Fisheye or Wide-Angle for 7D
Started Apr 14, 2012 | Discussions
Mustafa Senior Member • Posts: 1,306
Re: Fisheye or Wide-Angle for 7D
TrevorNews wrote:
after a week with the Fisheye, I may end up returning it for the 10-22
Trevor
Why?
VisualNectarPhotography
VisualNectarPhotography Regular Member • Posts: 370
Fisheyes are typically around 150-180 degrees of viewing angle Very distorted
Ultra Wides are aver 100 (10-22 is 108 degrees of viewing angle) Some distortion
Wides are 70-100 usually
And zooms do 60 and narrower
These are approximations
Be Content with what you have; rejoice in the way things are. When you realize there is nothing lacking, the whole world belongs to you.
 VisualNectarPhotography's gear list:VisualNectarPhotography's gear list
Canon EOS 300D Nikon D2Hs Canon EOS 60D Canon EF 50mm f/1.8 II Canon EF-S 10-22mm f/3.5-4.5 USM +3 more
lightform
lightform Regular Member • Posts: 120
I would think the fish eye effect would get used very little except for a novelty shot once in awhile. Not a very good replacement for an ultra wide in my opinion. Get a UWA first then if the mood strikes you get a fish eye.
 lightform's gear list:lightform's gear list
Canon EOS 7D Canon EOS 6D Canon EF 17-40mm f/4.0L USM Canon EF 100-400mm f/4.5-5.6L IS USM Canon EF 24-105mm f/4L IS USM +1 more
Jim Gif Junior Member • Posts: 33
I have the 10-22 as well as the Samyang Fisheye, they are quite different lenses and fit different uses. looking back at your first post, the fisheye will be no use to you for architecture, but has a place for landscapes or sunsets producing dramatic and unusual shots but not to give an exact photographic image of what you are seeing. The 10-22 will give a wide view with some but less distortion, ( I think the fisheye claims 160 degrees and the 10-22 about 97 maximum. Personally I use the 17-40mm more (maximum horizontal angle 67 degrees) for buildings. They are different lenses and fit different niches. If you want only one lens you have to define your useage, my advice, keep the fisheye and start saving for your next.
TrevorNews OP Contributing Member • Posts: 598
I think I may use the 10-22 more than the fisheye. I did see some noise from my initial shots. Haven't had time to play with it yet.
Trevor
 TrevorNews's gear list:TrevorNews's gear list
Canon EOS 7D Canon EF 50mm f/1.8 II Canon EF 24-105mm f/4L IS USM
Y0GI Veteran Member • Posts: 5,228
Noise is not attributable to the lens, but rather, camera settings, such as ISO.
Trevor
Yogi
When you get down to the nuts and bolts of photography, the results depend on the 'nut' behind the camera!
See the 'Gear List' in my 'Profile' for my current equipment.
Check out WilbaW's beginner FAQs at - http://snipurl.com/RebelFAQ
 Y0GI's gear list:Y0GI's gear list
Canon EOS 7D Canon EF-S 10-22mm f/3.5-4.5 USM Canon EF-S 17-55mm f/2.8 IS USM Canon EF 100-400mm f/4.5-5.6L IS USM +2 more
Being totally manual you have to work out the best settings for each shot. Being an 8mm lens shutter speed can be very slow without causing problems, and exposure can be sorted here before you need to push up the ISO setting. Set the camera to manual, M on top left wheel, then experiment to bring the exposure setting to centre or slight overexposure.
2 Sample Photo(s) using the 8mm Rokinon Fisheye
I added 2 photos (14+ mb each) if anybody is interested. Link below
http://www.dpreview.com/galleries/6704800890/invite/BF64EC0974BD4C6F8BF09297040F4846
I need to clean my sensor.
Trevor
casdewrf Regular Member • Posts: 259
consider the tokina 11-16
If you are considering a canon 10-22, try a tokina 11-16 also. Do a search on it, and everything positive mentioned about it is quite accurate. I had two canon 10-22's and have now two tokinas they will also work safely on full frame bodies with no risk of mirror collision (some vignetting from 11 to 13.9 on full frame body)
