Should I return my D800 and wait for them to resolve the outer
Started Apr 13, 2012 | Discussions
ARB1
Veteran MemberPosts: 3,018Gear list
Apr 13, 2012
AF issue or do you think it can be fixed via firmware?
I've done a number of tests and yes my D800 is a good bit off on the left and slightly off on the right. I puchased it from BestBuy and have 30 days to return it but I love the camera and would be willing to hold onto it if it looks like a firmware update could/would fix the problem. My LCD has a light yellow tint which is not big deal but I do want the sensor to be working properly on the outer edges.
Allen
 ARB1's gear list:ARB1's gear list
Panasonic Lumix DMC-LX3 Olympus OM-D E-M5 Nikon D800 Nikon AF Nikkor 50mm f/1.4D Olympus M.Zuiko Digital ED 9-18mm 1:4.0-5.6 +7 more
Nikon D800
ollehto
Regular MemberPosts: 122
Re: Should I return my D800 and wait for them to resolve the outer
In reply to ARB1, Apr 13, 2012
What are the first 3 numbers of the serial of your D800 ? So far it seems only reported by people in the 300xxxx range.
Mike Worley
Senior MemberPosts: 1,486
Have you eliminated the lens as a component of the issue? Or, for that matter, yourself, as in what you photographed and how you photographed it.
ARB1
In reply to ollehto, Apr 13, 2012
Yup, that's me 300XXXX
Allen
Press Correspondent
Veteran MemberPosts: 3,342Gear list
What a puzzle...
So you paid an insane amount for a new shiny toy, but they sold you a defective piece of junk. What should you do? Hmmm... That's a good one. The best, in fact. I think you should keep it. The fact that you had to ask shows you deserve it.
 Press Correspondent's gear list:Press Correspondent's gear list
Olympus XZ-1 Canon EOS 5D Mark III Canon EF 50mm f/1.4 USM Canon EF 17-40mm f/4.0L USM Canon EF 70-200mm f/4.0L USM +11 more
ARB1
In reply to Mike Worley, Apr 13, 2012
I shot under a number of different conditions (inside, outside, tripod, handheld, overcast, sunny) and got the same results left to right.
I did not change the lenses though, I shot all with my 24-120mm. I'll do some more tests this weekend with my 28-70mm and 50mm 1.4 to see if the shots improve.
Now when I shoot in AF-C all points are in focus, it's just AF-S that has issues.
Allen
ARB1
Re: What a puzzle...
In reply to Press Correspondent, Apr 13, 2012
Ya' know, I deal with snotty @ss kids all day long, and at my age I don't need to deal with them here, grow up.
Allen
beshannon
Veteran MemberPosts: 4,203Gear list
 beshannon's gear list:beshannon's gear list
Panasonic Lumix DMC-ZS7 Sigma DP2s Nikon Coolpix AW100 Nikon D800E Nikon AF-S Nikkor 16-35mm f/4G ED VR +5 more
Ayrshirephotographer
Regular MemberPosts: 360
Allen
"Now when I shoot in AF-C all points are in focus, it's just AF-S that has issues."
I hear alarm bells going off to this sentence...
"I come to this forum because it sucks less than the others."
ARB1
In reply to Ayrshirephotographer, Apr 13, 2012
Allen
Yes, this was also mentioned in another thread where folks received clean shots while shooting in AF-C, but out-of-focus outer points in AF-S.
What alarm bells are you hearing?
Allen
dmlong1
New MemberPosts: 15
I have the D800 with a serial number in the 3000 range and have tested it out with a 24-120 and all of my other lenses and the focus is extremely sharp. I also have no green screen. It appears that if there is an issue it is only a few that have it.
Someone will always find something.....
michaeladawson
Veteran MemberPosts: 7,253Gear list
Not true at all
The left outer focus issue was first identified in Asia and seemed to be with cameras starting with 800. The first digit of the serial number identifies the world region where the camera was sold.
Mike Dawson
 michaeladawson's gear list:michaeladawson's gear list
Panasonic Lumix DMC-LX3 Nikon D200 Nikon D4 Nikon D800E Nikon AF-S Nikkor 70-200mm f/2.8G ED VR +17 more
ARB1
In reply to dmlong1, Apr 13, 2012
Thanks dmlong1, I'm not one of those nit picky folks so I can deal with the slight yellow tint on the LCD, but I do want my AF points to be sharp. I e-mailed Nikon so I'll wait to see what they say, if I don't hear anything from them I'll bring it back to BestBuy this weekend and get on that long B&H line and hope for better results with a new camera. All-n-all the D800 is a dream camera so I won't give up on it and since I've been a Nikon user for over 30 years it's the only camera for me.
Allen
Dominique Dierick
Veteran MemberPosts: 4,467Gear list
I wouldn't return it if I had the problem
If you see it consistently with other lenses, have the orthogonality of the AF sensor checked. This is very likely the cause if it is not a lens problem.
Should be an easy fix.
My equipment: Nikon D3s, D800, EOS 450D
The ladies equipment: Panasonic LX5 and GH2 for video
 Dominique Dierick's gear list:Dominique Dierick's gear list
Fujifilm X100S
pyzon
Regular MemberPosts: 318
Allen
he has a point, you are asking forum peoples opinions if you should return a $3k defective camera? you bound to expect the 'odd' smart response no? You should have the nouse to know yourself if you should return it or not....
so many people who have bought this camera and in line to buy it still just seem to have either no clue of the mid to advanced functionality of it or are so insecure about it they have to almost ask permission to return it from people here....and no your not the first to do this....
it's faulty - (which I'm sure you'll probably verify after your lens swap) return it - money back or exchange - it's a no brainer at that expense
ollehto
Re: Not true at all
In reply to michaeladawson, Apr 13, 2012
Ok so currently it's reports from the 300xxxx and 800xxx range. Probably even in those ranges there are plenty of people who don't have that specific left AF focus issue in AF-S mode. I'm guessing just bad luck with some batches.
Dominique Dierick
re-calibrating the AF sensor orthogonality is faster than waiting for another camera - which eventually might have rolled of the wrong production line again (if Nikon in the meantime has not fixed their calibration issue on that production line ).
D.
Fujifilm X100S
KenBuse
Regular MemberPosts: 222Gear list
In reply to Dominique Dierick, Apr 13, 2012
My fears are that many of these "defective piece(s) of junk" as someone said; will be returned because users are having problems and then the stores will just turn them around and send the same camera to next in line. This could be me or whoever is waiting for their new camera and expecting the best.
That's why I ordered from B&H and don't mind the wait... I hope they have the integrity to do the right thing. I wouldn't trust your average NY online camera shop.
Dominique Dierick
Re: Not true at all
I suspect one of the production lines has a calibration issue of a tool. Would expect parallel production lines even for one batch. If one of the lines is impacted, this could explain.
Fujifilm X100S
ARB1
In reply to pyzon, Apr 13, 2012
Allen
You know, I'm over 50 years old and for me it's all about how you state your point. It can be done like an adult or like a 10 year old, it's a choice I guess.
I'm not new to Nikon, I go back to the F2AS days. I've paid the price in life to not have to ask permission for much anymore, hense my question had more to do with the possibility of a firmware fix, that's the reason I asked.
