Weird issue w/Ext. tube + M42 lens
Started Apr 20, 2012 | Discussions
Martin Ocando
Senior MemberPosts: 2,550Gear list
Apr 20, 2012
If I shoot my G3 using the extension tube and my 55mm Takumar, stopped down to f:11, this is what I get. Look the bright spot in the center of the image:
But if I shoot wide open, the center is not bright, but I don't have enough DOF.
What could be causing this, and how to avoid it.
Martin Ocando
 Martin Ocando's gear list:Martin Ocando's gear list
Panasonic Lumix DMC-G5 Panasonic Lumix G 20mm F1.7 ASPH Panasonic Lumix G 14mm F2.5 ASPH Panasonic Lumix G Vario 14-42mm F3.5-5.6 ASPH OIS Panasonic Lumix G Vario 45-150mm F4-5.6 ASPH Mega OIS +6 more
Aleo Veuliah
Forum ProPosts: 14,455Gear list
Re: Weird issue w/Ext. tube + M42 lens
In reply to Martin Ocando, Apr 20, 2012
Really strange, don't know why that happens
Simplicity is the ultimate sophistication.
God is the tangential point between zero and infinity.
Imagination is more important than knowledge.
God always take the simplest way.
 Aleo Veuliah's gear list:Aleo Veuliah's gear list
Panasonic Lumix DMC-ZS1 Panasonic Lumix DMC-GF1 Panasonic Lumix DMC-G2 Nikon 1 V3 Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS +3 more
Martin Ocando
In reply to Aleo Veuliah, Apr 20, 2012
Shows up on the LCD or EVF when shooting. I think it might be related to shooting stopped down. Maybe having aperture control might mitigate the effect.
Martin Ocando
MAubrey
Senior MemberPosts: 1,452Gear list
I've experienced this with extension tubes and legacy glass, too. But I haven't figured out what causes it...
--Mike
 MAubrey's gear list:MAubrey's gear list
Olympus OM-D E-M5 Sony Alpha 7 Olympus M.Zuiko Digital ED 9-18mm 1:4.0-5.6 Voigtlander 58mm F1.4 Nokton SL II Voigtlander 35mm F1.2 Nokton +7 more
MAubrey
In reply to MAubrey, Apr 20, 2012
Flare has been my best guess, but I don't know why that would be a problem only with really small apertures...
--Mike
nickoly
Veteran MemberPosts: 6,953
Umm,, iris busted and bad glass?
Check that the iris is opening and closing properly, that the glass is clear, and also use another lens to determine what the proper exposure might be.
Lights
Veteran MemberPosts: 3,190Gear list
Do you get this with the extension tube off? or any indication of it? (trying to eliminate the tube, from the lens - but if it's a combination of) very odd.
http://www.pbase.com/madlights
http://barriolson.aminus3.com/
Like the Joker said: Why so serious?
A photo may be worth a thousand words but it takes up a lot more space on your hard drive.
nickoly
In reply to Lights, Apr 20, 2012
Aha! good idea...
I can't see hoew it would happen, but it has just occurred to me that the tube could be fouling the iris control pin!
MAubrey
In reply to nickoly, Apr 20, 2012
Well, if that's the case, then my experience of this phenomenon has a different cause. It only happens with the extension tube at small apertures and my lens doesn't have an iris control pin, just an aperture ring.
--Mike
BBbuilder467
Regular MemberPosts: 425
I have a set of cheap extension tubes and what I and others have found is a light leak particularly around the lock/detent button near the lens. If you happen to catch the light just right you can get a terrible flare.
Take the tube and cover the opening and then shine a flashlight at the button and the joints. I covered mine with black electrical tape until I decide to just seal the button hole and leave that lens on semi-permantly. I can actually see through that hole and it reflects on the chrome clip inside.
nickoly
Beats me, but I still think the OPs problems are bigger than the extension tube. I guess we find out when he shoots without one......
I can't see how a tube would foul the pin, and I have no idea how it would cause an aberration like this, hence I suspect the lens(!)
Aleo Veuliah
Maybe it is a reflection from the white on the image, maybe the tubes are not good inside and the small aperture makes it visible , try it with different subjects
Martin Ocando
No issue without the extension tube.
Martin Ocando
Jeremy_T
Senior MemberPosts: 1,224Gear list
In reply to BBbuilder467, Apr 20, 2012
This is what I immediately thought of too.
At wide apertures the light leak might be invisible, since more light is hitting the sensor from your subject the leaked light is not of enough quantity to impact the result in a meaningful way. At small apertures with relatively longer exposures the light leak would effectively be amplified.
 Jeremy_T's gear list:Jeremy_T's gear list
Olympus OM-D E-M5 Panasonic Leica Summilux DG 25mm F1.4 Olympus M.Zuiko Digital 45mm 1:1.8 Panasonic 20mm F1.7 II
Jeremy_T
In reply to Jeremy_T, Apr 20, 2012
Oh also - the light leak might be illuminating the aperture blades themselves.
nickoly
OK, if it is kosher without the tube, maybe the tube is the villain. I assumed the lens was M42 mount, but if it is a PK Mount then maybe Jeremy is right about the light leak, and the problem is between the tube and the adapter. This might be verifiable by holding the mounted lens against your eye and keeping the front cap on.
If no leak is evident, a close check that the tube is not fouling the stop down is in order. Indeed I think you need to do that anyway, because it is pretty clear that things are not too good in the exposure department, even though it may not be a direct cause of your problem.
I suspect the focussing isn't to hot either, but I can't see how it would cause this.
Martin Ocando
Actually focusing is very hard, because the light spot is visible on the viewfinder or LCD, and I have to keep moving the subject to the sides to check focus, and then I snap the picture. Very odd indeed.
I'll check the light leak in a few. I keep you posted.
Martin Ocando
Martin Ocando
+ UPDATE
There is no apparent light leak. I covered the whole structure of tube + adapter + lens, and I saw no change in the shape or intensity of the bright spot.
Now: It does get a bit larger and softer (less evident) with the longer tube, 28mm, and noticeable smaller and brighter (way more annoying) using the small tube (7mm).
I'll try to shoot with the 28mm tube later, but definitively the 14mm (middle tube) is annoying, and I must do some selective adjustments in LR4 to darken the center area. For what I saw, the 7mm is much much worse, so no point in using that one.
Back home I have a couple more m42 lenses, and I will test them out and report my results.
BTW, I did used the tubes with my 14-42mm and 20mm Pannys, and there was no bright spot. But, they were wide open, and since there is no way to stop down, I can't tell for sure it won't show up.
Any more ideas?
Martin Ocando
LincolnB
Senior MemberPosts: 3,623Gear list
looks like some sort of lens flare
Looks exactly like the lens flare I get with my Fujian CCTV lens, with no extension tube, which also changes according to the aperture. It's possible that the lighting you use when doing macros is different than in other types of shots, which might explain why you see it with the extension tubes only.
Just a thought.
 LincolnB's gear list:LincolnB's gear list
Olympus PEN E-P1 Panasonic Lumix DMC-G3 Fujifilm X-E1 Olympus M.Zuiko Digital ED 40-150mm 1:4-5.6 Panasonic Lumix G Vario 14-42mm F3.5-5.6 II ASPH Mega OIS +4 more
Agitprop
Regular MemberPosts: 314
try a shorter extension tube or a lens with a shorter FL.
