LCD for filming
Started Apr 23, 2012 | Discussions
mitchino
New MemberPosts: 7
LCD for filming
Apr 23, 2012
I've got a 3 camera studio shoot coming up, the main cam is a 5d Mkii, the other two will be 60ds. The studio will be dark with theatrical lighting. Will my two camera operators be able to focus and compose shots ok only using the flip out LCDs? One of the cams will be on a slider, one on a fluid head. I'm trying to avoid coughing up for two external monitors or loupes.
Canon EOS 5D Canon EOS 60D
keane_
Regular MemberPosts: 387
Re: LCD for filming
In reply to mitchino, Apr 23, 2012
Never used it for video, but if you have access to an android tablet it might be worth looking at the following app:
http://dslrcontroller.com/
I have it working on a Chinese 7" tab and it's very useful for manual focus, with 10x view. It also has some new focus pull features which might come in handy.
dave_bass5
Veteran MemberPosts: 5,862Gear list
Re: LCD for filming
In reply to keane_, Apr 25, 2012
You should install Magic Lantern on your cameras, this will help enormously with focusing. Its what it was written for (originally).
Dave.
Gallery @
http://www.flickr.com/photos/davebass5/
http://davepearce.smugmug.com
Videos @ http://www.vimeo.com/user464364/videos
 dave_bass5's gear list:dave_bass5's gear list
Canon PowerShot S110 Canon EOS 5D Mark III Canon EOS 650D Canon EF 50mm f/1.4 USM Canon EF 100mm f/2.0 USM +7 more
paul13walnut5
Junior MemberPosts: 26
Re: LCD for filming
In reply to mitchino, Apr 25, 2012
Depends on a few factors.
Firstly, I find APS-C cameras slightly easier to manage for precise focus than the 5D2.
Secondly, accuracy is often down to the lenses in use, if it's L's or USM primes with nice wide long throw focus rings then it'll be easier. If it's budget zooms or AFD / micro-motor primes then it can be tricky as the rings are scratchy and very short throw.
Thirdly, old rules of depth of field come into play, keep your moving cameras wide and there's more depth of field latitude. Static cameras are probably better for tele shots where focusing is more precise.
Will the screens be up to the job?
Yes, so long as you get your dof & subject background seperation right, with large apertures it's usually quite easy to see if something is sharp or not, and with the long throw focus rings fairly smooth to alter focus (top tip, look up those silicon jar openers, they really dampen adjustments)
If you've got three cameras you can afford to earmark one as a wide catch all safety shot. Do the pick ups with the other cameras.
Three further bits of advice:
Calibrate exposure off of a grey card with cameras set to spot meter. F no's will not be the same, but centre of card metered centre spot should be consistent accross EV scale on each camera.
Calibrate Manual WB off same. Record 10s under unfiltered light with a QPcard or grey chart or similar. Makes post shot matching easy.
Clap in vision of all three cameras for pic/sound synch.
