D5100 self-timer and multiple shots
Started Apr 16, 2012 | Discussions
StrokerAce23 Regular Member • Posts: 371
With the D5100 when you combine the self timer with auto bracketing or just a set of continuous shots it counts down the timer internval, takes the shot, and then counts down the interval before the next shot. Example with a 2s timer for 3 shots:
Shutter press, 2s interval, shot, 2s interval, shot, 2s interval, shot
I'm used to cameras counting down the internval once and then taking the programmed number of shots as a burst like so:
Shutter press, 2s interval, shot, shot, shot
Is there a way to configure the D5100 so that it doesn't reset the timer interval between images?
This is useful for group shots and HDR and doing it in camera works for both (just a longer timer for group shots). I'm hoping to figure it out so I can avoid needing a remote and a cable release to deal with each of those situations seperately.
 StrokerAce23's gear list:StrokerAce23's gear list
Sony RX100 Sony RX1 Nikon D7100 Sigma 10-20mm F4-5.6 EX DC HSM Tokina AT-X Pro 50-135mm f/2.8 DX +2 more
Nikon D5100
RobertLaw Senior Member • Posts: 2,019
Re: D5100 self-timer and multiple shots
I don't have a D5100, but on the D90 it is in menu C3. Looking over the D5100 user manual, I can't tell if it as a 'C' category.
As far as possible, without surrender,
be on good terms with all persons.
-- Max Ehrmann
StrokerAce23 OP Regular Member • Posts: 371
I have a copy of the reference manual handy at all times and you are correct that the time delay and number of shots are selected in C3.
That appears to be the only two things you can change. It seems like a setting to keep the timer from resetting would be in that vicinity if there were one.
I'm not sure, but I believe that the number of shots stays the same until you reset them.
-- Max Ehrmann
