Yellow Cast - how do I remove?
Started May 5, 2012 | Discussions
Andy1970
New MemberPosts: 17
May 5, 2012
I wonder if one of you photoshop masters would please assist me with this? I have a few photos like this one that all have a very yellow cast to them. They are over 30 years old, so not sure if the prints were originally like this, or if they have faded in time. I guess much of the colour information has been lost, but I'd like to recover as much as possible. I got a much improved result, by adjusting the curves, using the black point of the mothers hair, the white point from clothing, and the grey from the bed frame..... but its still not great...
What method would you use to tackle this? Would really appreciate some help.
Howard Moftich
Veteran MemberPosts: 5,622
Re: Yellow Cast - how do I remove?
In reply to Andy1970, May 5, 2012
leroyvanhee
Senior MemberPosts: 1,810
Sometimes it's better to remove all the color...
Andy1970 wrote:
WineO
Veteran MemberPosts: 4,310
The image is very low resolution but if you have Photoshop go the Adjustment Layer -- Levels and in each RGB channel move the left and right sliders to where the histogram starts. You will also have to lighten the image as the exposure is way off.
Hope this helps
Claude
asoftwind
Veteran MemberPosts: 4,221
In reply to WineO, May 5, 2012
Claude
Howard Moftich
deleted post
Howard Moftich
In reply to Howard Moftich, May 5, 2012
still not great but Curves in Auto mode and then a touch of Levels.
Prstl2
Prstl2 MOD
Senior MemberPosts: 1,384
My effort....
Paul
joey_B
Veteran MemberPosts: 3,080
a quickie, done in Lab mode, but I guess you'll get better results colorizing this picture. The colors have all gone brownish...
joey_B
In reply to joey_B, May 5, 2012
now in RGB mode...
benross
Contributing MemberPosts: 827
ThumbDog
Regular MemberPosts: 110
Hi,
My go using CaptureNX.
1. Curves on each channel
2. LCH - upped the Master Lightnesss and moved the Hue line slightly up
3. Noise Reduction - entire image
4. Neutral Control Pont on the bed frame
5. Various Colour Control points to saturate certain parts of image
6. Noise Reduction - selected parts of image - mostly on skin
Cheers
RetiredInFlorida
Senior MemberPosts: 1,303
PSCS5
Copy - Shadow/Highlight
Stamp - Auto Color
Stamp - Shadow/Highlight
Stamp - Topaz DeNoise - kept as sharp as possible.
Stamp - DeSpeckle - opacity %15
Selective Colors - Reds -black, Yellows -blacks
New Selective Colors - worked Neutrals , Whites
Flatten
a whole lot of Masking in Hue/Sat: 1 for Whites. 1 for Blues. 1 for Red spots on Whites.
Patch Healing Tool for specks
Flatten
Painted Skin on a New Layer to remove the darkness
Flattened
Selective Colors for each color
Patch healing Tool - Faces Again
Flatten
Match Color to pump up the colors
Mike
Babine
Veteran MemberPosts: 5,290
Started with white/gray/black droppers in curves then numerous Average blur layers due to the multi-casts. In each case, added back with masks. Painting on layers in colour mode and Chip's PWL added colour and contrast. I then experimented with gradient overlay and texture layers in various blend modes and again, added each in with masks. To age and blend the noise, pattern layers in soft light.
Cheers.
Gary
http://forums.dpreview.com/Galleries/8298604696/photos
http://www.pbase.com/pictek
Do not argue with an idiot. He will drag you down to his level and beat you with experience.
Andy1970
New MemberPosts: 17
Wow! I'm amazed with how much detail you guys have managed to extract from the photo. I've got a bit closer to your efforts, but still can't get the blue in the shawl to come out. I just realised I uploaded a very low res version of the pic.. I've attached a better one. Thank you very much to everyone that has given me some help. I keep learning, but finding this one quite hard.
Andy1970
New MemberPosts: 17
Sorry, that last post is the low quality and the high quality scan, rather than my attempt at fixing it
Allen Gerdes
Veteran MemberPosts: 5,117
In reply to Babine, May 5, 2012
Well Gary, you set the bar so high, that I would guess this thread is now done. Excellent work. I thought I had gotten good results until I saw yours.
Regards...Allen
mikes
Senior MemberPosts: 2,877
Yellow Cast removed
Done with Corel
Only when you can criticize yourself, should you criticize others. Mikes.
RetiredInFlorida
Re: Yellow Cast removed
In reply to mikes, May 5, 2012
nice work on the arm and skin tones Mikes.
looks like a whole lot of painting going on. lol
Mike
pechio
Regular MemberPosts: 210
Still requires some work (like more de-noise, brightness...)
