D4/ D800(E) - Left AF Problem
Started Apr 18, 2012 | Discussions
bachie
New MemberPosts: 21Gear list
Apr 18, 2012
Recently I heard Nikon's new D800 have a left AF problem.
So I tested my D800 and my friends' D800/D800E/D4.
I checked 8 bodies. (four D800s, two D800Es, two D4s)
  • D800 : 4
  • D800E : 2
  • D4 : 2
Test condition
  • Wide lens (14-24 F2.8, 24mm F1.4G, 35mm F1.4G) with distance of 3m
  • Standard lens (Sigma 50mm F1.4, AF 85mm 1.4D ) with distance of 8m
  • Camera is fiexed on the tripod.
  • Every tests are confirmed by comparing 'contrast AF' in live-view mode.
  • My lenses are perfect in D700 and D3s.
Auto focus near center is really good.
Right side AF is slightly de-focused (not so serious).
All of these camera, however, show significant focusing error in case of left AFs.
3 left AF points result in further focal plane.
When I checked AF ability of my D800 'near' the target, I didn't notice these problem. I think this is really big problem.
Most of all, I found the same AF problem not only in D800(E) but also in D4.
Auto focus module for these new products seems to be not so accurate.
I am very disappointed with this test.
bachie
 bachie's gear list:bachie's gear list
Canon EOS-1Ds Mark III
Nikon D3S Nikon D4 Nikon D700 Nikon D800 Nikon D800E
spho-c
Regular MemberPosts: 264
Re: D4/ D800(E) - Left AF Problem
In reply to bachie, Apr 18, 2012
What serial numbers did the D4s have?
JO
Lea5
Contributing MemberPosts: 569Gear list
Same problem with my D4
checked it with the 14-24 at 14mm and 24mm.
Focussing through VF
Center point: very good
Outer right point: good
Outer left point: very bad
Serial#: 2009XXX
I'll check it with my 50mm 1.4 G and 85 1.4 D too.....
thanks
  • D800 : 4
  • D800E : 2
  • D4 : 2
Test condition
bachie
 Lea5's gear list:Lea5's gear list
Nikon D800E Sony Alpha 7R Nikon D4s Canon EF 17-40mm f/4.0L USM Nikon AF-S Nikkor 14-24mm f/2.8G ED +5 more
Lea5
D4 and 85mm 1.4 D
In reply to Lea5, Apr 18, 2012
Not as bad as the 14-24mm but still visible.
Outer right point: very good
Outer left point: not good
checking the 50mm 1.4 G now...
Serial#: 2009XXX
thanks
  • D800 : 4
  • D800E : 2
  • D4 : 2
Test condition
bachie
Lea5
D4 and 50mm 1.4 G
Outer left point: good
No issues here with the 50mm 1.4 G.
Could be a lens issue, not an AF problem
I'll check my other lenses tomorrow.
And I will fine tune the lenses too. Perhaps the Problem is solved after that.
Serial#: 2009XXX
thanks
  • D800 : 4
  • D800E : 2
  • D4 : 2
Test condition
bachie
PhillipAnthony
Regular MemberPosts: 131
Re: D4 and 85mm 1.4 D
Hi, I have just sent my D800 back to the shop for a refund because of its terrible outer focussing problem!! The left focus point COMPLETELY back focus by 20 af fine tune points and also the right is half that much out yet the middle is fine! So annoyed cos its sensor is AMAZING! They are sending to Nikon UK to confirm a problem before refund so i will let you guys know the outcome. I will know in next couple of days. If they can do a quick fix then i would happily keep the camera. Nikon might actually admit a problem!!!!
Phill
PhillipAnthony
In reply to PhillipAnthony, Apr 18, 2012
Serial number was 8000......
Phill
bachie
Re: I highly recommend to compare AF with CONTRAST AF in live view
At first, I think this problem is originated from low resolution of outer region of lens. But, when I use CONTRAST AF in live view mode, I can get sharp images.
So in order to distinguish current AF problem from lens resolution, contrast AF test is highly recommended.
(My D800) SN: 5600XXX
bachie
Lea5
I need to check my D4 more, before I call my shop. Tomorrow I will take my time in the studio to check the D4 with all my lenses, plus AF finetuning.
I'm not worried at the moment, cause my D3X had a few Af issues too, which was solved very quickly.
Phill
Dominique Dierick
Veteran MemberPosts: 4,467Gear list
Not here.
Maybe that is a bit too fast a conclusion? At least I do not have problems with mine, with any of the AF sensors. I just tried once more with the 85 1.4G left sensors. Spot on at the distance you give, at close distance, and at infinity.
D.
My equipment: Nikon D3s, D800, EOS 450D
The ladies equipment: Panasonic LX5 and GH2 for video
 Dominique Dierick's gear list:Dominique Dierick's gear list
Fujifilm X100S
Dominique Dierick
Not a general fault, images
Here are my results with 85 1.4G left AF sensor. If you can find a problem here, let me know, cuz I don't see one. Which does not mean there will be cameras with problems, lenses with issues, and user error. That has always been the case. It just doesn't seem like a general issue to me.
Close range:
Little test at 6 meter, focused on ashtray
Little test at infinity, through pouring rain
Fujifilm X100S
Leonard Shepherd
Veteran MemberPosts: 8,918Gear list
  • D800 : 4
  • D800E : 2
  • D4 : 2
Maybe you are the only person in the world with testing access to 8 bodies
Presumably if you have access to so many bodies plus D700 and D300, supplying a link to the test target (good or bad for calibration) will not be a problem.
Leonard Shepherd
Photography could be easier - if cameras and lenses came with an increase in skill button.
Nikon D800 Nikon D7100 Nikon AF-S DX Nikkor 18-200mm f/3.5-5.6G IF-ED VR Nikon AF-S DX Nikkor 12-24mm f/4G ED-IF Nikon AF-S Nikkor 16-35mm f/4G ED VR +19 more
russbarnes
Senior MemberPosts: 1,140
Re: Make sure you report it to Nikon!
I hope people are following through with Nikon as I am because as yet I am not hearing about a single individual who has had this fixed. Not one...and I am now close to returning my camera to the retailer and waiting 6 months.
  • D800 : 4
  • D800E : 2
  • D4 : 2
Test condition
bachie
Aamir Amjad
New MemberPosts: 2Gear list
Today tested my D800 with the 85mm 1.4D and had excellent fucusing at all points center, left and right using single point AF-S mode and wide open ie F1.4 to F8. No issues at all - Serial # 8000xxx. However, had severe focus issues with the D7000 earlier which I returned so can imagine that QC is not ideal at Nikon.
 Aamir Amjad's gear list:Aamir Amjad's gear list
Sony RX100 II Nikon D800 Olympus E-M1 Nikon AF Nikkor 85mm f/1.4D
nikoj
Contributing MemberPosts: 783Gear list
In reply to Aamir Amjad, Apr 18, 2012
My D800 is serial #3001xxx, and it's having the left af sensor accuracy/sharpness problem. So far, I've tested it on 24 1.4g, 35 1.4g, 85 1.4g, and 24-70 2.8, and it shows consistent pattern of farthest left sensor to be worst, right farthest about the same as mid left sensor. The center is good. All my prime lenses mentioned have been fine tuned, and with ft off, the results are even worse. My lenses are accurate on my D700. I've had the camera for about three weeks now, and love the IQ. I've been vacillating between sending it in and see if it can be fixed, or wait to see if Nikon comes up with some sort of a fix on their own; however, the more I think about it, the more I feel like I should send it in.
 nikoj's gear list:nikoj's gear list
Fujifilm FinePix X100 Fujifilm X-E1 Fujifilm XF 35mm F1.4 R Fujifilm XF 14mm F2.8 R Fujifilm XF 18-55mm F2.8-4 R LM OIS +2 more
Red G8R
Senior MemberPosts: 1,658Gear list
My D4 - no problem
In reply to nikoj, Apr 18, 2012
I felt pressured to check my focal points because of this thread and I can confirm that that all my focal points are dead sharp.
I wasn't concerned because I've taken several hundred shots so far without any unsharp pics.
A week or so ago I also emailed Ming Thein about this since he was the first Pro to report on it while testing the D800 and he had no focus problems with a D4. My serial # 2011xxx.
Peter
Ontario, Canada
 Red G8R's gear list:Red G8R's gear list
Nikon D4 Nikon D600 Nikon AF-S Nikkor 70-200mm f/2.8G ED VR Nikon AF-S Nikkor 14-24mm f/2.8G ED Nikon AF-S Nikkor 24-70mm f/2.8G ED +9 more
benjaminblack
Contributing MemberPosts: 567Gear list
Re: Not here.
In reply to Dominique Dierick, Apr 18, 2012
Same here
 benjaminblack's gear list:benjaminblack's gear list
Nikon D700 Nikon D810 Nikon AF-S Nikkor 24-70mm f/2.8G ED Nikon AF-S Micro-Nikkor 60mm f/2.8G ED Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II +5 more
TOF guy
TOF guy MOD
Forum ProPosts: 11,594Gear list
In reply to nikoj, Apr 19, 2012
You must really like the camera to even consider not doing it! But you'll come to regret it later if you don't return it.
Thierry
 TOF guy's gear list:TOF guy's gear list
Nikon D810 Nikon AF-S Nikkor 70-200mm f/2.8G ED VR Nikon AF-S DX Nikkor 12-24mm f/4G ED-IF Nikon AF-S Nikkor 24-70mm f/2.8G ED Sigma 150mm F2.8 EX DG OS Macro HSM +3 more
nikoj
In reply to TOF guy, Apr 19, 2012
Thierry
Yep, that's the thing, I really love the camera and don't want to be without it; my D700, as much as I love it, hasn't seen the light since I've gotten the D800. But you're right, I think if don't do anything, it will bug me big time later and the fact fact of knowing I am not getting all that I can out of the camera. I am coming around to think sooner the better at this point. I'll be taking some more test shots in the next couple of days and it'll be off for Melville with my test results included.
ARB1
Veteran MemberPosts: 3,054Gear list
I didn't want to but I returned my D800 to BestBuy after testing it and realizing that the left AF was way off and the right AF was soft. I hate that i had to do it because I really liked the camera but I'd rather wait a few months until Nikon gets it all worked out. I also didn't want to send a brand new $3K camera in for service.
 ARB1's gear list:ARB1's gear list
Olympus OM-D E-M5 Nikon D800 Nikon AF Nikkor 50mm f/1.4D Olympus M.Zuiko Digital ED 9-18mm 1:4.0-5.6 Nikon AF-S Nikkor 24-120mm f/4G ED VR +6 more
