Firmware 1.1.2 for Canon EOS 5D Mark III released
Started Apr 24, 2012 | Discussions
Rob72
Regular MemberPosts: 436Gear list
Apr 24, 2012
Hi,
Yesterday there was a new firmware released for the 5D Mark III. I don't see that this has been posted in this forum so I thougt I'd share it with you. Don't see anything relly major though.
The firmware 1.1.2 can be found here
http://usa.canon.com/cusa/professional/products/professional_cameras/digital_slr_cameras/eos_5d_mark_iii#DriversAndSoftware
Release notes:
Firmware Version 1.1.2 incorporates the following improvements and fixes.
1. Supports a new accessory, GPS receiver GP-E2.
2. Fixes a phenomenon where a pink cast may develop over the image when the shutter is completely pressed with the camera’s power turned off (by the auto power off setting).
3. Fixes a phenomenon where the camera operation stops after one shot when shooting in High Dynamic Range (HDR) mode.
4. Fixes a phenomenon where the Shooting Date/Time in the EXIF data of the image shows a later time than the actual shooting time.
5. Fixes the time zone for the Samoa Islands.
6. Corrects errors in the Finnish menu screen.
 Rob72's gear list:Rob72's gear list
altenae
Regular MemberPosts: 377
Re: Firmware 1.1.2 for Canon EOS 5D Mark III released
In reply to Rob72, Apr 24, 2012
No fix for the 200 and 800 mm IS sound ?
Enjoy Photography
http://www.wildlife-photos.net
ScottieC
Contributing MemberPosts: 643Gear list
I believe...
In reply to altenae, Apr 24, 2012
Canon is aware of it, and I vaguely remember that they are looking to see if it is certain batches of those lenses that have the issue. You can sign up for the email alert when to be notified once they determine the fix.
http://www.usa.canon.com/cusa/support/consumer/eos_slr_camera_systems/lenses/ef_800mm_f_5_6l_is_usm?pageKeyCode=prdAdvDetail&docId=0901e02480532d6b
Enjoy Photography
 ScottieC's gear list:ScottieC's gear list
Canon EOS-1D Mark II Canon EOS 5D Mark II Canon EOS 7D Canon EOS 5D Mark III Canon EF 85mm f/1.8 USM +8 more
cor20d
Regular MemberPosts: 160Gear list
Re: I believe...
In reply to ScottieC, Apr 24, 2012
Very disappointed that the v. 1.1.2 firmware update didn't fix this problem
The 200L is my favorite
 cor20d's gear list:cor20d's gear list
Canon EOS-1D Mark III Canon EOS 5D Mark II Canon EOS 30D Canon EOS 5D Mark III Canon EF 24mm f/1.4L II USM +15 more
UponQuai
Contributing MemberPosts: 654
It solved the leak
you have dry camera now
mick232
Contributing MemberPosts: 739Gear list
I like the way they refer to a simple bug as a "phenomenon".
 mick232's gear list:mick232's gear list
Sony Alpha NEX-5 Sony SLT-A99 Tamron SP AF 70-200mm F/2.8 Di LD (IF) MACRO Sony 75-300mm F4.5-5.6 Sony 85mm F2.8 SAM +17 more
5tve
Contributing MemberPosts: 623
In reply to mick232, Apr 24, 2012
Neat way of avoiding the word problem.
ka2ri
New MemberPosts: 2
In reply to Rob72, Apr 25, 2012
Anybody noticed a "clicking" noise on IS? After updating to new firmware 1.1.2, my 70-200mm f/2.8L IS USM lens started to make "clicking" sound when IS starts/ends.
Doug Searles
Regular MemberPosts: 184
When I went in, id my OS as Mac iOS, Lion 10.7, there was no firmware update. Why would that be? Any ideas?
Whelk
New MemberPosts: 14
In reply to Doug Searles, Apr 25, 2012
It only seems to be available if you select Windows as OS for now. I'll have to fire up the PC!
MASTERPPA
Contributing MemberPosts: 846
Shot a wedding this last weekend, 700 shots with 5DII and 2000 with 5D3.
I set the times to the sec with my computer.. At the end of the night, there times were barely 1 sec off after 10 hours. But on EXIF, they are around 1-2 MINUTES apart.. Guess I sure could have used the UPDATE before last weekend..
I was about to lose my mind, all my pics were out of order between the 2 cameras, had to manually move them in order.. UGH..
Rob72 wrote:
Hi,
Release notes:
igorphoto
New MemberPosts: 20
Just take it from 10.6
Igor
EduardoJB
New MemberPosts: 1
In reply to igorphoto, Apr 26, 2012
Any ideas why the difference between OS 10.6 and OS 10.7? 5D Mark II had same issue with firmware update. Some people said it's related ONLY to how the OS unzips the file
Whelk
New MemberPosts: 14
In reply to EduardoJB, Apr 26, 2012
I can't see it matters a jot, it's the same firmware and is platform independent. I think it has more to do with how the Canon bundle it with the platform specific software.
Bottom lone, if you download the FW and can unzip it and put it on your memory card then the camera will read it.
In the end I just downloaded the Win version to my mac and unzipped it there and it worked fine.
Wayne Newland
Forum MemberPosts: 89
In reply to mick232, Apr 27, 2012
Not such a strange way to state the issue.
Definition of phenomenon : an observable fact or event.
So it's much easier to say
"Fixes a phenomenon where the Shooting Date/Time in the EXIF data of the image shows a later time than the actual shooting time."
rather than
"Fixes an observable fact or event where the Shooting Date/Time in the EXIF data of the image shows a later time than the actual shooting time."
mick232
In reply to Wayne Newland, Apr 27, 2012
I didn't say it is wrong. But it is both unusual and an euphemism.
John
Senior MemberPosts: 1,291
In reply to mick232, Apr 28, 2012
And so it goes. New Camera, firmware update less than a month later.. One can only imagine the nightmare the 1DX will be since the 5D Mark III was an updated version of a mature camera... All new camera like the 1DX should be a hoot of firmware updates. Kind of odd that this continues with Canon each time they release a new camera.. What happened to field testing products...
