In reply to Juan Trujillo, May 8, 2012
Thank you all for your suggestions. Boris, impressive image.
I found a relatively cheap $49 adapter with aperture and took the risk. I hope in the worst case to be able to use it fully open.
Oscar Torres
Regular MemberPosts: 277
I've got one of the cheapest, without diaphragm and works quite well, the problem is when, under strong light, you need to stop down and you cant.
Juan Trujillo
In reply to Oscar Torres, May 8, 2012
See the trick above from Boris, it works alhtough you willl have a "fixed" aperture , at least you can decide which one. (unless you carry a Canon camera
REgards
pcake
Contributing MemberPosts: 692Gear list
i use really cheap and simple adapters, which works 'cause the lenses i use have aperture rings.
 pcake's gear list:pcake's gear list
Panasonic Lumix DMC-LF1 Olympus PEN E-PM2
Boris
Thank you Juan the 135f2 is the easiest one to MF out of all the Canon's I have.
Here is a itty bitty look at the iris adapter.
Boris
http://public.fotki.com/borysd/
RoyGBiv
Senior MemberPosts: 1,956
Thanks for that!
In reply to Boris, May 8, 2012
Boris
Ahh! That's what I wanted! Thanks for that, Boris.
'I have no responsibilities here whatsoever'
