understanding exposure on d7000
Started Apr 30, 2012 | Discussions
crs-collectibles
Regular MemberPosts: 132
Apr 30, 2012
I am using a d7000 with the 70-300 vr lens. I had the exposure set to matrix, af-c 9 point. It seems like when the subject is near the exposure seems ok, but when the subject is far away it seems the exposure is over-exposed. Should I be using different exposure setting for different distance?
Thanks.
Nikon D7000
Nightwings
Forum ProPosts: 10,352
Here you go
In reply to crs-collectibles, Apr 30, 2012
No so much exposure as atmospheric conditions ... easily corrected with one click in CaptureNX2 ... or Photoshop
Nikon AF - One Shot ..... One Kill
PrasadIndi
Regular MemberPosts: 161Gear list
Re: Here you go
In reply to Nightwings, Apr 30, 2012
Cool... could you explain how can this be done in LR3?
 PrasadIndi's gear list:PrasadIndi's gear list
Nikon D3100 Nikon AF-S DX Nikkor 18-55mm f/3.5-5.6G VR Nikon AF-S DX Nikkor 35mm f/1.8G
crs-collectibles
Re: Here you go
That looks better. What click would that be? I was playing around with it in viewnx2 and it seemed to make a difference when I changed the exposure which led me to think it was an exposure issue.
Thanks.
Nightwings
Re: Here you go
Thanks.
CaptureNX2 has an adjustment called "Auto Levels" .... found under Ajust ---> Light. To be used with caution as it sometimes goes balistic giving undesirable results. Viewnx2 has no such function (that I am aware of). You have to play with the brightness/contrast. In your case, in viewnx2 I applied -30 brighness and +30 contrast and got a similar correction.... infact it's even more pleasing then my posted correction.
Nightwings
Re: Here you go
In reply to PrasadIndi, Apr 30, 2012
It's not, I don't think there is an Auto Levels equivalent...that I know of; this is why they want you to buy CS5...etc. Although I can do auto levels in my near decade old copy of photoshop 7 .... certainly PS elements has it.
But here is a quick and dirty edit in LR4
-1ev
+95 contrast
+56 whites
-51 blacks
OR something less convoluted
+7 whites
-83 blacks
Island Golfer
Senior MemberPosts: 1,573
Re: Here you go
Photoshop Elements 9 does the exact same thing with one-click of "auto levels". I just tried it. If the Dpreview upload was functioning (which it too frequently doesn't), I would have posted it.
truview
Ray Soares
Veteran MemberPosts: 3,064Gear list
Re: understanding exposure on d7000
To cut haze use a CPL filter!.
And / or in PP just increase a bit your structure (middle tone contrast) or contrast.
Best
Ray Soares
See my pictures at http://www.pbase.com/raysoares
 Ray Soares's gear list:Ray Soares's gear list
Nikon D7000 Nikon D4 Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II Nikon AF-S Nikkor 24mm f/1.4G ED Nikon AF-S Nikkor 85mm f/1.4G +1 more
fotolopithecus
Senior MemberPosts: 1,699Gear list
In reply to Ray Soares, Apr 30, 2012
Watch three videos at testcams.com called "does Nikon D7000 overexpose"
 fotolopithecus's gear list:fotolopithecus's gear list
Nikon D610 Tamron SP AF 90mm F/2.8 Di Macro Nikon AF-S Nikkor 50mm f/1.8G
crs-collectibles
Re: Here you go
In reply to Nightwings, May 1, 2012
Thanks.
Thanks I'll try that. When I tried, I got it to look fairly decent (I liked it) by changing exposure to -1.1 and contrast to +24.
crs-collectibles
In reply to Ray Soares, May 1, 2012
Best
Ray Soares
Thanks, I didn't even think about using the cpl filter I had. It didn't look that bad on the lcd screen. Got to learn to look at that more.
Rob801
Forum MemberPosts: 74Gear list
In reply to crs-collectibles, May 1, 2012
Here's one with "auto enhance" in Aperture. I think it looks very close to the results Nightwings second post (which looks slightly different than the first one... at least the water). I'm not sure why the file is so small... I'm still struggling a little with getting the actual size file up and downloaded on DPR.
I use the Auto Enhance quite a lot (maybe too much) on my RAW photos.
 Rob801's gear list:Rob801's gear list
Nikon D7000 Nikon AF-S DX Nikkor 16-85mm f/3.5-5.6G ED VR Nikon AF-S Nikkor 70-300mm f/4.5-5.6G VR Nikon AF-S Nikkor 50mm f/1.8G
