Why no more ISO 100?
Started May 4, 2012 | Discussions
ulfie
Veteran MemberPosts: 3,152
May 4, 2012
Several m4/3's and smaller sensor manufacturers no longer have cameras with a base ISO of 100 or even less. (Heck, my teeny LX3 has 80!) It's usually 200 or 160. Why is this?
Panasonic Lumix DMC-LX3
JosephScha
Veteran MemberPosts: 4,206Gear list
Re: Why no more ISO 100?
In reply to ulfie, May 4, 2012
Just my theory: If you start at ISO 100, then ISO 1600 is 4 stops higher. But if you engineer the base ISO to be 200, then ISO 1600 is only 3 stops higher.
I suspect camera companies are aware of how people compare high ISO images, so they want to get better image quality there, and are willing to give up ISO 100 for it.
js
 JosephScha's gear list:JosephScha's gear list
Panasonic Lumix DMC-G10 Panasonic Lumix G Vario 45-200mm F4-5.6 OIS Panasonic Leica Summilux DG 25mm F1.4 +4 more
Jim T
Veteran MemberPosts: 4,220Gear list
In reply to JosephScha, May 4, 2012
I seem to recall several threads discussing the fact that many cameras that had ISO less than 200 were actually faking it.
 Jim T's gear list:Jim T's gear list
Sony Cyber-shot DSC-TX10 Olympus Tough TG-1 iHS Panasonic Lumix DMC-GH1 Olympus PEN E-PL2 Panasonic Lumix DMC-GF3 +11 more
ulfie
In reply to Jim T, May 4, 2012
What?! Like faking a climax...
Detail Man
Forum ProPosts: 14,950
So that your camera will be more likely to blow highlights at the RAW level, of course. People like bright, cartoonish images devoid of highlight details. Makes them feel good; righteously talented ...
No. Like faking a "camax" ...
Aleo Veuliah
Forum ProPosts: 14,465Gear list
New sensors tend to have a higher base ISO
Simplicity is the ultimate sophistication.
God is the tangential point between zero and infinity.
Imagination is more important than knowledge.
God always take the simplest way.
 Aleo Veuliah's gear list:Aleo Veuliah's gear list
Panasonic Lumix DMC-ZS1 Panasonic Lumix DMC-FZ1000 Panasonic Lumix DMC-GF1 Panasonic Lumix DMC-G2 Nikon 1 V3 +4 more
bobn2
Forum ProPosts: 27,836
Good observation, and a bit silly on behalf of the Four Thirds manufacturers. Really they should be aiming for a base ISO of 1/4 that of FF (25 or 50) if they want to match FF SNR with FT. That would bring the photographic capability with the compactness advantage.
Bob
ulfie
In reply to Aleo Veuliah, May 4, 2012
Aleo,
You wrote, "New sensors tend to have a higher base ISO."
Ah...I know that. My question is why.
jcharding
Senior MemberPosts: 1,977Gear list
A lot of old sensors also have a base ISO of 200 - including many Nikons. ISO100 is available, but it isn't the base ISO and is more noisy than ISO 200.
http://jcharding.zenfolio.com/
 jcharding's gear list:jcharding's gear list
Fujifilm FinePix X100 Olympus PEN E-P2 Olympus PEN E-P3 Fujifilm X-Pro1 Olympus OM-D E-M5 +10 more
bobn2
In reply to jcharding, May 4, 2012
It's never more noisy. It's always less noisy, just because of the extra exposure, but it risks blowing the highlights, because it's really just increasing exposure into the highlight headroom.
Bob
bobn2
ulfie wrote:
Aleo,
There is no 'why' - designers can design the base ISO as they want, within limits. The problem is, though that moving the base ISO down will inevitably provide slightly worse high ISO performance, and high ISO performance is too big a marketing asset for manufacturers to risk it. That is probably why mFT tends to go with 200, even though they should really be using 50 or 25.
Bob
Adventsam
Veteran MemberPosts: 4,983
Oly iso200 is 130!
http://forums.dpreview.com/forums/read.asp?forum=1041&message=41417060
odl
odl
Senior MemberPosts: 1,684
In reply to bobn2, May 4, 2012
While it would be nice for landscape shooters and studio shooters, ISO 50 and 25 have a little less use in general day to day shooting.
What would be nice, is to see cameras released as a high ISO and a low ISO model. But then, I dont know how that effects the actual manufacture of the wafer.
Ab
Bob
alatchinphotography.com
“Imagination is more important than knowledge. For
knowledge is limited to all we now know and
understand, while imagination embraces the entire
world, and all there ever will be to know and
understand.” - Albert Einstein
Detail Man
In reply to Adventsam, May 4, 2012
Adventsam wrote:
Oly iso200 is 130!
I myself might be more concerned with IQ than ISO at this point ...
MrFoopy
Regular MemberPosts: 322
One of the constraints for sensor development is the total ratio between high and low ISO values. If they "cheat" a little bit at the low end, they get higher usable ISOs at the top end. Many folks like that.
Myself, I'd love a usable ISO100 or ISO50. Saves some fiddling around with ND filters.
PhotographicPhil
Regular MemberPosts: 320
bobn2 wrote:
ulfie wrote:
Aleo,
Of course there is a "why", and the "because" is exactly as you said - because high ISO sells more cameras than low ISO.
bobn2
In reply to odl, May 4, 2012
They have as much use as 200 and 100 on a FF camera. The Cnaon f/4L lenses are rightly very popular. F/4 on a 5DIII at 100 ISO will give a very similar result noisewise as F/2 on a E-M5 at 25 ISO (if it had it) at the same shutter speed. Lowering the ISO and f-number provides a simple means for mFT cameras to have IQ parity with larger formats, while retaining the size advantages (though the f/2 zoom are a bit big). I guess there are a lot of photos taken around f/8 at 100 ISO on FF, which could equally well be taken at f/4, 25ISO on FT.
It means changing the capacitance in the pixel. Aptina has a sensor design which allows it to be selected.
Bob
luisflorit
Veteran MemberPosts: 6,830Gear list
In reply to Detail Man, May 4, 2012
Detail Man wrote:
Adventsam wrote:
Oly iso200 is 130!
IQ at which ISO? Better question: at real ISO or at fake ISO?
My gallery: http://luis.impa.br/photo/new
Oly E5/E3 + 12-60 + 50-200 + EC14 + EC20 + FL50R
Pany FZ50 + Oly FL50 + TCON17 + Raynox 150 & 250
 luisflorit's gear list:luisflorit's gear list
Olympus E-M1 Olympus Zuiko Digital ED 50-200mm 1:2.8-3.5 SWD Olympus Zuiko Digital 2.0x Teleconverter EC-20 Olympus Zuiko Digital 1.4x Teleconverter EC-14 Panasonic Lumix G Vario 100-300mm F4-5.6 OIS +3 more
odl
odl
In reply to bobn2, May 5, 2012
You would need an awful lot of light to use ISO 25 with a kit zoom at f4 on a micro 43rds camera.
However, that sensor tech sounds very promising.
Ab
s_grins
Veteran MemberPosts: 8,474Gear list
Re: Because of inflation? n/t
In reply to ulfie, May 5, 2012
I’m surprised how much Wikipedia contributes to the forum.
 s_grins's gear list:s_grins's gear list
Panasonic Lumix DMC-GH2 Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS Panasonic Lumix G 20mm F1.7 ASPH Panasonic Lumix G Vario 45-200mm F4-5.6 OIS Sigma 30mm F2.8 EX DN +2 more
