IS with Continuous Shooting - Review corrected.
Started May 1, 2012 | Discussions
Richard Butler
dpreview AdminPosts: 2,145
May 1, 2012
Reader feedback has brought to attention an error in the review. I had stated that IS didn't work at continuous shooting modes above 3.5fps. This was caused by a combination of mis-communication with Olympus and me mis-interpreting the results of my testing.
I've now re-tested the IS in continuous mode and revised the review accordingly. IS does work in continuous shooting mode, so the performance page has been revised and the 'Con' removed from the conclusion. The final score is unchanged, because the otherwise very good IS (especially in movie shooting) had given the camera a high score in that category, so the correction has limited impact on the overall total.
I apologise for the error and appreciate the user response that identified it.
Richard - dpreview.com
Rriley
Forum ProPosts: 21,846Gear list
Re: IS with Continuous Shooting - Review corrected.
In reply to Richard Butler, May 1, 2012
well done Richard
Riley
any similarity to persons living or dead is coincidental and unintended
support 1022 Sunday Scapes'
 Rriley's gear list:Rriley's gear list
Sigma DP2 Merrill Canon EOS 5D Olympus E-3 Olympus E-5 Panasonic Lumix DMC-GH2 +1 more
tommiejeep
Veteran MemberPosts: 4,351
Your timely re-testing and response it greatly appreciated and commended.
Anticipate the Light and wing it when you get it wrong
Tom
http://taja.smugmug.com/
TEBnewyork
Forum ProPosts: 11,337
Great!
Richard many thanks to you and the team for reading user questions and digger deeper when needed.
terry
http://www.terrybanet.com
Bob Meyer
Veteran MemberPosts: 5,375Gear list
Can you explain the "miscommunication" and the error in your testing, and how they impacted the reported results?
Bokeh is the aesthetic quality of the blur in out-of-focus areas of an image, or the way the lens renders out-of-focus points of light. Bokeh is not the same as depth of field (DOF).
 Bob Meyer's gear list:Bob Meyer's gear list
Panasonic Lumix G Vario 7-14mm F4 ASPH Panasonic 12-35mm F2.8 Panasonic Lumix G Vario 14-140mm F3.5-5.6 ASPH. / Power O.I.S Panasonic Lumix DMC-G3 Panasonic Lumix DMC-G7 +6 more
gdiver
Regular MemberPosts: 359Gear list
One less con is a good thing! How about a 1/2 point for that? Ha Ha.
 gdiver's gear list:gdiver's gear list
Olympus XZ-2 iHS Olympus E-330 Olympus E-5 Olympus PEN E-PM1 Olympus E-M1
Just Having Fun
Veteran MemberPosts: 3,869
Round 80.5 up to 81????
In reply to gdiver, May 1, 2012
I love it!
Macx
Senior MemberPosts: 1,430Gear list
I see that you also concurred with my find that the flash slow limit affects the auto iso shutter time limit (unfortunately it doesn't give you a full range but at least you get more than a fixed 1/60 second). Maybe half a percentage point there, too?
Tim in upstate NY
Veteran MemberPosts: 7,120Gear list
Yes we want 81 just like the NEX7
In reply to Just Having Fun, May 1, 2012
Just Having Fun wrote:
I love it!
. . . 81 would give the OM-D some real EQUIVALENCE with the Sony flagship.
 Tim in upstate NY's gear list:Tim in upstate NY's gear list
Olympus PEN E-PL3 Olympus OM-D E-M5 Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS Panasonic Lumix G 20mm F1.7 ASPH Olympus M.Zuiko Digital ED 14-150mm 1:4-5.6 +3 more
Richard Butler
In reply to Macx, May 1, 2012
There's nowhere for things that minor to be factored into the scoring, so there's nothing I could change to reflect it.
Macx
I know, I kid.
aleksanderpolo
Regular MemberPosts: 433
Thank you. So without going back to the review, is the IS as effective in continuous mode as in single shot mode?
cmorse
Contributing MemberPosts: 503Gear list
missed a spot.
Olympus says the camera will only achive 4.2fps with IS Off, with IS limiting the frame rate to 3.5 fps.
(includes a spelling error as well)
 cmorse's gear list:cmorse's gear list
Olympus OM-D E-M5 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Olympus Zuiko Digital ED 70-300mm 1:4.0-5.6 Olympus Zuiko Digital 14-54mm 1:2.8-3.5 Sigma 105mm F2.8 EX DG Macro +4 more
Jerodequin
Senior MemberPosts: 1,273Gear list
Thanks - are you also going to be adding the video of the live bulb mode in action soon? A couple of people seem to have mentioned that the quality of the final image for a long exposure in live bulb mode is not as good as that for standard bulb mode, would be great to see if this is indeed the case!
 Jerodequin's gear list:Jerodequin's gear list
Panasonic Lumix DMC-TS2 Panasonic Lumix DMC-GH2 Olympus PEN E-PL3 Panasonic Lumix G 14mm F2.5 ASPH Panasonic Lumix G Vario 100-300mm F4-5.6 OIS +14 more
Mark Thornton
Veteran MemberPosts: 3,135Gear list
Pro needs editing too
"Built-in image stabilization helps increase number of sharp shots (in single-frame mode)"
The bit in parenthesis (from the pros section) should be deleted.
Mark
 Mark Thornton's gear list:Mark Thornton's gear list
Olympus E-500 Panasonic Lumix DMC-GX1 Olympus Zuiko Digital 11-22mm 1:2.8-3.5 Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 12mm 1:2 +5 more
Pikme
Senior MemberPosts: 1,819Gear list
Question about IBIS and video
If you move the camera when shooting stills (panning, etc), you have to choose the correct IBIS setting or you will get blurry photos.
Is that also true with video? And if not, why not?
Roberto M.
acahaya
Senior MemberPosts: 1,018Gear list
Thanks, was starting to wonder if i had a special E-M5 version ;) (nt)
 acahaya's gear list:acahaya's gear list
Olympus OM-D E-M5 Olympus E-M1
compositor20
Senior MemberPosts: 1,628
Re: Question about IBIS and video
In reply to Pikme, May 1, 2012
you said you couldnĀ“t set a minium shutter speed for auto iso but you can.. set flash sync at 1/250 or 1/125 and it will up the iso at that one or 1/30 if you like.
Please test Continuos Autofocus with vivid setting as a user said....
Raist3d
Forum ProPosts: 35,138Gear list
Thank you Richard- and a request for high ISo/low light
Thank you so much Richard for responding to user feedback. I feel it's great when authors/ reviewers do so
I have one request, if I may: is there any chance dpreview could try an assorted set of low
Light shots in mixed light real world conditions at Iso 3200-12800? Even just 6400 would do
I am very interested to see how the em5 handles these as it's one of the type of shootings I do the most (street night life). The current high ISO shots in the gallery aren't really low light to me with two ISO 6400's with a 1/4000ths shutter speeds.
For reference: (basically looking for ISP 6400 at f2.8 with 1/30 to 1/60 shutter):
I understand you guys are pretty busy so if it can't be done I understand. I just could not get a feel for high ISO performance from the review though it sure looks promising over what Olympus currently had.
Thanks again
Raist3d/Ricardo (Photographer, software dev.)- "You are taking life too seriously if it bugs you in some way that a guy quotes himself in the .sig quote" - Ricardo
Macx
I haven't tested this, so take it for what it is, but I believe that is not true with video for the reason that the translational axis IBIS (up-down, side-to-side) is automatically off during video, hence the less noise. Instead the IBIS system retains the rotational axis (pitch, yaw, roll) and a digital image stabilization similar to what's used in the Pen cameras takes care of the translational axis.
