Lightroom 3 / D800 Help
Started May 2, 2012 | Discussions
marike6
Senior MemberPosts: 5,070Gear list
May 2, 2012
I can't seem to get Lightroom 3.6 to recognize files from my D800. Does anybody know how to get LR 3.6 working for D800 NEFs?
I successfully installed ACR 3.7, and Photoshop CS5 is reading NEF files fine. But when I try to import a CF card of images via Lightroom, the import window has "Preview Unavailable", and unrecognized file error.
Is there some trick or secret RC update? My LR is version 3.6 and the LR splash screen reads "Lightroom 3.6" and "ACR 3.6". I tried preferences in LR, but there doesn't seem to be a way to change ACR to 3.7.
On a side note, NX2 is much faster, and nicer to use than I remember, but I'm so used to a LR workflow, I'd like to at least compare LR vs NX2 before I make a decision which to use for D800 files. Thanks everybody, Cheers, Markus
 marike6's gear list:marike6's gear list
Nikon Coolpix P330 Panasonic Lumix DMC-GH2 Nikon D800 Fujifilm X-E1 Panasonic Lumix G 20mm F1.7 ASPH +7 more
Nikon D800
jfriend00
Forum ProPosts: 11,090
Re: Lightroom 3 / D800 Help
In reply to marike6, May 2, 2012
I believe you need Lightroom 4 in order to get D800 support. Lightroom does not use the same installed ACR engine as Photoshop. LR has it's own version of the ACR code built-in and you cannot update just the RAW converter in LR. You must upgrade LR itself to get a new RAW converter. In this case, D800 support came in LR4. Source: http://blogs.adobe.com/lightroomjournal/2012/03/raw-support-in-lightroom-and-camera-raw.html .
The only way I know of to get D800 RAW files to work with LR3 is to use the latest free DNG converter from Adobe and convert your D800 files to DNG and you can then open the DNG files in LR3.
John
Gallery: http://jfriend.smugmug.com
Popular: http://jfriend.smugmug.com/popular
Portfolio: http://jfriend.smugmug.com/portfolio
Surefire Photo
Forum MemberPosts: 57Gear list
Hi Markus!
You'll need to download Adobe's DNG converter release candidate here: http://labs.adobe.com/downloads/cameraraw6-7.html and convert your .nef files to .dng for import. It's a free download, and .dng files are both smaller and loseless so not a bad trade-off for an extra step
Adobe is scheduled to implement full D800/E .nef support soon.
Have a great day!
-Sean
http://www.surefirephotography.com
 Surefire Photo's gear list:Surefire Photo's gear list
Nikon D3 Nikon AF-S Nikkor 70-200mm f/2.8G ED VR Nikon AF-S Nikkor 24-70mm f/2.8G ED Nikon AF Nikkor 50mm f/1.4D
Dave Courtenay
Contributing MemberPosts: 692Gear list
In reply to Surefire Photo, May 2, 2012
You need LR 4 and CS5 6.7 to open RAW files from the D800 both available now
http://www.wildlifeinfocus.com
 Dave Courtenay's gear list:Dave Courtenay's gear list
Nikon D800 Nikon D800E Nikon AF-S Nikkor 16-35mm f/4G ED VR Nikon AF-S Nikkor 24-70mm f/2.8G ED Nikon AF-S Nikkor 600mm f/4G ED VR +9 more
marike6
In reply to Dave Courtenay, May 2, 2012
So my only option is to buy another copy of Lightroom? I know it's not terribly expensive, but that's pretty lame of Adobe, IMHO.
The converted NEFs from NX2 look really amazing, but for some reason, the saturation is very low. I don't know if the Picture Control has any effect on RAW, but I've been shooting in Standard, and the converted NEFs just don't pop unless I switch the Picture Control to Vivid or turn up Saturation in NX2. Does anyone have any thoughts on JPEGs from NEF in NX2 vs LR?
Thanks everybody. Greatly appreciate the fast replies. Love the camera. Zero issues so far, and files look noticeably better than my previous camera, a 5D Mk II.
mfbernstein
Veteran MemberPosts: 6,518
They don't add new cameras to older versions once new versions have been released. That's how it is.
The DNG Converter workaround mentioned upthread is perfectly reasonable, and free.
MFBernstein
'Wilderness is not a luxury but a necessity of the human spirit.' - Ed Abbey
marike6
In reply to mfbernstein, May 2, 2012
I understand that, but since ACR 3.7 supports the D800, it would have been trivial for Adobe to implement D800 support. What's a bit troubling about Adobe is they now have an extremely fast release cycle where it seems like a new version of CS is released every half a year. Seems like I finally established a solid CS5 / LR3 workflow, and now CS6 and LR4 are out, and the new versions are needed for some popular new cameras. I know that how it is, but it doesn't seem like such a good way to support average users. Professional graphic design shops can afford to keep up with fast upgrade cycles. The rest of us, no less loyal Adobe customers, cannot.
I've used this method before, and have no problem with it except then you have a sets of RAW (DNG and NEF) using up hard drive space. I will likely buy LR 4 as I like all the B&W conversion filters, and RAW conversion is so fast relative to NX2. If people think the ultimate NEF > JPEG or TIFF quality is obtainable with NX2 however, I might skip LR and use NX2. Thanks a lot.
jfriend00
This is how Adobe does business with Lightroom. It has been this way since the very first day they shipped Lightroom 1. They will sometimes add new cameras to a free point release 3.1, 3.2, etc..., but once the next version is out new cameras are only added in the new version. LR4 shipped a little while ago so that's where all new camera support goes.
If you plan on being a LR customer, you will just need to plan on upgrading regularly. If you don't want to do that, then you will need to select a different software vendor that has a policy you like.
This forum isn't a very useful place to complain about Adobe's long standing policies. It's very old news here and nobody who can do anything about it is here. I'm sure you can find a more lively discussion about the policy over in the adobe forums.
John
marike6
In reply to jfriend00, May 2, 2012
I've been an Adobe customer for years since Photoshop 5 days, so I am aware how they operate, but I guess I'm not in tune to the minutiae of their release cycles and minor updates/camera compatibility.
Sorry didn't mean to waste everyone's time complaining.
Patco
Forum ProPosts: 11,399
Just a nitpick - ACR 3.7 dates back to 2007, and does not support any cameras since that time.
http://www.adobe.com/support/downloads/detail.jsp?ftpID=3584
The version that supports the D800 is ACR 6.7 RC:
http://labs.adobe.com/technologies/cameraraw6-7/?tabID=details#tabTop
Patco
A photograph is more than a bunch of pixels
Patco
I wouldn't worry about it - there's quite a number of people in these forums who simply love complaining, and they seem to get plenty of responses, as well
Patco
marike6
In reply to Patco, May 2, 2012
I meant ACR 3.7, the final release candidate for CS5. The files for it and the DNG Converter 3.7 are both linked to here.
http://www.dpreview.com/news/2012/05/02/Adobe-releases-ACR-6-7
Thanks everybody.
Patco
Adobe Camera Raw 6.7 & DNG Convertor 6.7 are linked.
Not 3.7
Patco
marike6
Not 3.7
Got it confused with the LR 3.6 that I have, and the version of LR 3.7 that I was hoping to download, but that doesn't exist. My fault. Sorry.
sfnikon
Senior MemberPosts: 1,937Gear list
No new LR3 work around?
In reply to marike6, May 24, 2012
Am I forced at this point to upgrade to LR4? I don't think the NEF to DNG converter is a viable long term option.
I just found out my D800E is ready for pick up so this caught me a bit unprepared.
Jake
Robin Casady
Forum ProPosts: 10,827
Re: No new LR3 work around?
In reply to sfnikon, May 24, 2012
Upgrade. Lightroom 4 has an improved conversion engine, so it is a worthwhile upgrade.
Robin Casady
http://www.robincasady.com/Photo/index.html
MasterOfGoingFaster
Senior MemberPosts: 1,255Gear list
So you can afford a $3000 camera, but a $75 upgrade isn't reasonable?
Yeah - I wish upgrades were free forever, but they are not. And Adobe did cut the price of Lightroom in half. If you think about it, common practice is to support and add features to current products, not older versions. It makes sense to have your coders work on the current code base, and not go back and work on obsolete products - other than security fixes.
I have the Adobe CS Master Collection and I have to upgrade the entire suite to get Photoshop to support newer cameras - at a cost of over US$1000. The Lightroom upgrade is a sweet deal. Besides, you'll want the moire-removal brush and other tools that are easily worth the $75 upgrade price.
Ken Elliott
Equipment in profile.
 MasterOfGoingFaster's gear list:MasterOfGoingFaster's gear list
Nikon D700
marike6
In reply to MasterOfGoingFaster, May 24, 2012
What I can and cannot afford is my business.
Not long ago I purchased the full version of CS5 and LR3, and will likely purchase LR4, and since I asked this question nearly a month ago, I have since purchased LR4.
Good for you.
MasterOfGoingFaster
Indeed. I didn't mean to question that - sorry. I just don't grasp the logic of you saying Adobe is "pretty lame" for what appears to be such a small amount of money compared to the camera. But there's lots of things I don't understand.
Sorry if my response rubbed you the wrong way. Just trying to understand.
My mention of the Master Suite upgrade is to provide a basis for others to understand why I think $75 is cheap, and nothing more.
Ken Elliott
Nikon D700
mais51
Contributing MemberPosts: 655Gear list
In reply to MasterOfGoingFaster, 10 months ago
It is not simple to upgrade from LR3 to LR4, LR4 requires 64-bit operating system, will not install in 32-bit version of Windows.  64-bit is a whole new ball game: new hardware, new software, new installation and new trouble shooting. One must have to be prepare for this trouble and expense. I suppose Mac OS is 64-bit so it is not a problem for anyone using Mac OS
 mais51's gear list:mais51's gear list
Canon PowerShot SX260 HS Nikon D300S Nikon D800 Nikon AF-S Nikkor 50mm f/1.4G Nikon AF Nikkor 24mm f/2.8D +3 more
