K-01 @ ISO6400....impressive!!!
Started May 4, 2012 | Discussions
Wesley Wong
Regular MemberPosts: 327
May 4, 2012
100% view:
Tell me what you think?
I just love both my K-01s......
~ Wesley ~
Pentax K-01
igelfeld
Senior MemberPosts: 1,079
Re: K-01 @ ISO6400....impressive!!!
In reply to Wesley Wong, May 4, 2012
What's there to think :-)? Great!
Igelfeld
awaldram
Forum ProPosts: 10,460Gear list
That 16mp Sony sensor is very good and once Pentax have waved their pixie dust on it its excellent
 awaldram's gear list:awaldram's gear list
Pentax Q Pentax K-3 Pentax smc DA* 55mm F1.4 SDM Pentax smc DA* 16-50mm F2.8 ED AL (IF) SDM Pentax smc DA* 50-135mm F2.8 ED (IF) SDM +11 more
mike703
Veteran MemberPosts: 5,747
Hi, how were these processed - RAW or jpeg and did you apply any NR?
Mike
http://www.pentaxphotogallery.com/artists/mikeward
Wesley Wong
In reply to mike703, May 4, 2012
Hi Mike,
These were shot entirely on JPEG with NR @ 6400 set to level 1 (custom NR for high ISO).
I further added some color noise reduction (+12) in Lr4. I retained the luminance noise, as I like the grainy look.
Wesley
drummercam
Regular MemberPosts: 439Gear list
the uniform graininess in the 100% view of the chair is indeed pleasing to look at.
 drummercam's gear list:drummercam's gear list
Pentax K-01 Pentax K-30 Pentax K-3
asahi man
Regular MemberPosts: 418
The first pic is not a plus point for the camera,but the other are on K-5 level.
Best regards
kikivrany
Senior MemberPosts: 2,716
Hello Wesley Wong
The K01 have for sure a nice ISO 6400...like the K5, .... but could it be that your pictures are all croped ?
I mean, the noise in the first picture is a little too much for a ISO 6400, therefore, and because the 100% view have effect only a 'small' magnification view, I think the first picture is for example already a big crop.
best regards kikivrany
carpe noctem
Wesley Wong
In reply to kikivrany, May 5, 2012
The images are not cropped, but viewed at different level of pixel dimensions. First let's understand that noise is more apparent on shadow areas than highlight. Also, it also lurks in the blue channel. Anything within shadow/blue has more tendency to induce sensor noise.
The 100% of the image shows the 'up, close and personal' view of the characteristic of the noise. It's definitely more luminance than color. Pentax engineers has done a great job in this aspect.
I like luminance noise. Color noise, these days can easily be eradicated in post processing too. Luminance noise adds character to the image, especially in black and white work.
Personally, I hardly ever shoot in such high ISO6400 as I'm a lavish flash user. This is just an illustration of how well the K-01 handles noise at such level.
Wesley
leopold
Forum ProPosts: 11,962Gear list
In reply to Wesley Wong, May 5, 2012
Thank you for showing your results, the highest ISO i've tried on my K-01 is ISO 2000.
I regularly use it at ISO 1000 to 1250 and i like the results.
Leopold
Pentax forever
http://smarcoux.zenfolio.com/
http://www.limagier-photo.com/
http://www.firstlight.com/galleries.php
http://steevemarcoux2.wordpress.com/
JohnBee
Veteran MemberPosts: 3,864
Looks very very good.
I'd love to see what comes out of this in RAW and a good NR software like Topaz Denoise!
PS. based on what I've seen to date it looks as though the K-01 is resolving slightly more detail than the K-5. Which is very encouraging for us hopefuls out there waiting on a K-5 replacement
Wesley Wong
In reply to JohnBee, May 5, 2012
Thanks for your kind comment.
I think the K-01 uses a weaker AA filter, hence increasing pixel sharpness. If only they take it out completely....it will be heaven!! We can easily deal with any moire, if any.
Robgo2
Veteran MemberPosts: 3,437
Uh, sorry, but moire is not always easily dealt with. AA filters have a bad reputation around here, but they do serve a useful purpose. Moreover, the blurring effect they introduce can largely be removed by deconvolution sharpening.
Rob
kikivrany
Hello Wesley Wong
I made pictures with my K5 in a theater. It was a ballet performance. The illumination was partial with blue, red and green light-spots.
Now I don't belive that the K5 is different to the K-01. Therefor I wonder about how 'big' the noise looks like in your first picture, and this in all colour channels.
I read that you used a JPG. Now I would realy try out a RAW file for compare.
I'm sure, that would result in a much more impressive result.
It's not that I mean the JPG looks bad, it's only that if you do later PP a high ISO JPG picture, it can never be so good as if you PP a high ISO RAW file.
I can not post a picture where you can see the dancers, so here a shaddow picture:
K5 / ISO 8000
carpe noctem
Jim King
Veteran MemberPosts: 7,549Gear list
In reply to Robgo2, May 5, 2012
With respect, Rob, deconvolution sharpening can restore the illusion of the lost sharpness, but the image will still not be as sharp as it would be without the AA filttration. Lost information can only be estimated, not restored. At least IMHO...
Jim King - Retired Colormonger - Suburban Detroit, Michigan, USA; GMT -4h (EDT)
Pentaxian for over 50 years.
A fanatic is one who can't change his mind and won't change the subject.
  • Sir Winston Churchill
The difference between genius and stupidity is that genius has its limits.
  • Albert Einstein
 Jim King's gear list:Jim King's gear list
Leica M9 Ricoh GXR S10 24-72mm F2.5-4.4 VC Ricoh GXR Mount A12 Ricoh GXR A16 24-85mm F3.5-5.5 Pentax K-5 IIs +4 more
Tom__Brown
Senior MemberPosts: 1,268
Re: terrific and so is that Zeiss 35mm (nt)
In reply to Wesley Wong, May 6, 2012
-- Tom
taitai
Senior MemberPosts: 1,201
I shot yesterday first time with my new k5 25600 iso! shot raw pp cs5 1/60 F5.6 50mm 1.7 A.
snake_b
Senior MemberPosts: 4,680
In reply to taitai, May 6, 2012
These high ISO shots are looking great.
Wesley Wong
In reply to taitai, May 7, 2012
Awesome!!! Did you shoot in RAW and process the NR separately in Photoshop?
taitai
In reply to Wesley Wong, May 7, 2012
Yes Wong,shot raw and pp with CS5.
Thanks itai.
http://www.flickr.com/photos/39871864@N05/
