Are there any Leica M lenses that don't mount on NEX-7
Started Apr 20, 2012 | Discussions
GeorgeD200 Regular Member • Posts: 388
I'm thinking about buying an NEX-7 as a digital body to use my Leica M and screwmount lenses on. I can't afford an M9 or M8.2. M8 cost more used than the NEX-7, and give inferior IQ, so they're out, too. I want APS-c and EVF. For the cost of NEX-5n and the EVF, I might as well buy the NEX-7. I also like the controls and lines better. Call me silly, but the lens mount circle that exceeds the body rectangle of the NEX-5, etc. I find terribly ugly.
My lenses:
Voigtlander 21mm f4 Color-Skopar (Cosina-made)
Leitz Summicron 35mm f2 M-mount
Leitz Summicron 5cm f2 M-mount collapsible
Tokyo Kogaku Simlar 5cm f1.5 m39 screwmount
Leitz Summicron 9cm f2 M-mount
Nikon 105mm f2.5 m39 screwmount
I'll probably also buy a Nikon adapter for my Nikon 50mm f1.2 AIS. I might get other Cosina-Voigtlander lenses, like the 15mm, but I'll probably never buy a Leitz or Zeiss super-wide. I'll shoot mostly in B&W, so I doubt I'll see any of the color shifts that others have reported.
Anything I should know about before I take the plunge? I'm not really interested in any other Sony glass right now, I just want a back for my legacy lenses. I know this has been covered other times, but it's hard to sift through all of the NEX posts to find relevant threads.
Sony Alpha NEX-5 Sony Alpha NEX-5N Sony Alpha NEX-7
wll Veteran Member • Posts: 4,821
Re: Are there any Leica M lenses that don't mount on NEX-7
Any lens that will fit on a Leica M mount will fit on a NEX series camera with the M mount adapter. The registration distance will be the same as a Leica to match the Leica camera registration distance.
Everything will work fine.
wll
Joe S2001 New Member • Posts: 18
It pays to be careful with the collapsible lenses to avoid collisions and damages. I haven't heard a discussion of what works and what can't be collapsed. I have a 50 Summicron that looks very close and assume a old 50 Elmar would not work as it protrudes even further.
Bruce Bowman Contributing Member • Posts: 572
Don't be too quick to eliminate the -5N until you've tried it (Sony Store?). It's a great camera.
5N+EVF = 7-$250. Essentially you're paying $250 for the extra pixels, a slightly larger body and an EVF that's built-in keeping the flash mount free. I think the value of the -7 supports the price compared to the -5N. And the -7 is a great camera. But the -5N is a great camera too. You owe it to yourself to handle both before spending your hard earned $$$.
Bruce
 Bruce Bowman's gear list:Bruce Bowman's gear list
Panasonic Lumix DMC-LX5 Sony Alpha NEX-7 Sony E 18-55mm F3.5-5.6 OSS Sony E 16mm F2.8 Pancake Sony E 30mm F3.5 Macro +14 more
FERNANDO FERNANDEZ-BOLANOS Forum Member • Posts: 67
in 4 days i have tested the following leica lenses
28 35 50 135 M
21 35 60micro 180 apo R
retina reflex s k lenses 28 35 50 85 135 200
they all performed very well
also, on the leica lenses i noticed some moire and some softness when blowing up some of the shots at wide openings .they tend to go away as you close down the lens .
now, the adapters may be part of some softness . they are not novoflex adapters but planing to buy them for the m and r when i go to europe next month where they sell for 100 euro ,way below the asking here in the usa .
my current adapters are metabones for m and fotodiox for r
$85 and 29 respectively
the dkl adapter was 29 and so far so good .
caldna New Member • Posts: 8
I recently did a review of the Leica M to NEX macro tube helicoid adapter sold by cardany_chan on eBay. It's a clone of the more well known Hawk's Factory helicoid adapter, but cheaper. You can read my review here:
http://forums.dpreview.com/forums/readflat.asp?forum=1042&message=41230179
blue_skies
blue_skies Veteran Member • Posts: 9,638
My lenses:
All your lenses will work, but you may want to consider the Nex-5N.
E.g., the CV21 can be used on the Nex-5N without post-processing.
The CV21 on the Nex-7 requires post, CornerFix, etc.
The wider angle RF lenses are showing color (magenta) case on the Nex-7, and the edges turn fuzzy. Edge softness is related to field curvature and subject distance, but it is more pronounced on the RF lenses than on e.g. the Sigma lenses. (You can see the edges being soft in all three images below).
See these images:
Henry
Sony Alpha NEX-6 Sony a6000 Sony a5100 Sony Alpha 7 II Sony DT 18-55mm F3.5-5.6 SAM +33 more
fermy Veteran Member • Posts: 3,168
There is nothing to be afraid of with collapsible lenses. The lens will not hit the sensor when collapsed, only a baffle around it. A simple rubber band will prevent the lens from collapsing too far and you will get the best of both words: completely safe operation and small size. My impressions of collapsible Industar-22 are here: http://forum.mflenses.com/industar-22-t48796.html
esophoria Regular Member • Posts: 142
NEX-7: When using an adapter with M9 lenses...is the exif data passed through? Specifically, when processing the pictures can you see the f stop, ISO, shutter speed, etc.
 esophoria's gear list:esophoria's gear list
Leica Q Leica Macro-Elmar-M 90mm f/4
Mark_McD Senior Member • Posts: 1,759
No, adapters are mechanical. Metering works because it's TTL but you'll only have your ISO, shutter, etc. no aperture information will be captured, or lens tagged.
 Mark_McD's gear list:Mark_McD's gear list
Sony Alpha NEX-5 Sony Alpha 7 Sony E 18-55mm F3.5-5.6 OSS Sony E 16mm F2.8 Pancake Sony DT 35mm F1.8 SAM +6 more
peter_no Regular Member • Posts: 151
I've tested the following lenses on a NEX-7 using a Novoflex adapter and they all work fine:
CV 15/4.5
Leica 24/2.8 ASPH
Konica Hexanon 28/2.8
Leitz 35/2 pre-ASPH v.1
Leica 35/2 ASPH
Leica 50/1.4 ASPH
Leica 75/2 ASPH
Leitz 90/2 pre-ASPH (E55)
capricho72 Forum Member • Posts: 62
Leica rangefinder lenses will perform better when mated with the sensor used on the NEX 5-N rather on the NEX 7. Here's my setup:
Photoedit1 New Member • Posts: 1
I am way late to this thread but I thought I would add my experience with the Nex-7 and legacy Leica lenses.
I have a Metabones adapter because the Novoflex was out of stock. My Leica 21mm f3.4 Super Angulon and my Leica 28mm f2.8 Elmarit DO NOT fit on the camera with the adapter. Both of them hit the plastic housing for the sensor. So far I have used my Leica 35 f2, Leica 50 f1.4, Leica 90 f2.8, and my Leica 135 f4 and they all work perfectly. The wides do not. Could it be the adapter?
CameraTest Forum Member • Posts: 74
CV 15/4.5
Did those images need software correction please?
Besides the Voigtlander, another lens I am also considering is the Leica 21mm /f4 Super Angulon, where the same question would apply.
I do need a wide or super wide, which need not be fast, but I want to avoid too much (or any?) post processing.
Thanks.
Euell Senior Member • Posts: 1,815
CameraTest wrote:
CV 15/4.5
Thanks.
The NEX 7 sensor will require the use of Corner Fix or similar corrections in post with many wide rangefinder lenses.  Maybe the upcoming A6000 will be better, but the NEX 5n, 5r and 6 all do quite well with wide angle rangefinder lenses, although I suspect not the CV 15mm.  I use a CV 21mm f4 on a NEX 6 without having to make corrections for smearing or color shifts in post.
 Euell's gear list:Euell's gear list
Sony RX100 Canon EOS 7D Sony Alpha NEX-5 Sony Alpha NEX-6 Sony a6000 +15 more
Lightshow
Lightshow Veteran Member • Posts: 4,466
wll
That is not a guarantee that it will mount on the NEX-7 or other APS-C body, the Jupiter 12 for example has a bulbous rear element that contacts the plastic shroud that surrounds the sensor, so it will not work properly, it does work fine on the A7(r).
 Lightshow's gear list:Lightshow's gear list
Sony Alpha NEX-7 Sony Alpha 7R +1 more
Euell wrote:
CameraTest wrote:
CV 15/4.5
Thanks.
Euell, is there any reason to believe that the CV 21mm f4 would behave differently on a NEX-7? In which case I might go in that direction.
CameraTest wrote:
Euell wrote:
CameraTest wrote:
CV 15/4.5
Thanks.
Yes, as reported here in other threads, there are problems on the NEX 7, although the CV 21mm Ultron seems to work OK on the NEX 7.
GXRuser Contributing Member • Posts: 656
My lenses:
I think the Nex-6 is the best Sony APS-C format camera for sharpness and avoiding magenta color shifts, especially with wide angle lenses.
The other camera to consider ia a Ricoh GXR with the Mount module.
