Great wide lens found
Started Apr 25, 2012 | Discussions
AshMills Contributing Member • Posts: 820
 AshMills's gear list:AshMills's gear list
Nikon D700 Nikon D800 Olympus E-M5 II Olympus E-M1 Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II +10 more
JulesJ
JulesJ Forum Pro • Posts: 39,266
Re: Great wide lens found
Owen
Owen Senior Member • Posts: 2,578
How much was the lens new in 1970?
Owen
Joseph S Wisniewski Forum Pro • Posts: 34,119
$26,000 in 1992...
I don't know. But Nikon was still building them to order about 20 years ago. I ordered one, and I believe it was $26,000. In advance, with a 9 month lead time.
Very much like having a child.
Rahon Klavanian 1912-2008.
Armenian genocide survivor, amazing cook, scrabble master, and loving grandmother. You will be missed.
Ciao! Joseph
http://www.swissarmyfork.com
 Joseph S Wisniewski's gear list:Joseph S Wisniewski's gear list
Nikon D3 Nikon D2X Nikon D90 Nikon D100 Canon EOS 5D Mark II +43 more
stephenmelvin Veteran Member • Posts: 4,547
Where is it now?
Did you order it for yourself? I assume for a company you were working for, with that kind of budget.
A little less messy, perhaps.
Ciao! Joseph
jon lake
jon lake Senior Member • Posts: 1,630
Wow. Where to get a CPL for that!!!
And yes, I know it wouldn't work properly!
 jon lake's gear list:jon lake's gear list
Canon PowerShot G12 Canon EOS-1Ds Mark II Canon EOS-1Ds Mark III Canon EOS 40D Canon EF 70-200mm f/4L IS USM +3 more
mandm Regular Member • Posts: 471
I used the 6mm 2.8 Nikkor in 1970
In the old days EPOI (Nikon distributor in the US), offered a 2 day class for owners of the 'F', it included lunch and the whole event was free. I attended in 1970 (I was 17 years old) in Minneapolis and the class was limited to 50 people so we all had a chance to use the equipment in the hotel conference room or outside in the courtyard.
One of the Nikon speakers told of using the 6mm 2.8 in Washington DC, he wanted to take a picture of the Washington Monument and the Lincoln Memorial while between the 2! He explained that he set the self timer, placed his camera facing up and ran to hide behind a tree. After doing a few pic's he noticed the park police watching him, they never stopped or asked him want he was doing. Today the swat team would be on him. He showed us the slides, great pic's as the 220 degree view showed the grass all around and the 2 monuments at each end in the same pic.
He also explained how good the coatings were on the Nikkor lenses and that the top coating was so hard you could rub out a lit cigar on it, and then he did!
mandmp; 100% of my income since 1972 has been due to a camera. My hobby turned into an enjoyable & profitable career.
 mandm's gear list:mandm's gear list
Nikon Df Nikon D750 Nikon AF Nikkor 50mm f/1.4D Nikon AF-S Nikkor 17-35mm f/2.8D ED-IF Nikon AF-S Nikkor 24-120mm f/4G ED VR +4 more
A little outfit called Ford...
For a specific project, modeling incident light.
At Ford, I used to end up on some pretty high budget projects.
The lens was for the object modeling system. That was about a million dollar toy. I gave Adrays one of the biggest single purchase orders in their history: it included 32 setups with Canon D30 DSLRs and 3 lenses per camera, about $160K. Those went into a sort of a geodesic dome structure. There were 8 PCs, each camera feeding four PCs. It could take a 30 angle view of a car, or other large object, in a single shot. Few hundred thousand for the software.
One configuration put 24 or 30 cameras in a circle, and we were doing "bullet time" years before "The Matrix".
The biggest purchase order I ever wrote was $14,000,000.
You've never worked for Ford.
Ciao! Joseph
Doug J Veteran Member • Posts: 8,914
Re: A little outfit called Ford...
Impressive, thanks for sharing Joe. One wonders if the lens isn't sitting in a warehouse somewhere with a fixed asset tag, inventoried twice a year and stuck on a shelf.
Doug
http://www.pbase.com/dougj/birds_birds_birds
stuck on a shelf...
I hope not. That would be a terrible fate for such a thing of beauty. It belongs either in use for some scientific application, or on display in a collection.
Although most of that lens's uses have been replaced by either stitching techniques, or a dodecahedron of cameras, it still has uses, when you need your > 180 degree sky dome to be taken in a single shot. We could get lighting on a flash exposure.
Ciao! Joseph
Hhhmmmmn?
JulesJ wrote:
Hhhmmmmn?
That added a lot to the conversation.
Ciao! Joseph
Behind the lens...
You wouldn't need a circular, because the lens is so wide that the matrix metering system and the focus aids are irrelevant. You can put a linear polarizer behind the lens.
That does have some scientific uses, but not with our application.
Ciao! Joseph
Awesome...
Impressive. I'd have been more leery of thermoshocking the lens. I bet he did it near the edge, where the glass is 50mm thick, not in the thin part in the center.
Cool.
I love stories like this. People like that distributor who went out of their way to inspire people, and it rippling down through the years.
Oddly enough, it was some Oly guys who had the most effect on me.
Ciao! Joseph
MaxTux Regular Member • Posts: 441
And the lens hood?
You wouldn't need a circular [CPL], because the lens is so wide that the matrix metering system and the focus aids are irrelevant. You can put a linear polarizer behind the lens.
And the lens hood? Was it included (or even built in? like on my 135/2.8?) or did you have to buy it separately?
MaxTux
jon lake
Re: And the lens hood?
I presume the angle of view is so broad that a lens hood would be in the field of view. Was flare a problem?
MaxTux
Re: And the lens hood?/Impossible
It a 6mm f2.8 to f22, angle of view of 220 degrees, it sees behind the lens! 12 elements in 9 groups, it produces a 23mm diameter circle on the film. Close focus is .9 feet. Weight is 11.5 lbs (5.2kg)! 236mm dia x 171mm long It has built in filters of L1A, Y48, Y52, O56, R60 and XO, use your thumb to rotate the built in disk to use the filter you want.
When this lens was introduced in 1970 Nikon already had a 6mm f5.6 Fish-eye that had a 220 degree angle of view that put a 21.6mm circle on the film. It has the same built in filters as the 6.3mm f2.8 does, but only weights 430g. and list price was $895.00 in 1969.
Nikon liked wide lenses in the 1960's and 70's, they had a 10mm f5.6 list $687.50, 8mm f2.8, 8mm f8.0 and a 7.5mm f5.6 list $499.50, all with an angle of view of 180 degree.
All list prices are from the February 1, 1969 Nikon price list.
nothing's impossible...
An inverted cone comes to mind. And keep the sun not over your left shoulder, but pointing straight at where the sun (normally) don't shine. At any rate, I'll never buy this lens unless they include the hood.
MaxTux
Boxbrownie Regular Member • Posts: 496
Thats interesting, where you a Photographer at Ford in the states?
Best regards David
 Boxbrownie's gear list:Boxbrownie's gear list
Nikon D7200
Diopter
Diopter Senior Member • Posts: 2,830
samples?
Neither linked article nor this nice conversation does not bring any samples and comparisons with the over-the-counter wide angle lenses.
Interesting.
ZorSy Veteran Member • Posts: 3,408
Beasts from teh past
Slightly longer 8mm f2.8 can be found here http://www.cameras.net.au/secondhand.php for $4250 if anyone interested and the review is on KR site.
cheers
have nothing to do with ECS, just a customer.
 ZorSy's gear list:ZorSy's gear list
Nikon D7100 Nikon D80
