X-Pro 1 focus tip for moving objects
Started Apr 21, 2012 | Discussions
cafemonaco Junior Member • Posts: 43
Although I've mentioned it in a few replies to posts, I thought it might be helpful just to reiterate a simple technique that allows X-pro 1 users to get a very high percentage of pictures in focus for objects that are approaching you (eg kids, cyclists, cars etc).
A fuller explanation is at http://picabroad.com/ but, very briefly, when the object is on the AF patch just depress the shutter all the way down in in one movement - do not half press and wait for focus as you would on a DSLR.
Works beautifully.
ha_c Regular Member • Posts: 104
Re: X-Pro 1 focus tip for moving objects
YES, that's the way to get good information out to everyone - in its own thread with a telling 'subject'. i missed your earlier notes with a possible solution to the problem with focusing on moving targets. thank you very much.
/ hac
PS
http://picabroad.com/2012/04/10/fuji-x-pro-1-autofocus-trick/
on moving targets you set the X-Pro on AF-S (NOT AF-C) and press the shutter down all the way in one movement and wait for the shutter to fire.
(unknown member) Veteran Member • Posts: 3,348
I've tried this and it does work - at least it does so within the limits of the overall system.
fluxism Contributing Member • Posts: 505
I'm grateful for this tip, but I guess it means focal point has to be in center of frame?
 fluxism's gear list:fluxism's gear list
Fujifilm X-Pro1 Fujifilm X-E2 Fujifilm X-Pro2 Fujifilm XF 35mm F1.4 R Fujifilm XF 18-55mm F2.8-4 R LM OIS +2 more
Dkaplan74 Regular Member • Posts: 124
Does this work for X100 as well?
redzob Regular Member • Posts: 141
Just returned from a rugby match and have to say that this technique appeared to work quite well. Early days yet, but managed to track a fair few action shots using the 60mm at f2.4 with a 3 stop ND filter on the front. Also tended to use the OVF for timings. Wish I'd been able to get to the touchline much earlier, but the poor quality shots are my fault, not the XP1 - I just need to practice....
 redzob's gear list:redzob's gear list
Sony RX100 Fujifilm X100S Fujifilm X-Pro1 Fujifilm XF 35mm F1.4 R Fujifilm XF 60mm F2.4 R Macro +7 more
kevin camera Junior Member • Posts: 42
thanks for posting article.
went out to try it today on some fast moving bikes... was able to focus on the object!
Works beautifully.
mhohman Junior Member • Posts: 40
I nailed this focus using this technique. The guy on the motorcycle was driving away from me... Glad it worked. Of course, you can move the focus point to anywhere on the frame to get the composition you want.
I just wish this technique worked with the Area AF Mode but that never seems to find the subject, no matter what. Arg.
Jeff Charles Veteran Member • Posts: 7,514
Yes
Jeff
 Jeff Charles's gear list:Jeff Charles's gear list
Sony Cyber-shot DSC-RX100 III Fujifilm X100T Olympus E-M1 Fujifilm X-E2 Olympus M.Zuiko Digital ED 40-150mm 1:4-5.6 R +5 more
Davidgilmour Senior Member • Posts: 1,397
Could you please tell it more exacty?
You mean if I see an interesting person walking on the street, I just point my Fuji to that person, compose and press the shutter button all the way down, without focusing?
I.e., just like it's a point and shoot camera?
 Davidgilmour's gear list:Davidgilmour's gear list
Fujifilm FinePix X100 Fujifilm XF 35mm F1.4 R Fujifilm XF 60mm F2.4 R Macro Sony RX1 Fujifilm X-A1 +1 more
baobob
baobob Veteran Member • Posts: 7,222
Works very well with my X100
Sony RX100 Olympus Tough TG-4 Fujifilm X-T1 Nikon D7200 Fujifilm X-T10 +12 more
well, when you press the shutter all the way down, you're already issuing the focus command.
so it's not taking a shot "without focusing" but it's more like "capturing the picture immediately after focus"
Lol, so it IS a point and shoot after all
gambofoto New Member • Posts: 18
Great shot, mhohman.
Zarniwoop1985
Zarniwoop1985 Regular Member • Posts: 171
Great shot! Those pigs don't look very happy though.
 Zarniwoop1985's gear list:Zarniwoop1985's gear list
Canon PowerShot G10 Panasonic Lumix DMC-LX3 Fujifilm FinePix X100 Fujifilm X10 Sony RX100 +18 more
intruder61
intruder61 Veteran Member • Posts: 3,064
actually, known as a compact....just above the P&S
Francis Harrison New Member • Posts: 12
First of all, sincere thanks for the tip, much appreciated. One question though: isn't there an added risk of camera movement if you "mash down" on the button as you inevitably have to do? That would be the only downside...
James Ito Regular Member • Posts: 103
Yep, it's identical to my Canon SLR's option to give priority to focussing i.e. when the shutter release is pressed, "obtain focus and then release the shutter". Personally, I've never found a use for the other option which is "try to focus but release the shutter regardless".
James Ito
 James Ito's gear list:James Ito's gear list
Canon EOS 7D Fujifilm X-Pro1 Fujifilm X-M1 Fujifilm X-T1 Canon EF 24mm f/2.8 +22 more
Adrian MH New Member • Posts: 16
This is great news! I am contemplating buying the Fuji 35mm lens - so far only have body + my CV Nokton 35mm/1.4
Would this technique be helped or hindered by using a soft-release button?
morganb Regular Member • Posts: 116
I don't own this camera but I have had fujis.in the past. Is there an option to disable the half shutter focus and force it to only react to full press?
 morganb's gear list:morganb's gear list
Nikon D600 Nikon AF-S Nikkor 14-24mm f/2.8G ED Tamron SP AF 180mm F/3.5 Di LD (IF) Macro Nikon AF-S Nikkor 50mm f/1.8G Nikon AF-S Nikkor 24-85mm F3.5-4.5G ED VR +1 more
