D7000 & the 24mm f1.4 G as a walkaround (lots of pics)...
Started Apr 30, 2012 | Discussions
Ray Soares
Veteran MemberPosts: 3,064Gear list
Apr 30, 2012
Just come from my mom's 80th birthday party and it was pretty fun!
You may go anywhere with this combo and a SB-700.
All with my usual flash settings and PP work
Best
Ray Soares
See my pictures at http://www.pbase.com/raysoares
 Ray Soares's gear list:Ray Soares's gear list
Nikon D7000 Nikon D4 Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II Nikon AF-S Nikkor 24mm f/1.4G ED Nikon AF-S Nikkor 85mm f/1.4G +1 more
Nikon D7000
antilles72
Regular MemberPosts: 479Gear list
Re: D7000 & the 24mm f1.4 G as a walkaround (lots of pics)...
In reply to Ray Soares, Apr 30, 2012
Wow Ray! What an excellent combo in your hands. Emphasis on the last part.
http://roystonkane.blogspot.com
 antilles72's gear list:antilles72's gear list
Nikon D800 Nikon AF-S Nikkor 50mm f/1.8G Nikon AF-S Nikkor 85mm f/1.8G
Mako2011
Mako2011 MOD
Forum ProPosts: 14,343
A problem
One problem Sir, all these pics remind me of how much work I have to do, and lead to a very short term period of depression. At least it's short term
Very nicely done! An excellent example in a number of different lighting/setup conditions. Thank you again for the motivation and pass my best wishes on to your Mother.
mothergoose
Senior MemberPosts: 1,227Gear list
Great job with those portraits. Love the one of the 4 children together. May I ask about your flash technique?
 mothergoose's gear list:mothergoose's gear list
Nikon Coolpix P7700 Nikon D800E Nikon AF-S Nikkor 50mm f/1.4G Nikon AF-S Micro-Nikkor 105mm f/2.8G IF-ED VR Nikon AF-S Nikkor 24-120mm f/4G ED VR +6 more
EfX
EfX
New MemberPosts: 7
In reply to mothergoose, Apr 30, 2012
I'm also interested on on how use your SB-700, lightning in those photos is pretty good !
andrbar
Veteran MemberPosts: 5,568Gear list
Great job!
80th birthday? Your mom is a beautiful woman. Tell her! (as for you, you're an excellent photographer).
André
 andrbar's gear list:andrbar's gear list
Nikon Coolpix P7100 Nikon 1 V1 Nikon AF-S DX Nikkor 55-200mm f/4-5.6G VR Nikon AF-S DX Nikkor 35mm f/1.8G Nikon 1 Nikkor VR 10-30mm f/3.5-5.6 +3 more
joaquin100
Senior MemberPosts: 1,516Gear list
Ray Soares
Happy Birthday then to her! She looks much younger and elegant too, congrats for your/her success.
Life must be good over there.
Regards
Joaquin
Deleted-pending
Senior MemberPosts: 2,665
Great shots Ray !
In reply to joaquin100, Apr 30, 2012
The 24mm 1.4 and 85mm 1.4 are fantastic lenses but I must admit, I am only 33 years old and your mother looks fantastic !
Larold
Contributing MemberPosts: 749
Hi Ray,
I am a fan, but I have a comment. Your photos are sooo sharp, that I notice a lot of makeup on everyone's faces. The photos are great, but could be more flattering if one or the other was backed off a bit.
Just my 2 cents.
Larold
Ray Soares
Thanks for your kind words guys!...
As for my setup for flash, I used my tradicional A mode plus my other settings, and always bounced the flash (in this case straigh upwards as the ceiling was pretty low).
The SB-700 seems to be made for this camera: just perfect!
For the ones who doesn't know yet my settings plz read this:
http://forums.dpreview.com/forums/read.asp?forum=1034&message=37815130
Obs: I've changed my flash settings with the SB-700 as you may have noticed...
As I used Matrix metering, the flash went to default iTTL-BL and balanced the main subject with the background, working flawless with auto-iso.
In some of these pics I put people in front of a window too and the Auto WB worked
pretty well.
Apertures range from f2 for one person to f5.6 with small groups.
As for make-up, for sure the old ladies used a lot of it and I did a lot of skin corrections in PP: just my style for this case and occasion!
But I can't see make-up on children and I didn't touch in their skin in PP
And plz forget the old rule that wide angle lenses can't do portraits!
Cheers
Ray Soares
Steve_in_FL
Contributing MemberPosts: 948Gear list
Re: Thanks for your kind words guys!...
Ray, first I will echo Mako's comments - your photos depress me because they are So much better than anything I can do! Truly amazing.
Second, you read my mind with your last comment! I was always told that wide angles were inappropriate for portraiture, because of the distortion. I was under the impression that I would go to Hell if I even considered using a W/A for a portrait. However, your results to the contrary are pretty hard to argue with. So what kind of magic do you use to get away with this?
 Steve_in_FL's gear list:Steve_in_FL's gear list
Nikon D7000 Nikon AF-S DX Nikkor 18-105mm f/3.5-5.6G ED VR Nikon AF Nikkor 50mm f/1.8D Nikon AF-S Nikkor 70-300mm f/4.5-5.6G VR Sigma 70mm F2.8 EX DG Macro +4 more
uncleskull
Senior MemberPosts: 1,903
Too bad you can't get good flesh tones with that D7000 . . .
WOWSERS! Nice stuff. VERY nice stuff.
unc
~ The only things stopping us from reaching our goals are the limitations we place on ourselves ~
Ray Soares
Re: Thanks Steve!...
In reply to Steve_in_FL, May 1, 2012
Mako is always kind with us mortals
As per the wide angles, I think the key is to increase your distance to keep distortions relatively in control. A little cropping later helps to bring objects closer.
Also in DX the 24mm is equivalent to 35mm and that's not too wide...
Best
Ray Soares
thejohnnerparty
Regular MemberPosts: 158Gear list
In reply to Ray Soares, May 1, 2012
Very nicely done. Looks very professional. I think they are all good, but the outdoor shots really impressed. That lens is good and seem to know how to use it. Very good!
 thejohnnerparty's gear list:thejohnnerparty's gear list
Sony RX100
zig123
Regular MemberPosts: 418
Re: Thank You
I primarily visit this forum each day to gain insight as to what other photographers are doing in the hope of learning something new as well as for inspiration. Your post succeeded in both counts.
After admiring your images, I can't wait to see my grandkids and trying my hand at doing what you've done so remarkably well.
Thanks,
Zig
Ray Soares
You are welcome zig :) nt
In reply to zig123, May 1, 2012
Ray Soares
AnthonyPK
Regular MemberPosts: 382
Re: You are welcome zig :) nt
Do i even have to say it? YES I do AMAZING job as always. Your photos really inspire me to take photos and work on my technique. The colors you get are always imressive.
http://www.flickr.com/photos/11353513@N08/
Nightwings
Forum ProPosts: 10,329
Fountain of youth
Your mom looks better at 80 than a lot of 60 year olds.
Nikon AF - One Shot ..... One Kill
Ray Soares
Lol nightwings! nt
In reply to Nightwings, May 1, 2012
Ray Soares
Horshack
Veteran MemberPosts: 3,810
Some PP notes
  1. 2 and #3 look a bit oversharpened to me, esp in the background areas. Also the blue tint for the sky looks unnatural to me and there is some untreated tint peaking through the flowers (or that's a large-radius sharpening halo, can't tell for sure).
