Street shots gf1/20/1.7 B&W [3 imgs] CS6
Started Apr 25, 2012 | Discussions
boyzo
Veteran MemberPosts: 4,516
Apr 25, 2012
Panasonic Lumix DMC-GF1
Marla2008
Senior MemberPosts: 2,295
Re: Street shots gf1/20/1.7 B&W [3 imgs] CS6
In reply to boyzo, Apr 25, 2012
LOVE the processing, very sleek !!
Marla
Jonathan Robson
Contributing MemberPosts: 843Gear list
Stunning work!
'When the seagulls follow the trawler, it's because they think sardines will be thrown in
to the sea.' - Eric Cantona
http://jrobfoto.com
 Jonathan Robson's gear list:Jonathan Robson's gear list
Canon EOS 5D Mark II Canon EOS 50D Nikon 1 V1 Sony Alpha 7R Canon EF 35mm f/2.0 +17 more
kgwhite
Senior MemberPosts: 1,329Gear list
In reply to boyzo, Apr 26, 2012
Nice photos but please explain how they would be different if processed using CS5? Are you using CS6 specific functionality? Just asking.
kw
http://www.thealamoproject.com/
http://www.pbase.com/kwhite
boyzo
In reply to kgwhite, Apr 26, 2012
On 2 images I used the new blur filter with CS6
I used Tilt Shift (vertically) to selectively blur specific areas while the main subject kept sharp
The Street artist could have been done in CS5 ie no Blur effect
I did use the Niksoftware COlorEFEX pro 4 on all images
kw
boyzo
In reply to Marla2008, Apr 26, 2012
Marla
Trick is to get the Color looking good before B&W conversion
Nik software helps along the way
Thanks for looking
Marla
vincent filomena
Veteran MemberPosts: 5,104Gear list
3rd shot is a story within a story,
within another story !
Vjim
 vincent filomena's gear list:vincent filomena's gear list
Panasonic Lumix DMC-LF1 Panasonic Lumix DMC-G5 Olympus PEN E-PL5 Olympus M.Zuiko Digital 45mm 1:1.8 Olympus M.Zuiko Digital ED 60mm 1:2.8 Macro +1 more
Aleo Veuliah
Forum ProPosts: 14,455Gear list
Good images, liked the black and white tones
Are you liking the CS6 ?
Simplicity is the ultimate sophistication.
God is the tangential point between zero and infinity.
Imagination is more important than knowledge.
God always take the simplest way.
 Aleo Veuliah's gear list:Aleo Veuliah's gear list
Panasonic Lumix DMC-ZS1 Panasonic Lumix DMC-GF1 Panasonic Lumix DMC-G2 Nikon 1 V3 Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS +3 more
boyzo
In reply to Aleo Veuliah, Apr 26, 2012
Yes Aleo I will upgrade to CS6
MadsR
Senior MemberPosts: 2,235Gear list
Wow (nt)
just wow
 MadsR's gear list:MadsR's gear list
Olympus PEN E-P1 Panasonic Lumix G 20mm F1.7 ASPH +2 more
kgwhite
Thanks for the info. I'm all for easier processing if the results are good and they clearly with these images.
kw
boyzo
Far easier than layers and normal filters and brushes the new filters let you achieve what you want with ease and you can change or reverse the effect.
kw
boyzo
Re: Street shots ....one more image
In reply to boyzo, Apr 28, 2012
jimboyvr
Senior MemberPosts: 1,191
Did you find the upgrade to CS6 worth it?
Lights
Veteran MemberPosts: 3,185Gear list
In reply to vincent filomena, Apr 28, 2012
Vjim
Yep it sure is. I like 'em all but that 3rd one is really intriguing.
http://www.pbase.com/madlights
http://barriolson.aminus3.com/
Like the Joker said: Why so serious?
A photo may be worth a thousand words but it takes up a lot more space on your hard drive.
boyzo
In reply to jimboyvr, Apr 28, 2012
Running the CS6 beta preview but will Upgrade to final
Its worthwhile yes.
