Universal EM-5 preset for LR4.1 RC2
Started Apr 30, 2012 | Discussions
archeogeolab
Contributing MemberPosts: 534
Apr 30, 2012
Here it is: the first universal EM-5 preset for use with Lightroom 4.1 RC2.
The ORF's have a lot of headroom!
As always the Olympus jpegs show in shadow areas reddish to orangish casts.
This preset does't show that.
It is ment as a universal PP-starting point.
The coming weeks I shall post tweaks in this thread:
EM-5
Exposure: -1,05
Contrast: -20
Highlights: -75
Shadows: 25
Whites: 45
Blacks: 10
Clarity: 5
Vibrance: 10
Saturation: 10
Sliders in tone curve:
border between shadows and darks: 10
border between darks and lights: 30
border between lights and highlights: 90
Hightlights: -40
Lights: 50
Darks: 54
Shadows: -15
Point curve: Linear
Color:
Red hue: 8
Red saturation: -18
Red luminance: -2
Orange hue: 18
Orange saturation: 7
Orange luminance: 0
Yellow hue: 0
Yellow saturation: -13
Yellow luminance -4
Green hue: -18
Green saturation: 18
Green luminance: 7
Aqua hue: 0
Aqua saturation: 9
Aqua luminance: 7
Blue hue: 0
Blue saturation: -2
Blue luminance: 4
Purple hue: 0
Purple saturation: 4
Purple luminance: 10
Magenta hue: -10
Magenta saturation: -7
Magenta luminance: 5
Sharpening:
amount: 100
radius: 1.0
detail: 15
Camera Calibration:
process: 2012 (Current)
profile: Adobe Standard
Red primary:
hue: 0
saturation: 0
Green primary:
hue: 20
saturation: -40
Blue primary:
hue: -1
saturation: 1
Wishes, Erik
Gregm61
Forum ProPosts: 14,413Gear list
Re: Universal EM-5 preset for LR4.1 RC2
In reply to archeogeolab, Apr 30, 2012
Your presets for the E5 DSLR were awful good, so I'd expect these to be equally desireable for any Lightroom or Photoshop CS6 ACR user.
Those sharpening settings are interesting. Do you use the luminence noise filter slider at all? I didn't see it in the list under sharpening where I'd expect it.
Greg
"There's shadows in life, baby.." Jack Horner- Boogie Nights
 Gregm61's gear list:Gregm61's gear list
Leica M9 Olympus OM-D E-M5 Panasonic Lumix DMC-GX7 Olympus E-M1 Olympus Zuiko Digital ED 50mm 1:2.0 Macro +17 more
archeogeolab
In reply to Gregm61, Apr 30, 2012
These sharpening values are only ment for monitor view of full images (no cropping).
Printing needs another sharpening approach.
For high ISO's and cropped images I indeed also use the luminence noise filter.
Wishes, Erik
Greg
londonsnapper
Forum MemberPosts: 50
As a GX1 owner, I was wondering if you might share your technique for creating these universal profiles so that I might make my own for Lightroom use.
At present I have a basic preset that works lightly on contrast, NR, highlight reduction, clarity and vibrance - which I am continuing to evolve, having realised that those are the settings 99% of the time, and in a particular way to establish a basic better image which can then be fine tuned. So I'd be interested to here your method for these other settings, which I generally only edit on an image-by-image basis.
Leopr
Regular MemberPosts: 307Gear list
Help-new LR user
I entered all those settings and liked the results very much. Is there a way to save those settings as a pre-set so I don't have to enter all those settings separately each time?
I did use the copy settings and paste settings under the settings tab and was able to apply them for other images in the same import but what happens if I do a new import?
Leo Reinhard, Pickering Ontario
 Leopr's gear list:Leopr's gear list
Olympus E-M5 II Olympus 12-40mm F2.8 Canon EF 35mm F1.4L II USM
Macx
Senior MemberPosts: 1,430Gear list
Thank you very much, I've bookmarked this and will try it out in the next couple of days. Does this require a custom white balance in the camera to work properly?
archeogeolab
In reply to londonsnapper, Apr 30, 2012
The preset is made by a near unendlesly adjusting of all parameters with different all color-containing RAW's (low-high ISO's; flash; dull and bright sunny conditons; contrasty and even images; shadow images; skies, beaches, snow, nature, portraits, landscapes, over- and underexposures; skin colors; tele- and wide).
I have no special method, only experience.
Erik
Bob Tullis
Forum ProPosts: 30,472Gear list
Re: Help-new LR user
In reply to Leopr, Apr 30, 2012
In the Library module, look over to the top-left for Presets. Click the Plus sign of the Presets heading to save the current settings in effect.
...Bob, NYC
http://www.bobtullis.com
"Well, sometimes the magic works. . . Sometimes, it doesn't." - Little Big Man
 Bob Tullis's gear list:Bob Tullis's gear list
Sony Alpha 7S Sony Alpha 7R II Voigtlander 28mm F2 Ultron Olympus 12-40mm F2.8 Sony RX1R II +22 more
archeogeolab
Hi Leo,
In the "develop" mode of Lightroom, you first fill in all the settings (from this post) in the vertical right toolbar. Then you go to the vertical left toolbar.
Right to the presets part you see a "plus" sign.
Click on it and you give these settings a name at your own choice (in folder: "user presets";......don't enable auto tone).
Click on "create" and you made the preset given in this post as your own preset.
Succes, Erik
archeogeolab
In reply to Macx, Apr 30, 2012
No I just used auto-WB in-camera and in the preset WB is "as shot".
Cheers
Bluephotons
Veteran MemberPosts: 4,000Gear list
I appreciate your good work and your willing to share this.!
I'm ready, now is your turn Adoraaaaamaaa!!!
Bluephotons
Ah, but I was so much older then, I'm younger than that now. Bob Dylan
 Bluephotons's gear list:Bluephotons's gear list
Olympus OM-D E-M5 Olympus M.Zuiko Digital ED 40-150mm 1:4-5.6 Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital 25mm F1.8
Leopr
Thanks Erik and Bob
I suppose I could alter any of these settings ( such as noise reduction changes ) and save as another preset?
londonsnapper
Ahh, I had suspected as much. Thanks though, sounds like an impressive effort that's paid off well
Erik
jaylive
Regular MemberPosts: 291Gear list
Re: Thanks Erik and Bob
i just added a preset. boy setting all those sliders really kicked my ass, but it seems pretty cool. thanks!
 jaylive's gear list:jaylive's gear list
Olympus OM-D E-M5 Panasonic Lumix G Vario 7-14mm F4 ASPH Panasonic Lumix G Vario 100-300mm F4-5.6 OIS Panasonic Leica Summilux DG 25mm F1.4 Olympus M.Zuiko Digital 45mm F1.8 +2 more
Brian Mosley
Forum ProPosts: 20,703Gear list
Thanks Erik
I'm new to lightroom, so this is very interesting and useful.
Thanks for the time this must have taken, I appreciate you sharing it with us.
Kind regards
Brian
Join our free worldwide support network here :
http://www.ukphotosafari.org/join-the-ukpsg/
UK, Peak District Local Olympus Safari Group : http://snipurl.com/bqtd7-ukpsg
Keep up with me here : http://twitter.com/alert_bri
 Brian Mosley's gear list:Brian Mosley's gear list
Sony RX1 Sony Cyber-shot DSC-RX100 IV Olympus E-M1 Fujifilm FinePix X100 Olympus OM-D E-M5 +1 more
archeogeolab
Of course,......that's the principle.
I have a lot of different presets (indeed f.i. for several grades of noise reduction).
This universal preset is ment as a starting point for PP-work.
Erik
bgalb
Senior MemberPosts: 1,664Gear list
Re: Thanks Erik
In reply to Brian Mosley, May 1, 2012
+1. My thanks also. Will give it (the preset) a good workout.
 bgalb's gear list:bgalb's gear list
Olympus OM-D E-M5 Olympus E-M1 Olympus Zuiko Digital ED 12-60mm 1:2.8-4.0 SWD Olympus Zuiko Digital ED 18-180mm 1:3.5-6.3 Olympus Zuiko Digital ED 50-200mm 1:2.8-3.5 SWD +7 more
Bob Tullis
In reply to archeogeolab, May 1, 2012
BTW, nice work. I never ever used a preset - enjoyed starting from 0 adjustments. This was simple enough to tackle in a few moments, and I like it.
Thank you.
...Bob, NYC
reggieandtfe
Regular MemberPosts: 143
I dont understand the section about the tone curve. Am i supposed to create points and drag them and where do i put in the numbers for whites, lights, darks, etc?
reggieandtfe
In reply to reggieandtfe, May 1, 2012
Nevermind, I figured it out. Great starting preset although certain scenes will require some serious massaging after the fact. Overall though, it vastly improves the flat raw shots.
