Is the Lumix 14-42X still problematic?
Started May 2, 2012 | Discussions
zzzzzzzzzzz
Senior MemberPosts: 2,215
May 2, 2012
There were a lot of OIS related issues being reported when the 14-42X was released. Many people were having trouble with ghosting, which resulted in blurry images. Did Panasonic resolve the issues with this lens?
Krishna Das
Contributing MemberPosts: 835
Re: Is the Lumix 14-42X still problematic?
In reply to zzzzzzzzzzz, May 2, 2012
I would also like to know. I've been away from this forum for a while (bicycle accident). Tried to search for it but no luck.
Anybody owns one?
Nikko aus London
Senior MemberPosts: 1,131Gear list
In reply to Krishna Das, May 2, 2012
My copy is better than fine. See my post from last Sunday on India with many, many samples.
N
 Nikko aus London's gear list:Nikko aus London's gear list
Panasonic Lumix DMC-GF1 Olympus OM-D E-M5 Panasonic Lumix G 20mm F1.7 ASPH Panasonic Lumix G 14mm F2.5 ASPH Olympus M.Zuiko Digital 45mm 1:1.8 +5 more
cysewski
Regular MemberPosts: 104Gear list
In reply to Nikko aus London, May 2, 2012
It is not fixed, see DPReview test of the GX1 and others. I have the lens, and want to like it, but I can repeat the same problem described in the DPReview test. The test is with firmware 1.1. I am keeping the lens because I hope (assume) that Panasonic will fix it.
Stephen Cysewski
 cysewski's gear list:cysewski's gear list
Olympus E-M1 Olympus OM-D E-M10 Olympus M.Zuiko Digital ED 9-18mm 1:4.0-5.6 Olympus M.Zuiko Digital 45mm 1:1.8 Panasonic Lumix G X Vario PZ 45-175mm F4.0-5.6 ASPH OIS +6 more
MAubrey
Senior MemberPosts: 1,479Gear list
The situation is the same as it always has been:
Some copies are problematic.
Some copies are not problematic.
I'd say its worth trying for a good copy if the place you order from has a reasonable return policy.
--Mike
 MAubrey's gear list:MAubrey's gear list
Olympus OM-D E-M5 Sony Alpha 7 Olympus M.Zuiko Digital ED 9-18mm 1:4.0-5.6 Voigtlander 58mm F1.4 Nokton SL II Voigtlander 35mm F1.2 Nokton +7 more
Button Pusher
Contributing MemberPosts: 584Gear list
Re: Question asked...
fcna72
Regular MemberPosts: 215Gear list
In reply to Button Pusher, May 2, 2012
have tried 4 different copies, including latest batch with serial # starting with HN. Though sharpness is superb at 14mm, as soon as I zoom in in the 1/80 to 1/200 range, all displayed the double blur issue.
 fcna72's gear list:fcna72's gear list
Panasonic Lumix DMC-GX7
Kevdog
Senior MemberPosts: 1,365Gear list
My copy had problems with OIS off, which implied more of a hardware issue, not a firmware one. Holding the lens barrel firmly made it better, which again implies a hardware issue.
It was a GF3X kit lens.
I made numerous posts about it. You can search for that info.
 Kevdog's gear list:Kevdog's gear list
Olympus OM-D E-M5 Olympus PEN E-PL5 Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS Panasonic Lumix G 14mm F2.5 ASPH Panasonic Lumix G Vario 100-300mm F4-5.6 OIS +2 more
LMNCT
Senior MemberPosts: 1,525Gear list
No problems at all. Counting myself lucky. Good luck with your search. Hope you find one that works for you because it is a rather nice lens when it works properly.
 LMNCT's gear list:LMNCT's gear list
Panasonic Lumix DMC-LX7 Panasonic Lumix DMC-G1 Panasonic Lumix DMC-GF1 Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GM1 +15 more
e268
Senior MemberPosts: 1,182
In reply to LMNCT, May 3, 2012
It may be a QC issue. My thread here show happy owners:
http://forums.dpreview.com/forums/readflat.asp?forum=1041&message=41391983
