D800 + 85 1.4G Controlled AF Test Results: Left AF point definitely bad.
Started Apr 13, 2012 | Discussions
wl7
wl7
Forum MemberPosts: 53Gear list
Apr 13, 2012
Today I did some controlled autofocus tests using my D800 and 85 1.5G, mounted on a tripod.
I used 5 different AF points during the test, starting with the leftmost, then left center, center, right center, rightmost. I rotated the ballhead so that the AF point being tested was always on the target, and repeated the sequence 5 times. I intentionally defocused after each picture, and the AF mode was set to AFS.
The first picture is an example of the entire frame when using the center AF point. The second picture is a composite of 25 100% crops of the target using the leftmost AF, left center, center, right center, right AF points as labeled across the top.
All shots were taken wide open at f/1.4, ISO 400, 1/125sec, timer + exposure delay with the camera mounted on a tripod, 8 feet away from the target.
Clearly, my camera has a problem with the leftmost AF point. Actually, the sharpest focus was using the right center AF point. The center AF point was still a bit soft.
I haven't yet repeated this test with my 24 1.4, but based on my observations, I am pretty sure that the results would be the same
Nikon needs to address this ASAP. If they don't, my camera will be returned to Best Buy in two weeks before my 30 days are up!
 wl7's gear list:wl7's gear list
Nikon D4S Nikon D810 Nikon AF-S Nikkor 14-24mm f/2.8G ED Nikon AF-S Nikkor 24-70mm f/2.8G ED Nikon AF-S Nikkor 50mm f/1.4G +8 more
Nikon D800
IsaacImage
Regular MemberPosts: 141Gear list
Re: D800 + 85 1.4G Controlled AF Test Results: Left AF point definitely bad.
In reply to wl7, Apr 13, 2012
Thank you very much for your work
What is the serial # of the body pls ?
 IsaacImage's gear list:IsaacImage's gear list
Canon EOS-1D X Nikon D800E Canon EF 85mm f/1.2L II USM Nikon AF-S Nikkor 14-24mm f/2.8G ED Nikon AF-S Nikkor 24-70mm f/2.8G ED +4 more
TigrouMeow
Forum MemberPosts: 70Gear list
I'm using the same lens but I don't have this issue at all. I'll do some more testing in one hour, if I find anything I'll come back on this thread.
 TigrouMeow's gear list:TigrouMeow's gear list
Olympus OM-D E-M5 Nikon D800 Nikon D7100 Nikon D810 Nikon AF-S Nikkor 14-24mm f/2.8G ED +3 more
wl7
wl7 OP
In reply to IsaacImage, Apr 13, 2012
You're welcome. Since I get valuable information from this forum, I feel it is important to contribute as well.
S/N is 3001xxx
fabgo
Senior MemberPosts: 1,298
(nt)
Edit. I see now my question has already been answered.
fabgo
In reply to TigrouMeow, Apr 13, 2012
Whats the approx. serial # of your camera? I wonder if this is issue affects only early camera models, or affects a random number of D800s.
Fabian
olakiril2
Contributing MemberPosts: 639
You can see from the longitudinal chromatic aberration of the lens that the AF sensor is tilted (different colors left to right). The axis of tilt is your center-right AF point.
PLMSG
New MemberPosts: 22
I have problems with the far & mid Left AF points with my AFS 85G/1.4 & D800. I used a tripod and electronic cable release and shot from a distance of about 15 feet @ 1.4 F stop. I used both AFS & AFC and Single shot. When tested from say 6 feet, it was hard to see any difference re focus clarity. I used ISO 1600 for my test to keep the shutter speed > 200.
I reported this to Nikon USA re EMail on 11 April afternoon (USA East Coast Time). I have not heard anything yet.
PLMSG
New MemberPosts: 22
In reply to PLMSG, Apr 13, 2012
The serial number for my camera is 3003XXX.
wl7
wl7 OP
I have also just reported this issue to Nikon. They are asking for the sample photos, which I will send. They said the problem will be escalated, and I should hear back in 1 day.
dennis chapin
Regular MemberPosts: 275Gear list
Serial #300...
I have no focus problems at all. Played with the camera in very low light with an 85mm 1.8D and it works fine.
 dennis chapin's gear list:dennis chapin's gear list
Nikon D5300 Sony Alpha 7S Nikon D810 Nikon AF-S Nikkor 16-35mm F4G ED VR Nikon AF-S Nikkor 300mm f/4D ED-IF +22 more
PHXAZCRAIG
Forum ProPosts: 12,182Gear list
In reply to olakiril2, Apr 13, 2012
I wonder if a batch of D800's was set up with some alignment jig that was off at the factory, resulting in every D800 aligned on that setup to have a problem?
If it's just an alignment issue, I'd assume a recall and some labor would be involved to fix it.
Nikon D80 Nikon D200 Nikon D300 Nikon D700 Nikon 1 V1 +35 more
carcodger
Forum MemberPosts: 50
Not long ago when I had a problem with a camera (nikon v1) from best buy the return window was 14 days and not 30! check into it before it is to late......
zoltrix79
Junior MemberPosts: 45Gear list
I contacted to Nikon for the same issue. They wanted sample images. I sent the sample images - 24 hours later, I got an email that suggests me to do AF micro adjust. Just a boilerplate email. When I asked how AF micro adjust would help with the asymmetric behavior of the left and right focus points, they told me to send the camera in.
Still debating whether I should send the camera now or wait a little longer.
 zoltrix79's gear list:zoltrix79's gear list
Nikon D810
Robin Casady
Forum ProPosts: 12,898
Cameras assembled by...
In reply to fabgo, Apr 13, 2012
It affects the cameras with the AF assembled by Miko on Monday mornings and Friday afternoons.
Anyone old enough to remember when people tried to avoid cars assembled a Monday and Friday?
Robin Casady
http://www.robincasady.com/Photo/index.html
Dominique Dierick
Veteran MemberPosts: 4,494Gear list
Looks like textbook sample focus sensor orthogonality
Assuming that your lens is ok (not decentered), this is a textbook sample of a focus sensor plane out of orthogonality. If you have it with other lenses too, send it in for orthogonality calibration.
Perhaps one of the workbenches at Nikon has a deviation in the measurements. This could explain why some have the problem, while others don't see it. It may not be batch related.
D.
My equipment: Nikon D3s, D800, EOS 450D
The ladies equipment: Panasonic LX5 and GH2 for video
 Dominique Dierick's gear list:Dominique Dierick's gear list
Fujifilm X100S
Robin Casady
So, do the red edges mean the universe is expanding? (Back focus or front focus?)
Robin Casady
Robin Casady
Re: Looks like textbook sample focus sensor orthogonality
In reply to Dominique Dierick, Apr 13, 2012
Not perfectly calibrated after the earthquake, perhaps?
Robin Casady
Dominique Dierick
Hubble trouble
In reply to Robin Casady, Apr 13, 2012
Could of course be any reason. Remember Hubble? Perfectly corrected badly just because of one measurement instrument out of alignment. I think this is what we are seeing with some D800's. Luckily to correct this error, it just takes a round trip to Nikon, not to space. I would send the camera in with 'correct orthogonality AF sensor', not with 'calibrate focus' as a message, just to make sure they get it right.
Fujifilm X100S
reginalddwight
Senior MemberPosts: 2,003Gear list
Same results shooting in AF-C? Live view?
Have you tested accuracy of the various AF points shooting in AF-C mode? Live view?
I have not tested the AF accuracy of my D800 as systematically as you (I have tested the outermost left, center, and outermost right AF points), but I have observed that shooting in AF-C mode essentially negates the mis-focus for me. Not certain why this is the case, but this is my workaround for now. Another suggested workaround is to shoot in live view, as Bill has with his recent wedding assignment.
USA copy, S/N 300XXXX
