5d3 with 135L... a magical match....
Started May 1, 2012 | Discussions
Tony Parenti
Regular MemberPosts: 346
May 1, 2012
I'm loving this combo and being able to select from all those focus points. I can honestly say I haven't touched my 5d2 since I upgraded. Poor thing.
Canon EOS 5D Mark II Canon EOS 5D Mark III
Peter 13
Veteran MemberPosts: 8,301
Re: 5d3 with 135L... a magical match....
In reply to Tony Parenti, May 1, 2012
The 135L is a lens that does not really require more than one AF point, except for action.
kim_hdr
Regular MemberPosts: 318
very nice sot
so you tell us that you can't do it with the 5D 2 ?
Rickuz
Regular MemberPosts: 117
In reply to Peter 13, May 1, 2012
It is a great photo from a great lens, but I gotta agree with Tony.
I'd understand if it had been a 50L 1.2 or 85L 1.2.
Rickuz
In reply to Rickuz, May 1, 2012
I ment that I agree with Peter.
Gosh. Will they ever fix the edit button? Its been 3 days already..
amobi
Senior MemberPosts: 2,738
Sorry but I totally disagree with you guys. 135L is one of those lenses that will benefit from more than one working AF point. The lens is too long for hand hold and requires steady hand for focus. Any focus and recompose messes things up unless you stopping down a lot.
In my book 50L, 85L and 153L will benefit a lot from 5DIII. The shot OP showed can be nailed with 5DII with careful focusing but will be a piece of cake with 5DIII.
facedodge
Regular MemberPosts: 306Gear list
Well if you want to catch a truly candid or special moment while still being able to properly compose your shots, then yes, you need more than one AF point.
"I'm so sick of all these, you don't need that camera to take that shot" CRAP!
You don't need a washing machine to get clean clothes and you don't need a computer to do your taxes either. I wonder if you spend your whole life trying to make it more difficult.
 facedodge's gear list:facedodge's gear list
Canon EOS 5D Mark III Canon EF 35mm f/1.4L USM Canon EF 50mm f/1.2L USM Canon EF 135mm f/2.0L USM Tamron SP AF 90mm F/2.8 Di Macro +4 more
Tony Parenti
In reply to kim_hdr, May 1, 2012
It's right in the manual, "Shots like these cannot be attained with the 5d Mark 2"...
No seriously, I didn't say that. Thought I probably would've center/recomposed it.... 5d3 just made it easier...
rpiotr01
Regular MemberPosts: 256Gear list
Great shot!
The water is nice and smooth, and colors really pop.
Also nice to know the outside AF points work well. They're not worth a ton on the 5DI.
rwbaron
Veteran MemberPosts: 7,712Gear list
Nice shot but I just wish the white bridge wasn't so distracting :|.
Bob
http://www.pbase.com/rwbaron
 rwbaron's gear list:rwbaron's gear list
Canon PowerShot G9 Canon PowerShot S90 Canon PowerShot G1 X Canon EOS 50D Canon EOS 7D +20 more
Peter 13
In reply to facedodge, May 1, 2012
Not really. I focus and recompose much faster than I can change the AF point.
Don' t start such threads then. Both the title and the comments suggest that the 5D3 has some special benefits with that lens that make it "magical". You should expect somebody to call your bluff.
fjpyyy
Forum MemberPosts: 84
In reply to rwbaron, May 1, 2012
+1. The white bridge dominates the frame, a bit distracting. Otherwise a very nice picture.
Peter 13
OK, you are not the OP. When will DPR adjust their clock?
Peter 13
In reply to amobi, May 1, 2012
I would remove the 135L from that list. I never had a misfocused shot with it with my 5D2. But I would add the 35L and the 24L. F&R is more problematic with WA, and that depends on the distance, as well.
Same with the 5D2.
AllanW
Senior MemberPosts: 1,155Gear list
This lens .............
The 135 f/2 and the 50 f/1.2 nearly made me move from Nikon to Canon.
They truly are remarkable pieces of glass.
Time Goes By!
carlk
Forum ProPosts: 15,786Gear list
IQ-wise this lens is a magic with any cameras. I do agree with you about the AF capability though. However I don't know it's the lighting or pp the image looks a little blend to me especially when it's coming from a lens like this. I've seen much better ones.
 carlk's gear list:carlk's gear list
Canon EOS 50D Canon EOS 7D Nikon D800E Fujifilm X-E1 Canon EF 85mm f/1.2L II USM +6 more
Collett
Senior MemberPosts: 4,961
Re: This lens .............
In reply to AllanW, May 1, 2012
I'll second that - my two favorite lenses.
Time Goes By!
Jim
NovemberSun
Regular MemberPosts: 393Gear list
Great example. Ive rented the lens in the past and loved it. one day...one day it shall be mine!
Cheers. Cheers to what we possess within ourselves. Cheers to the possibilities of this day.
 NovemberSun's gear list:NovemberSun's gear list
Canon EOS 50D Canon EF 24-85mm f/3.5-4.5 USM Canon EF-S 18-55mm f/3.5-5.6 IS Canon Pixma Pro9000 Mark II
chironNYC
Senior MemberPosts: 1,366
In reply to Peter 13, May 2, 2012
This seems less like a matter for dogma than for the shooter's preference.
Same with the 5D2.
Peter
chironNYC
In reply to fjpyyy, May 2, 2012
The white bridge is a nice structural element because it leads to the children, but it is so white that it pulls your away away from the children. I think you should bring it way down in post processing.
Peter
