GH2 Variable Aspect Ratio
Started Apr 23, 2012 | Discussions
Vlad S
Senior MemberPosts: 3,026Gear list
75 degrees
In reply to Jimbo70, Apr 23, 2012
Jimbo70 wrote:
I guess my question should have been; is the angle of view 75 degrees when the camera is in the native 4-3 ratio or 75 degrees in 16-9 ratio?
75 degrees is the diagonal angle of view. In the GH cameras it does not change with the aspect ratio because all of the aspect ratios fill in the same circle 21.58mm in diameter: you loose a little vertically, but you gain a little horizontally at the same time.
You see more on the sides because the horizontal angle of view of a 14mm lens on the micro 4/3 sensor is 63 degrees in 4:3, and 68 degrees in 16:9.
For comparison, the diagonal angle of view of a 28mm lens and FF sensor is also 75 degrees, but the horizontal AoV is 65.5 degrees, which is wider than 4:3 and narrower than 16:9 on the ยต4/3 sensor, as expected.
Vlad
 Vlad S's gear list:Vlad S's gear list
Olympus OM-D E-M5 Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS Olympus M.Zuiko Digital ED 9-18mm 1:4.0-5.6 Panasonic Lumix G 20mm F1.7 ASPH Panasonic Lumix G Vario 100-300mm F4-5.6 OIS +2 more
Jimbo70
Regular MemberPosts: 340Gear list
Re: 75 degrees
In reply to Vlad S, Apr 23, 2012
Vlad
Thank you, I didn't realize such an innocent question could cause such a discussion.
 Jimbo70's gear list:Jimbo70's gear list
Fujifilm X20
Detail Man
Forum ProPosts: 14,837
The Angle of the Dangle is inversely proportional to the Heat of the ...
Vlad
Why not submit any questions you may have surrounding "Depth of Field" for a real imbroglio ...
Mike Ronesia
Senior MemberPosts: 2,494Gear list
Re: Here are your angles
In reply to Adventsam, Apr 24, 2012
Adventsam wrote:
14mm in 16:9 is 25mm
7mm in 16:9 is 12.5mm
Horizontal FOV!
So what does 12.5 correlate to in horizontal degrees? A square room would be 90 degrees between walls when in the corner. The fish eye states 180 degrees but I don't know if they are talking corner to corner or if if it means 180 degrees as in half a circle.
It's easier to ask for forgiveness then to ask for permission.
 Mike Ronesia's gear list:Mike Ronesia's gear list
Panasonic Lumix DMC-GF1 Panasonic Lumix DMC-GH2 Panasonic Lumix DMC-GH3 Panasonic Lumix DMC-GM1 Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS +9 more
Detail Man
Re: Corrected: GH2 Image Sensor Diagonal and Horizontal Crop Factors
In reply to Steen Bay, Apr 24, 2012
Steen Bay wrote:
Detail Man wrote:
Shouldn't it also be taken into account that the effective diagonal of the FF sensor is reduced when the native 3:2 FF image is cropped to 4:3 and 16:9? I'd say that both the diagonal and horizontal crop factor is 2.0x when shooting 3:2 images with the GH2, and less than 2.0x when shooting 4:3 and 16:9 images, because the multi-aspect ratio GH2 sensor uses the full image circle with all three aspect ratios, whereas the FF sensor only uses the full image circle when shooting 3:2 images.
All Diagonal Crop Factors :
4:3 - Crop Factor = 2.069320
3:2 - Crop Factor = 2.087004
16:9 - Crop Factor = 2.087553
So, none of them are exactly 28mm, all of them are a little bit "narrower" than 28mm (in terms of the Field of View), and the 4:3 aspect-ratio mode is the "widest" of them all (by a miniscule amount, anyway), having the smallest Crop Factor.
All Horizontal Crop Factors (corrected):
4:3 - Crop Factor = 2.586650
3:2 - Crop Factor = 2.508267
16:9 - Crop Factor = 2.395354
The 16:9 aspect-ratio mode is clearly the "widest" of them all, having the smallest Crop Factor.
So 14mm is not 14mm. It is 14mm multiplied by the Crop Factors listed above.
Do the math ... I used a 3.63 Micron pixel-pitch and the JPG sizes from the GH2 Op. Instructions.
OK. If cropping a 3:2 FF image to 16:9, then the effective sensor diagonal is reduced from 43.267mm to 41.3mm, and the effective crop factor between FF and GH2 (with a 21.63mm image circle) is therefore 1.91 when shooting 16:9 images. For 4:3 images the effective crop factor is 1.85 (40.0mm / 21.63mm), and when shooting 3:2 images the crop factor is 2.0 (assuming that the GH2 uses the full 21.63mm image circle with all three aspect ratios).
35mm equivalent focal length has nothing whatsoever to do will cropping a 3:2 aspect-ratio full-frame of physical dimensions 36mm width, 24mm height, and 43.267mm diagonal. Nothing ...
It is derived by comparing any given image-sensor's (aspect-ratio mode relevant) active-area physical width, height, or diagonal dimensions with that of 35mm full-frame size (listed above).
Since:
FOV = (2) x ( Arctangent ( ( S ) / ( ( 2 ) x ( L ) ) ) )
where:
FOV is Field of View;
S is the frame-size (either width, height, or diagonal);
L is the Focal Length.
Re-arranging the identity stated above yields:
EFL = ( S ) / ( ( 2 ) x ( Tangent ( ( FOV ) / ( 2) ) ) )
where EFL is the 35mm Equivalent Focal Length; and
S is the width, height, or dagonal dimension of 35mm full-frame.
Calculate the physical dimensions of the (aspect-ratio relevant) active area for any image-sensor in order calculate these things, and then compare those particular dimensions with the physical dimensions of 35mm full-frame. That is all that there is to it. Nothing more; nothing less ...
Bart Hickman
Veteran MemberPosts: 7,089Gear list
They don't call you the detail man for nothing!
In reply to Detail Man, Apr 24, 2012
We're talking about 1% variation here--I bet the lens itself is more than 1% off of 14mm anyway.
Horizontal Crop Factors:
4:3 - Crop Factor = 1.721763
3:2 - Crop Factor = 1.736477
16:9 - Crop Factor = 1.736934
14mm is 14mm. I assume you mean the f/l in FF that has the same FOV is 14mm times those factors. Isn't the important thing the FOV stays constant (give or take 1%) as you change the aspect ratio on the GH2?
Bart
http://bhimages.zenfolio.com
 Bart Hickman's gear list:Bart Hickman's gear list
Sony Alpha NEX-6 Pentax smc FA 50mm F1.4 Sony E 55-210mm F4.5-6.3 OSS Sony E 10-18mm F4 OSS Sony E 16-50mm F3.5-5.6 PZ OSS +9 more
Detail Man
Re: They don't call you the detail man for nothing! - Gee, Thanks !
In reply to Bart Hickman, Apr 24, 2012
Indeed. When I run calculations I figure that it really does not hurt to show the answers to a few digits. No offense intended towards any persons who may chop off digits for justifiable reasons ...
14mm is 14mm.
The OP asked how close his 14mm (actual) Focal Length lens would be to a (35mm equivalent stated form) 28mm lens. I was simply answering the question by calculating and providing the Crop Factors involved - based on DxOMark's statement that the GH2 pixel-pitch is 3.63 Microns, and using the pixel-dimensions for the GH2 (JPGs) in various aspect-ratio modes that are found in the GH2 Operating Instructions.
The product of (any) Focal Length multiplied by those Crop Factors equals the (35mm equivalent) Focal Lengths for any aspect-ratio on the GH2 - based upon DxOMark's 3.63 Micron pixel-pitch specification, that is, but Adventsam has referenced a Panasonic "spec sheet" for the image sensor which states that the GH2 image-sensor's pixel-pitch equals 3.8 Microns (4.7% larger). See:
MN34070 Data: http://www.semicon.panasonic.co.jp/en/catalog/cat/pdf/T12013CE.pdf?bcsi_scan_0003A2F8FAC96BED=0&bcsi_scan_filename=T12013CE.pdf
Well, it is true that the (diagonal only) FOV is relatively constant on a multi-aspect-ratio image-sensor. I assumed that the OP knew that already - and that the OP (similar to many DPR forums readers in the past) may have been asking about the (horizontally referenced) "width" (as in FOV, or as expressed as 35mm equivalent Focal Length).
The matter of how the GH1 and GH2 differer from all other M43 cameras is an interesting one. The percentage differences in the relevant specifications of common concern were covered here:
http://forums.dpreview.com/forums/read.asp?forum=1041&message=40326952
dp88
Regular MemberPosts: 330
a lot of "photographers" don't know about compression/expansion
They think fov is just about making things closer or farther away, or wide angle lenses are just to fit more things in a frame.
Vlad S
Harder to tell for fisheye
In reply to Mike Ronesia, Apr 24, 2012
In the case of Panasonic 8mm lens 180 degrees is the diagonal AoV: the arc shown between opposite corners will span the full 180 degrees. What it is going to be along the sides is hard to tell: the relation between the points in the image and the points in space is described by a mapping function, and there are many different ones that fisheye lenses can use. If someone learns the mapping function of the Panasonic or Samyang lenses then it will be possible to tell the AoV side-to-side.
Detail Man
Re: a lot of "photographers" don't know about compression/expansion
In reply to dp88, Apr 24, 2012
At the same time, the phrase "perspective distortion" is in itself a misnomer - in that it is not the lens-system that (necessarily) "causes" the distortion (right?). It is the proximity to the subject-matter, and the physical perspective that exists as a result - combined with the fact that human vision using two eyes (at some subject distances, anyway) serves to partially reduce our perceptual awareness of the differences in perspective arising out of a close proximity to subjects viewed ...
Please feel free to educate and/or to correct me if you have relevant/interesting knowledge here !
Steen Bay
Veteran MemberPosts: 6,188
Since:
where:
The active area of a FF sensor when shooting images with the three different aspect ratios is :
4:3 - 32x24mm - diagonal = 40.0mm and crop factor = 1.85 (40mm/21.63mm = 1.85)
3:2 - 36x24mm - diagonal = 43.3mm and crop factor = 2.00
16:9 - 36x 20.25mm - diagonal = 41.3mm and crop factor = 1.91
Anyway, that's the comparison I find most relevant, if talking different aspect ratios and FF vs. GH2.
