leica m8 actuations count?
Started May 2, 2012 | Discussions
msadat
Forum MemberPosts: 76Gear list
May 2, 2012
how do you tell the number of shots taken with leica m8? thanks
 msadat's gear list:msadat's gear list
Sony RX100 Leica S2 Canon EOS-1D X Nikon D800E Leica M Typ 240 +6 more
MrLaki
Senior MemberPosts: 1,094
Re: leica m8 actuations count?
In reply to msadat, May 3, 2012
easiest way is to use m8 info:
http://www.soens.de/swpage/swpage.html
cheers
laki
Homer: If The Flintstones has taught us anything, it's that pelicans can be used to mix cement.
http://www.konstantinou.com
jaapv
Forum MemberPosts: 73
In reply to MrLaki, May 3, 2012
Which means, look in EXIF for the "Unique Image ID" on the last image you took, and read out the hex number there. Convert to decimal (tools on the internet) and there is the number of actuations -which cannot be faked btw.
Jaap
msadat
In reply to jaapv, May 3, 2012
thank you all
tschotsch
New MemberPosts: 9
In reply to msadat, May 4, 2012
I have an easier way for you, try this…
the navigation dials (four arrows) next to the screen, hit the right arrow 4 times, the left arrow 3 times, the right arrow one more time and then INFO, navigate to BODY DEBUG DATA and press SET. Navigate with the arrow buttons and search for NumExposures. I have not found any other way to exit this menu other than shutting the camera off.
Hope this works for you
Cheers
tschotsch
jaapv
In reply to tschotsch, May 7, 2012
I don't know what you have been doing - but this procedure brings up....The info screen. In other words, it does nothing.
Cheers
tschotsch
Jaap
sillette
Regular MemberPosts: 179
In reply to jaapv, May 7, 2012
works for me. You have to turn on the camera first....
tschotsch
New MemberPosts: 9
In reply to jaapv, May 12, 2012
Hi jaapv,
it actually brings up an info/ debug screen which Leica and their dealers use to determine the state of the camera and also the number of exposures… you might want to try this again and see if you can get to this screen, if not, I can send you a short video flick I made with my iPhone where a Leica dealer is showing me the procedure on my M8, but it is in german…
Cheers
–tschotsch
tschotsch
New MemberPosts: 9
In reply to sillette, May 12, 2012
sorry, forgot to mention the 'turning the camera on' part…
Brad Herman
Regular MemberPosts: 194
In reply to tschotsch, May 15, 2012
I have been using a Freeware program called Opanda iEXIF version 2.3. You can also purchase the full version if you wish to edit the iEXIF Data and do other things.
When you open a file with Opanda, look for Unique Image ID. There is a Hex number which can be converted to Decimal using the Windows (or other) Scientific calculator. This gives you the total number of actuations at the moment that you captured that particular image.
http://www.opanda.com/en/download/index.html
Brad
valleyman
New MemberPosts: 24
Hey thanks for posting this, that's great to know!
Reminds me of the "Konami Code"
http://en.wikipedia.org/wiki/Konami_Code
tschotsch
New MemberPosts: 9
In reply to valleyman, May 17, 2012
Ha! My pleasure, I'm glad it worked for you.
tschotsch
New MemberPosts: 9
In reply to jaapv, May 17, 2012
actually, I think you are pressing the SET button after the arrow button combination, you must hit the INFO button…
