Tripod for D700
Started Apr 20, 2012 | Discussions
mukNY Regular Member • Posts: 151
Tripod for D700
I recently upgraded to a D700 and my old tripod isn't sturdy enough for it. I am looking for something that is small, light and does not break the bank. I am looking at the 190CXPRO4. Do any of you use it (or something similar) with a D700? What would be the biggest lens I could use it with? I cannot imagine ever needing anything larger than a 70-200. Any help is appreciated!
Marko
 mukNY's gear list:mukNY's gear list
Nikon D700 Nikon AF Nikkor 20mm f/2.8D Nikon AF Nikkor 50mm f/1.8D Nikon AF Nikkor 85mm f/1.8D Nikon AF-S Nikkor 24-120mm f/4G ED VR +1 more
Nikon D700
Fred Mueller Senior Member • Posts: 2,468
Re: Tripod for D700
I have the 055 alu three section - so can't tell you much about your actual model, but the Manfrotto "Pods" are good for the price and my aluminum unit is very solid. If I was carrying it any real distance I would want lighter, but for ripping off 7-9 frame brackets of interiors with a D700 and 14-24 typically, I don't think I need to spend more ...
I have an Acratech ball head fitted now. I was NOT too keen about the Manfrotto BH I got originally (498??). Basically I think Manfrotto's tripods deserve better heads ...
Robin Casady Forum Pro • Posts: 12,898
Re: Tripod for D700
Then when you upgrade to a D800 in a few years you will have to buy better tripod.
Follow this advice and save yourself some money in the long run.
http://bythom.com/support.htm
I've been using the same Gitzo tripod for about a decade and cannot foresee ever needing to upgrade it. Although tripods are large, they are not heavy when compared to a bag of lenses. The 190CXPRO4 looks far to flimsy to be of much use.
Robin Casady
http://www.robincasady.com/Photo/index.html
newtoy Regular Member • Posts: 391
Re: Tripod for D700
Marko
Sorry, but small, light, doesn't break the bank do not co-exist with study enough. I find my Gitzo 3 series with Acra-Swiss Z Ball only marginally OK with the D700 and 70-200. Using a laser pointer hard mounted on the hot shoes. I can see movement on the lizer marker at around 20 feet when the mirror flip.
 newtoy's gear list:newtoy's gear list
Nikon D70 Nikon 1 V2 Fujifilm X-T1 Nikon D810 Nikon AF-S DX Nikkor 16-85mm f/3.5-5.6G ED VR +23 more
mukNY OP Regular Member • Posts: 151
Re: Tripod for D700
I looked at the carbon fiber version of the 055 too. I like that it is a bit taller, but this makes it also less convenient for traveling.
Thanks for the ballhead tip.
Re: Tripod for D700
I should have been a bit more specific. I am looking form something for travel, not for studio use. I realize that lighter usually means less stable, but it also means that I am much more likely to actually take it with me.
gsmith08 Regular Member • Posts: 257
Re: Tripod for D700
When I got my D700 several years ago I too decided on what looked to be a more affordable 190CXPRO4 tripod with a RRS ball head. The head was excellent but the tripod wasn't even close to supporting my longer lenses and upgraded to a Manfrotto 055CXPRO3 carbon fiber which is excellent. And, to be honest went for an even more expensive but not sure if it is any much better Gitzo tripod a year later. Cheers
Marko
 gsmith08's gear list:gsmith08's gear list
Leica SL (Typ 601) Leica SL 24-90mm F2.8-4
Al Giordano
Al Giordano Senior Member • Posts: 1,130
I just purchased....
I just purchased this Carbon Fiber baby on Ebay:
http://www.ebay.com/itm/FT-6827A-Pro-Camera-Carbon-Fiber-Tripod-Ball-Head-Kit-/130270299838?pt=US_Tripods&hash=item1e54b706be
It's rated at 26lb load capacity and has a decent ball head. I thought $221 for a Carbon Fiber was a really good deal! It's not too heavy either and comes with a travel case.
 Al Giordano's gear list:Al Giordano's gear list
Nikon D810 Sony Alpha 7 II Nikon AF-S Nikkor 16-35mm F4G ED VR Nikon AF-S Nikkor 24-70mm f/2.8G ED Nikon AF-S Micro-Nikkor 105mm f/2.8G IF-ED VR +10 more
iain gilmour New Member • Posts: 14
Re: Tripod for D700
I've just put my 055CXPRO4 in my suitcase ready for an upcoming trip. As I do a lot of long exposure work, a solid tripod is essential and the 055CXPRO4 fits the bill for the D700, the 190 series are not sturdy enough. One tip, buy some spikes.
Marko
 iain gilmour's gear list:iain gilmour's gear list
Nikon D800 Nikon AF-S Nikkor 16-35mm F4G ED VR Nikon AF-S Nikkor 50mm f/1.4G Nikon AF-S Micro-Nikkor 105mm f/2.8G IF-ED VR Nikon PC-E Nikkor 24mm f/3.5D ED
Gazphotos Regular Member • Posts: 140
Re: Tripod for D700
This is good advice. Buy a Really Right Stuff tripod and ball head and never look back!
Garry
Lihkin
Lihkin Senior Member • Posts: 2,374
Yep
RRS and BH-55 ballhead (or a Kirk etc.) are the way to go. I know the price seems high ($1400 for the tripod/ head combo), but this will last a lifetime, unlike the D800 that will be worth half its value in 3 years time.
Nikhil
http://www.lihkin.net
 Lihkin's gear list:Lihkin's gear list
Nikon D800E
Revision Contributing Member • Posts: 828
Re: Tripod for D700
The 190 is too light. The 055 will do. Thom's advice makes no sense to me. It is very costly advice and one tripod does not fit all tasks. I have a very heavy sturdy and relatively cheap tripod for studio use and an 055 for travel. This works very well for me. Manfrotto heads I dislike and their plates are unsafe. I have a Markins M20 and a Manfrotto 486 with a Markins plate for my monopods.
Best Regards,
Renato
'The world is going to pieces and people like Adams and Weston are photographing rocks.' Henri Cartier Bresson, in the 1930's
Vladi Stoimenov
Vladi Stoimenov Regular Member • Posts: 420
Re: Tripod for D700
Consider SIRUI-tripods, excellent products.
I have N1004 tripod (aluminium) + K20x head for my D7000. I use them as a travel kit,
top product!
N-serie can be transferred to a monopod.
Aluminium tripods are a little more heavy but inexpensive.
I bought N1004 + K20x at Amazon.de, please check Amazon.com
Vladi
 Vladi Stoimenov's gear list:Vladi Stoimenov's gear list
Nikon D90 Nikon D610 Nikon AF-S Nikkor 14-24mm f/2.8G ED Nikon AF-S Nikkor 50mm f/1.4G Nikon AF-S Micro-Nikkor 105mm f/2.8G IF-ED VR +5 more
clickshots Regular Member • Posts: 444
Re: Tripod for D700
I'm really suprised to read that I use a GT3530s + Markins Q20 with a D3/300mm ok. Never had an issue with the 70-200mm at all.
MarcAZ New Member • Posts: 11
Re: Tripod for D700
I have the same set up and can highly recommend Gitzo GT2541 &
GH2780QR
Its the perfect balance between size and sturdiness.
 MarcAZ's gear list:MarcAZ's gear list
Nikon Coolpix 4500 Fujifilm FinePix S5 Pro Nikon D7000 Nikon D800 Nikon AF-S DX Nikkor 35mm f/1.8G +5 more
JukkaV Regular Member • Posts: 125
Re: Tripod for D700
I'm using 190XB with D700. It's OK tripod, but I'd say that it's about minimum for D700.
I have used that tripod with Samyung 650-1300 f/8-16 and 70-200mm f/2.8 sigma objectives and it is okay.
As others have said, I'll say again. Get a good tripod. If you buy a good tripod, you can use it decades. It doesn't get old as body does. Get for example Manfrotto 055 series tripod and you will easily use it 30 years.
Tip 2: Also get a good head. Good tripod with poor head is pain to use, and also will be shakier.
If you have used 2000+ euro/dollars for body, you should be able to use ~500 euro/dollar to tripod+head. Good tripod will grow with you. And give a growing room to you.
If I would be buying a tripod, I'd get probably get Manfrotto 055XPROB tripod + 498 RC2 head. Or some similar kit.
Bob Moulton Regular Member • Posts: 122
Re: Tripod for D700
Have you considered the CF Induro ,line or the Gitzo explorers? Either will work for you and the indoors come with a spike set and a case..I've used a #214 induro with Nikon 7000 and dobro with an 80-200 lens with no problems. I use either the RRS 55 or 40 heads. I prefer the 55 head. I prefer the Gitzo explorer because of the leg set which allows great leeway in set up
Bob M
adamba Contributing Member • Posts: 710
Re: Tripod for D700
Don't overlook Benro and Induro. They are more affordable than Gitzo or Manfrotto but offer similar performance. I have Benro M-228n6 carbon fiber tripod with Benro KB-1A ball head purchased about 4 years ago while I was in China. Use it with my Nikon D300 and D7000 with Nikon 24-70 mm and Nikon 70-200mm and so far no complains, work It's light and sturdy, supports a gear up to 8kg.
 adamba's gear list:adamba's gear list
Nikon D600 Nikon D750 Sony Alpha a6300 Nikon AF-S Nikkor 24-70mm f/2.8G ED Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II +5 more
polizonte
polizonte Contributing Member • Posts: 728
Re: Tripod for D700
Another vote for the 055XB with quick release plate tilt/pan head - I just don't like ball heads. The 055XB works well with my D700 +70-200mm. Weight is reasonable - bought it recently to replace my 12 lb. Manfrotto studio tripod with geared column that I bought back in the early 1980's . That was heavy, I don't miss the spiked legs & geared column; I bought the short column accessory on Amazon to shoot low with my Nikon 14-24mm.
Es mejor pescar que ser pescado.
 polizonte's gear list:polizonte's gear list
Nikon D800E Nikon AF-S Micro-Nikkor 60mm f/2.8G ED Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II Nikon 24mm F1.8G ED +1 more
