how to turn on focus peaking?
Started Apr 23, 2012 | Discussions
timewaster
Regular MemberPosts: 226
Apr 23, 2012
i was playing around with the nex 5n in a store.
went to the settings to try to enable focus peaking, but it is greyed out and disabled.
how do you turn it on?
LoneReaction
Regular MemberPosts: 492Gear list
Re: how to turn on focus peaking?
In reply to timewaster, Apr 23, 2012
You need to be in manual focus
 LoneReaction's gear list:LoneReaction's gear list
Sony Alpha NEX-5N Sony Alpha NEX-7 Sony Alpha 7 Sony E 35mm F1.8 OSS Sony FE 35mm F2.8 +5 more
blue_skies
Senior MemberPosts: 6,352Gear list
In reply to LoneReaction, Apr 23, 2012
Set Focus method to DMF or MF.
Then the focus peaking options become accessible.
Henry
Canon PowerShot S95 Sony Alpha NEX-7 Sony Alpha NEX-6 Sony Alpha 7 Sony E 18-55mm F3.5-5.6 OSS +27 more
timewaster
In reply to blue_skies, Apr 23, 2012
Henry
that's weird.
i'm pretty sure i switched it to MF (Also tried DMF).
Will check it again next time.
Mr Yozhik
New MemberPosts: 23
It has to be set to manual mode via the menu setting, not the button. Otherwise, the camera resets back to AF when you enter the menu.
nadamas
Regular MemberPosts: 186
In reply to Mr Yozhik, Apr 23, 2012
Could you please clarify that a bit? What causes the camera to reset back to AF from DMF?
timewaster
In reply to nadamas, Apr 23, 2012
what button are you referring to ? i was playing with the 5n not the 7.
LoneReaction
In reply to timewaster, Apr 24, 2012
This is strange.. I have the 5n and switch focus modes one of the shortcuts on the soft center button. You don't have to go to the main menu for the focus modes to work.
Anyway, the next time you're at a store, just change the focus to DMF or manual focus, then you can set peaking. If you use DMF you have to half press the shutter button before being able to manually adjust focus.
